Old 04-01-2016, 11:47 PM   #1
PandaBRZ
PandaBRZ's Avatar
Drives: SWP BRZ
Strange tire wear
Hey, guys.
I went to adjust my AST coilovers today and noticed the inside shoulders of all my tires was wearing really oddly. It's almost squared off and parts are chunking.
My Michelin Pilot Super Sports are at the end of their life, but I haven't seen tires wear this way before.
My alignment is 0 toe all around -1.3° of camber in the front and -1.5° in the back. The fronts have noticeably worse wear than the rears. Strange thing is that read wear is even across the tire, except for the inner shoulders.
Any idea what's causing this? Is it just normal for tires at the end of their life to chunk?
Read my writing about the BRZ on my website.
PandaBRZ is offline   Reply With Quote
Old 04-02-2016, 08:44 AM   #2
WRBrzRX
Drives: runs&drives
theyre toast friend
WRBrzRX is offline   Reply With Quote
Old 04-02-2016, 12:41 PM   #3
PandaBRZ
PandaBRZ's Avatar
Drives: SWP BRZ
Originally Posted by WRBrzRX View Post
theyre toast friend
Yep. Just curious why the inner wear is so severe.
Old 04-02-2016, 12:47 PM   #4
http://www.procarcare.com/includes/c...dtirewear.html
"One Side Wear
When an inner or outer rib wears faster than than the rest of the tire, the need for wheel alignment is indicated. There is excessive camber in the front suspension, causing the wheel to lean too much to the inside or outside and putting too much load on one side of the tire. The car may simply need the wheels aligned, but misalignment could be due to sagging springs, worn ball joints, or worn control arm bushings. Because load has a great affect on alignment, be sure the car is loaded the way it's normally driven when you have the wheels aligned; this is particularly important with independent rear suspension cars."
PandaBRZ (04-02-2016), SmartedPanda (04-02-2016)
Old 04-02-2016, 12:49 PM   #5
PandaBRZ
PandaBRZ's Avatar
Drives: SWP BRZ
Frustrating that this happened after new coilovers and alignment. I'll just replace the tires and watch the wear closely.
The Following User Says Thank You to PandaBRZ For This Useful Post:
Tcoat (04-02-2016)
Old 04-02-2016, 02:58 PM   #6
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Never been to a track day or autox eh?
New tires and alginment (take it to an alignment shop, don't diy it.) . Problem fixed. Good day.
Old 04-02-2016, 03:13 PM   #7
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
How many miles did you drive with the new coilovers overall?
How much time between installing coilovers and then alignment?
What's your camber at?
Sounds like too much camber or bad alignment or both.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 04-02-2016, 03:19 PM   #8
2ZZW30
Drives: 2000 Toyota MR2 Spyder
Looks like toe wear to me but if your specs are actually what you quoted you shouldn't be having extreme wear like that.
2ZZW30 is offline   Reply With Quote
Old 04-03-2016, 02:19 AM   #9
PandaBRZ
PandaBRZ's Avatar
Drives: SWP BRZ
I've driven 3k miles on the coilovers overall. The car was aligned immediately after installing them. Camber is at -1.3 in the front and -1.5 in the rear.
I'm thinking @Tcoat was right about the springs settling after the install and affecting the alignment.
At this rate, I'm going to get a new set of tires and another alignment just to be safe.
Tcoat (04-03-2016)
Old 04-03-2016, 04:32 PM   #10
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I would try to convince the place that did your original alignment to give you another one free of charge, based on the assumption that they should've had you come back for the alignment after driving around post install for a week or so.
Originally Posted by humfrz
I'm old and lazy
EAGLE5 (04-03-2016)
Old 04-03-2016, 04:53 PM   #11
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Ya. Things seem to need time to settle.
Old 04-03-2016, 04:56 PM   #12
EAGLE5
Dismember
EAGLE5's Avatar
Driving fast also messes things up. I can't imagine you bought those expensive coilovers just to drive slowly.
The Following User Says Thank You to EAGLE5 For This Useful Post:
PandaBRZ (04-03-2016)
Old 04-18-2016, 02:22 AM   #13
PandaBRZ
PandaBRZ's Avatar
Drives: SWP BRZ
Just a quick update for everyone.
I had the car's alignment checked and everything was up to spec as when I had the coilovers installed. That means it wasn't the alignment settings causing the wear, but a defect in the tire at the end of its life. It seems to me that the MPSS deteriorate rapidly towards the end of its life, kinda like a Die Hard battery. When it dies, it DIES.
I replaced them with another set of MPSS and the wear is fine after 1,000 miles. I'll keep an eye on the tires and will report back any anomalies.
Tire Wear question bacon_cheese_beer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 12-08-2014 02:51 AM
Tire Wear Help babykwiss Tracking / Autocross / HPDE / Drifting 10 07-14-2014 11:31 AM
Odd rear tire wear...anyone else? BRZnut Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 03-09-2014 07:31 PM
Let's Discuss Tire Wear SkitterSkotter Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-14-2014 11:35 PM
question about tire wear driver01 Tracking / Autocross / HPDE / Drifting 8 08-05-2012 09:50 PM
