Old 04-03-2016, 01:02 PM   #1
jxl00
Drives: scion frs 2014
Jolt in AT shifting to second Gear at 7000rpm
Was wondering if anyone else has experienced this.
In 2014 firs AT in manual mode. In first gear around 7000rpm about to shift to 2nd gear, I feel a huge jolt almost as if car is stalling. Did I not shift in time or is something else going on?
Sorry if this is a noob question
jxl00 is offline   Reply With Quote
Old 04-03-2016, 01:30 PM   #2
whataboutbob
AutoX-10/10ths every run
You probably hit the rev limiter before it made the shift. On the OEM tune the rev limiter is a hard limit. It'll cause the motor to bog if you hit it.
Build thread:Here
Old 04-03-2016, 01:42 PM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Given that it's a 2014 and he could possibly be on original fluid, an ATF flush would probably be near.
Old 04-03-2016, 03:14 PM   #4
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Do you get the feeling of the car pulling you back? If you do, I have that on my 2013 if I drive it hard in M Mode. I could also chirp in 2nd doing that (I feel like my transmission has an issue but I had it inspected recently and no issues).
N1rve
Old 04-03-2016, 08:19 PM   #5
jxl00
I do feel the car pulling back. It happened only twice so far. If you have any ideas let me know
Old 04-03-2016, 08:50 PM   #6
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Yup, sounds like bouncing off the rev limiter to me.
shiumai is offline   Reply With Quote
Old 04-05-2016, 08:12 PM   #7
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
This. Working as intended.
Old 04-08-2016, 10:39 AM   #8
frs23
frs23's Avatar
Drives: FR-S H Lava
before concluding did jx see the rev warning red light come, exactly where the revs were if you were playing close attention to the tach, and for an AT car shouldn't you get all the way up to 7600rpm before cutoff ?
frs23 is offline   Reply With Quote
Old 04-08-2016, 04:42 PM   #9
jxl00
i thought the rev was at 7000. did not see an indicator light go on. I could be wrong though. I hope it's not an issue. If it happens again, i'll be sure to update. I just wanted to see if this was an issue many people had and it seems like it is not.
Old 04-08-2016, 06:32 PM   #10
frs23
frs23's Avatar
Drives: FR-S H Lava
if needed, for your peace of mind, you can just try to reproduce it. Rev it until it hits the limiter and see if it feels the same to you. No harm done
3rd gear jolt / clunk after smooth shift 1Cor10:23 Engine, Exhaust, Transmission 2 03-23-2015 11:35 AM
Shifting from 1st-2nd gear... FRSpappa Engine, Exhaust, Transmission 13 05-24-2014 10:06 PM
3 min fix for 2nd gear hard shifting Black Tire Engine, Exhaust, Transmission 22 03-23-2014 12:13 PM
Subtle Jolt when shifting into first MethBear Issues | Warranty | Recalls / TSB 15 01-03-2014 03:01 PM
3rd gear inconsistent shifting mike the snake Issues | Warranty | Recalls / TSB 30 11-22-2013 03:54 PM
