Old 08-03-2012, 08:44 PM   #1
jdubz
Drives: 2013 Whiteout FR-S
Solution Found: Rear Deck Rattle
tl;dr The wireless transmitter is loose!
There was a horrible rattle that sounded like a screw or something loose rolling around coming from the back of the car. Dealership didn't put any effort into finding it so I had to find it myself. I figured out that if hit my palm against the bottom of the deck on the driver's side I could replicate the sound I was hearing when driving. After removing the rear deck, I discovered that the wireless transmitter was too loose.
Solution:
1. Take the rear deck out. There are multiple ways to do this--I pulled the plastic pins out that you see when you put the rear seats down and then was able to pull up on the deck after locating the 4 plastic grommets. This is much easier than totally disassembling the rear pillars, etc. Do this at your own risk--you can easily bend or crease the deck if you get in a hurry.
2. Locate the wireless transmitter and find an appropriate sized socket.
3. You can tighten the bolt and see if that fixes your rattle. However, I wanted to make sure I never had to get back there again so I cut a small rubber placemat the size of the transmitter (and a hole for the bolt) and placed it under the transmitter.
4. Tighten the bolt and be rattle free. I've not heard the noise for over two weeks.
5. When you reinstall the rear deck, make sure you push down on it so that there is sufficient clearance between the brake light and the window or else you will hear rattle!
jdubz is offline   Reply With Quote
Old 08-03-2012, 08:55 PM   #2
kendalldwhite
kendalldwhite's Avatar
Drives: Mint-Tiffany blue FRS
good job
kendalldwhite is offline   Reply With Quote
Old 08-03-2012, 09:01 PM   #3
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Do you mean the transmitter was supposed to be bolted on, but was not?
Or was it bolted on, but not tight enough?
Sigh-on-Rice is offline   Reply With Quote
Old 08-03-2012, 09:08 PM   #4
White64Goat
Wireless transmitter for what?
Old 08-03-2012, 09:10 PM   #5
jdubz
It is bolted on but was not snug. Even when I tightened it all the way, I was not sure if that small padding on the bottom of the transmitter provided enough pressure to keep the transmitter from rattling.
Old 08-03-2012, 09:13 PM   #6
jdubz
Part of the 2013 DOT rules. All new cars transmit locations and conversations to local law enforcement.
Key Fob
Old 08-03-2012, 09:33 PM   #7
FRSowner
Drives: Hot Lava A/T
LOL, that was a good one (and probably not too far from the truth in the near future).
FRSowner is offline   Reply With Quote
Old 08-03-2012, 09:36 PM   #8
|-Goku-|
|-Goku-|'s Avatar
Drives: 2011 Civic Si
I think this is my issue. Does this sound like a metallic buzzing when it occurs?
|-Goku-| is offline   Reply With Quote
Old 08-03-2012, 09:51 PM   #9
jdubz
Yes, it is more of a buzz then a rattle. Right around 60mph in 6th gear was my sweet spot for maximum noise.
Old 08-03-2012, 10:04 PM   #10
|-Goku-|
|-Goku-|'s Avatar
You are the man, this is what I am getting.
Can't wait to fix this tomorrow
Old 08-03-2012, 10:11 PM   #11
W2
W2's Avatar
Drives: Firestorm FR-S
I don't have an issue (yet) but if I do I will look there first. Thanks for posting this and hopefully this helps a lot of people that are being driven mad by random sounds in their cars.
W2 is offline   Reply With Quote
Old 08-03-2012, 10:21 PM   #12
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I'll check this when i add some sound deadener this weekend, going to do a little work in the trunk and rear deck areas.
edit: don't have a noise in mine but going to get pro active
JoeBoxer is offline   Reply With Quote
Old 08-03-2012, 10:23 PM   #13
Nepenthe
Drives: 2013 Argento Silver Automatic FR-S
Well done! :happy0180:
Nepenthe is offline   Reply With Quote
Old 08-03-2012, 10:28 PM   #14
Bangduk
Drives: FR-S 2013
thumbs up XD
Bangduk is offline   Reply With Quote
How-To: Remove Rear Deck & Third Brake Light Moshpit37 DIY (Do-It-Yourself) Guides 63 08-01-2020 09:48 PM
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 04:55 AM
solution to the ugly taillights beirouty Cosmetic Modification (Interior/Exterior/Lighting) 107 05-04-2014 03:42 PM
My Front Plate Solution Flat Black VW BRZ First-Gen (2012+) — General Topics 55 11-06-2012 09:07 AM
do you think the rear deck rattle... pr086 Issues | Warranty | Recalls / TSB 7 08-03-2012 04:35 PM
