Old 12-24-2013, 03:25 PM   #1
MethBear
Drives: Scion FRS
Subtle Jolt when shifting into first
Not sure if this has been brought up already, at least I didn't notice it.
But my check engine light came on this afternoon and I immediately noticed that when the car comes to a stop (I have a 6 auto) it has a subtle "jolt" as it switches into first gear. I'm not a car guy so I have no idea, any imput would be greatly appreciated. Also, the dealer is closed until Thursday so im relying on ya'lls expertise!
MethBear is offline   Reply With Quote
Old 12-24-2013, 03:27 PM   #2
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
Not sure about the subtle jolt but you can take your to any autozone and they can check the engine code for you.
the new guy is offline   Reply With Quote
Old 12-24-2013, 03:54 PM   #3
humfrz
Yep, get the code read, then we can be more help.
Or maybe some of the AT guys have experienced this .... ??
humfrz
Old 12-24-2013, 06:06 PM   #4
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
Possibly a sticky shift solenoid, I had a similar problem in my Tacoma when I first got it.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 12-24-2013, 06:50 PM   #5
MethBear
Drives: Scion FRS
What was the fix?
Old 12-24-2013, 06:50 PM   #6
MethBear
Drives: Scion FRS
humfrz
Will do, thanks
Old 12-24-2013, 06:59 PM   #7
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
Get that CEL checked out at autozone. I believe the car is basically in a limp mode state (i could be wrong).
I experienced this when i had a CEL a couple of weeks ago. It did the same thing when the car went into 1st. I didn't like the feeling overall but the car ran ok enough to pull over and check the code. I didn't run great, it felt really off but i was able to get from Point A to B. If you have the code checked out report back with what you get.
In my case debris threw the sensors in the Oil Control Valve to go out of whack. After i had the dealer work on it the car works fine, no jolt feeling going into 1st as well.
JonAvalon is offline   Reply With Quote
Old 12-24-2013, 08:54 PM   #8
Sony
Sony's Avatar
Originally Posted by MethBear View Post
What was the fix?
At the time I was under warranty so they replaced the entire transmission.
Old 12-25-2013, 12:25 PM   #9
MethBear
Drives: Scion FRS
Thanks for the feed back, I did get it serviced over the weekend and picked it up on Monday, my feeling is that something might not have been screwed on properly, you comment makes me feel much better though,
Merry Christmas brother!
Old 12-25-2013, 12:26 PM   #10
MethBear
Drives: Scion FRS
Nice, glad they did that for you
Old 12-25-2013, 01:48 PM   #11
Sony
Sony's Avatar
Well my issue was probably a lot worse than yours. Mine wouldn't shift into first until you tried to take off from a stop then it would slam into first and screech the tires. But it would sometime shift into first at a stop with a little jolt...it depended on what it felt like at the time. Ether way your problem is most likely caused by the same issue, a sticky shift solenoid.
Old 12-26-2013, 04:15 PM   #12
MethBear
Drives: Scion FRS
*Update*
Got her back from the dealer, for some reason the CEL was "off" when the tech looked at it even though I was on when I brought it in. Anyway, they did a computer check and noted in the history that there was error code, referring to a "cylinder 1-coil malfunction". so they gave it back to me after they reset the CEL and everything and it seems to drive just fine. Soooo all for naught I guess. Still its good to have her home
Old 12-26-2013, 05:06 PM   #13
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
You need to get that fixed. Coil one pack will lead to worse problems down the line. I have a auto to and it just got replaced. Have you been driving the car hard? Mine happened after some 0-125mph pulls
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 12-27-2013, 05:23 PM   #14
MethBear
Drives: Scion FRS
Originally Posted by vteclol View Post
You should go back or go somewhere else to have it replaced before the coil really starts cutting out. The coils are junk and the CEL will come back sooner or later, usually during high RPMs.
Can i just take it back and be like "can you just fix it anyway"? I know its under warrantee but if it's technically not broken yet will they tell me to wait until it breaks all the way?
frs, jolt, shifter
Subtle rear diffuers, what's out there? wparsons Cosmetic Modification (Interior/Exterior/Lighting) 12 10-11-2013 06:43 PM
Subtle Polyurethane Lip for FRS/86? DriftEightSix Cosmetic Modification (Interior/Exterior/Lighting) 32 09-23-2013 05:41 PM
Subtle Lip Spoiler - where is it? DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 44 10-12-2012 02:18 PM
MT Shifting n8dog11914 Engine, Exhaust, Transmission 4 08-28-2012 03:28 PM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 05:09 PM
