Drives: Whiteout Scion FR-S
3 min fix for 2nd gear hard shifting
Pick your favorite manual transmission fluid by reading other posts: Motul, Pentosin, Amsoil, OEM, whatever.
I currently have Amsoil in the transmission. If I start cold in the winter, second gear will crunch on every shift, and even if I double clutch when it is below 0°F. That is if I can even get it to go into 2nd gear. When this happens I usually just end up skipping 2nd gear altogether. So here's the fix... . . . . . . . . . . . . . . . . ... your not going to like it, so just stop here if and save yourself some time an aggravation if you are the type to get upset... . . . . . . . . . . . . . . . . . . . . . . . ...The 3 min fix: Let the car idle with the transmission in neutral and your foot off of the clutch pedal for at least 3 minutes. The result will be nice smooth 2nd gear shifts. In REALLY cold weather, or with more stubborn fluid, add another minute or so. This has worked every time for me this winter in Minnesota.
| The Following 3 Users Say Thank You to Black Tire For This Useful Post: |
So warming up the transmission and getting it nice and lubed up helps smoothen it out? Huh, never would've thought.
| The Following 2 Users Say Thank You to husker741 For This Useful Post: | BlueDubbinTDI (03-10-2014), Sportsguy83 (03-10-2014) |
#3 | |
Did you miss something?
It would also be nice if Toyota/Scion/Subaru would address this problem more seriously.
Drives: Avensis 2.2 diesel
| The Following 2 Users Say Thank You to Lasse For This Useful Post: | Captain Snooze (03-09-2014), DriftEightSix (03-10-2014) |
I have had cars that have better shifting transmissions that do not have this problem, so why the compromise?
Boosted Member
Drives: 2013 Subaru BRZ
Better shifting does not = stronger.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG 2011 Honda CBR1000RR 2010 Subaru Impreza WRX PRM SSM |
Drives: h22 hatch
what the hell...My second gear is smooth as butter but my third gear feels rough and my car only. Is this also common?
Yea, sure: I'm so sure the Getrag unit in the 1999 BMW M3 I had was not as strong as the one in my FR-S. It may be true that better shifting does not always = stronger, but both can be accomplished with the proper design.
Edit: I really need to be more precise in my comments here. When fully warmed up, the FR-S shifts as smoothly as any car I have ever driven. It is only that it take a LONG time for this to happen in 2nd gear unless I specifically warm it up for that purpose. All of the other cars I have had shifted good and equally well in all gears from a cold start, or after about a few minutes of slower driving in colder weather. After 15 minutes of slow, city driving in cold weather (≤ –10°F), my FR-S still will not smoothly shift into second gear. Some of this may be due to my current transmission fluid, but it should still not take that long with a quality fluid that meets all of the manufacturers specs for the transmission.
I haven't read about it in these forums, but you never know. Is this shifting better with a warm up as I suggested? If not, have you tried changing the transmission fluid?
#10 |
Drives: SC RB FRS
another easy way is slightly going into neutral before going into 2nd gear. works every time.
| The Following User Says Thank You to pitstops For This Useful Post: | Mikepage (03-10-2014) |
#11 | |
Drives: h22 hatch
What fluids are people using? My car is pretty much new (500 miles) but I do plan on upgrading the brake fluid next weekend might as well do that also. |
#12 |
Drives: Sterling BRZ Ltd
When my dad bought his last tacoma it came with the wrong fluid in the manual trans. He had to do this for about 10mins before shifting at all was even possible.
This is an extreme example so please don't run to the dealer saying your fluid is wrong.
| The Following 2 Users Say Thank You to mrk1 For This Useful Post: | Black Tire (03-09-2014), Sportsguy83 (03-10-2014) |
#13 | |
http://www.ft86club.com/forums/showthread.php?t=16604
| The Following User Says Thank You to Black Tire For This Useful Post: | zimzum (03-09-2014) |
#14 |
Coffee Snob
Drives: '14 SWP BRZ Limited
While it doesn't get nearly as cold as other places here in SF, the temperatures certainly do drop at night, and my car is effectively "street parked" since our garage is open on the sides (gated and completely vented).
The car shifts butter smooth after about 5 minutes of easy driving, but I give it a minimum of 30 seconds to warm up (revs to drop).
| Hard shifting into first gear; normal? | blalor | Engine, Exhaust, Transmission | 54 | 08-31-2017 09:57 PM |
| clicking/tapping noise when shifting semi hard | Skurge | Issues | Warranty | Recalls / TSB | 3 | 09-20-2013 04:37 PM |
| Transmission noise when up shifting after hard rev | 1Cor10:23 | Engine, Exhaust, Transmission | 2 | 09-03-2013 03:22 PM |
| hard shifting in sport mode AT | sofrsnsokleen | Issues | Warranty | Recalls / TSB | 11 | 12-12-2012 11:13 AM |
| Hard shifting into 2nd gear when cold | BMWDavid | BRZ First-Gen (2012+) — General Topics | 35 | 06-24-2012 02:22 PM |
