Old 08-02-2012, 10:30 PM   #1
driver01
Drives: brz 13
question about tire wear
Delete
driver01 is offline   Reply With Quote
Old 08-03-2012, 08:11 AM   #2
mla163
Overthinking it
Drives: BRZ in CS
That's absolutely normal if you aren't running any camber.
mla163 is offline   Reply With Quote
Old 08-03-2012, 08:37 AM   #3
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Normal if you are not running any - camber. I added -2 Front -1.6 Rear ill add camber or subtract depending on tire temps i will let you know.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 08-03-2012, 09:09 AM   #4
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
camber and driving style
a lot of people use the tires to scrub of speed at entry rather than braking properly, it's a habit that's hard to break.
could also be incorrect tire pressures, i remember i burned through half of my RE11's in a single day when i first bought them, then went online and checked the pressures (should have done it sooner) and had them last the rest of the season.
Old 08-03-2012, 09:19 AM   #5
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
It's pretty typical, even if you dial up the camber it can still happen. If they are symmetrical flip 'em on the wheels after a few autox events or between track days and you'll increase the tire life.
Sccabrz192 is offline   Reply With Quote
Old 08-03-2012, 10:07 AM   #6
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
I'm also running AD08's - autocross only, no track days - and have seen the exact same thing. I'm running the max camber I can under SCCA stock rules at ~1.3 deg front and ~1 deg rear. The AD08's are symmetrical and I flipped mine at ~115 runs after starting them at full tread depth. At that point, I had basically erased the shoulder sipes on two of them and had the other two worn down pretty far.
jdrxb9 is offline   Reply With Quote
Old 08-04-2012, 08:11 PM   #7
driver01
Drives: brz 13
Delete
Old 08-04-2012, 11:44 PM   #8
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by driver01 View Post
or if I feel i need some rotation at 35 front and 37 rear. Is that low or high from your experience?
what does Yokohama say? Send their techs an email.
Old 08-05-2012, 09:50 PM   #9
jdrxb9
jdrxb9's Avatar
I have been running my tire pressure at 35 all around. or if I feel i need some rotation at 35 front and 37 rear. Is that low or high from your experience?
I think this will be setup/surface/driver dependent, but I'm now at 36-38 F and 34-38 R, pavement/weather/co-driver dependent. At those pressures I'm still scrubbing the 'tips' off the 'triangles' that indicate how much the tire is rolling onto the sidewall, but I can live with the wear rate. YMMV
Tire Sidewall Question applekash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-26-2012 08:42 PM
Outer tire wear at track? fasteddy Tracking / Autocross / HPDE / Drifting 20 07-24-2012 01:16 PM
tire deformation question. dsgerbc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 05-30-2012 03:50 AM
Total noob tire-change question Sport-Tech Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 04-17-2012 07:15 PM
wear your seatbelt... bofa Off-Topic Lounge [WARNING: NO POLITICS] 17 07-16-2011 04:25 AM
