Old 02-04-2013, 12:14 PM   #1
SkitterSkotter
SkitterSkotter's Avatar
Drives: 2013 Scion FR-S (Hot Lava)
Let's Discuss Tire Wear
So i'm near as makes no difference to 7,000 miles, and I don't believe I drive particularly hard, though I do hoon about given the right circumstances. Anyways, I checked my tread depth this morning and I was a bit surprised by how much less depth the rear treads have. I would say they are about 1.5mm more shallow than the front.
I realize that the tries will be rotated as per the usual 7,500 mile standard check up, but I believe the tires are supposed to last about 45,000 miles. So two points here, one: how is your tread depth looking in relation to your miles and how have you driven? Two: should I expect a set if tires to last about 20,000 miles? I should post up some pictures of the current depths, perhaps I can do that in a bit. With my old Accord I went through tires quickly, but they would always be covered by warranty because it was not a performance car, with this car, I suspect, I will not be so lucky.
SkitterSkotter is offline   Reply With Quote
Old 02-04-2013, 01:29 PM   #2
HotLavaMann
First 86 member
Drives: FRS, Tacoma, Honda CB1100
I just had my tires rotated at 7000 miles and there was equal wear front and back. ( I thought it a bit strange because I certainly let the back end move out going around corners etc). Just another data point.
HotLavaMann is offline   Reply With Quote
Old 02-04-2013, 03:04 PM   #3
Synack
Boosted
Synack's Avatar
Drives: Sideways
You are super lucky. My rear tires are lucky if they last 5000 miles.
Old 02-04-2013, 10:18 PM   #4
getbent
Drives: 2013 FR-S Blue MT
With a treadwear rating of 240, I would expect them to last upwards of 20-30K if they aren't abused and rotated frequently.
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 02-04-2013, 10:40 PM   #5
Synack
Boosted
Synack's Avatar
Drives: Sideways
Also the rear camber is about -1.5 so expect your inner tire to wear quite a bit faster than the middle and outer tire.
Old 02-04-2013, 10:41 PM   #6
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
The nice thing about having equal size tires front and rear with a higher rear wear rate is that you can always keep the tires with more tread on back without risking safety. In other words, say you blew a tire halfway thru the tread life. Well, you could simply buy 2 new ones and put them in the rear and eventually all 4 will end up with about even wear. Compared to a front wheel drive or front based all wheel drive with a higher front wear rate, where you would potentially have to deal with snap oversteer by keeping the worn tires in the rear, which is why they advise just replacing all 4 tires in a situation like that.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 02-04-2013, 10:44 PM   #7
Batman
Easy, Tiger.
Batman's Avatar
Drives: Tiguan, S4, SBC 350 Wrangler
I rotated my tires around 5k, all are worn pretty bad by now. When I first got the car (after break in) there was a chunk of hooning, but not as much as would be expected by looking at my tires
Two V8s, one turbo, 12 Wheels total.
Batman is offline   Reply With Quote
Old 07-22-2013, 09:38 AM   #8
DarkSunrise
DarkSunrise's Avatar
Bumping this topic.
I checked the tread-depth on my tires and found the rears wearing much faster than the fronts. About 8/32" remaining on the rears, 10/32" on the fronts.
Sumitomo HTR-ZIII, 4k miles, 2 autocrosses, no track days.
I'll probably rotate them soon, but is it normal to see the rears wear that much quicker in only 4k miles?
2022 BRZ Build
2013 FR-S Build
Old 07-22-2013, 10:59 AM   #9
infinite012
Drives: 13 DGM BRZ Ltd
Get your alignment checked.
But yes, it's pretty normal on a RWD car for the rears to wear quicker than the fronts. How much quicker is up to the alignment settings and how hard you drive it.
infinite012 is offline   Reply With Quote
Old 07-22-2013, 11:27 AM   #10
DarkSunrise
Yeah the odd part is I don't really drive this car that hard, other than autocrossing and hitting backroads a few times a month. Oh well, I guess I'll get an alignment if things don't improve after rotation.
2022 BRZ Build
2013 FR-S Build
Old 07-22-2013, 11:34 AM   #11
autobrz
Drives: Mazda 3
toe is what wears tires camber alone doesnt affect wear very much
Sent from my SGH-T989 using Tapatalk 4 Beta
autobrz is offline   Reply With Quote
Old 07-22-2013, 11:51 AM   #12
infinite012
Yes, this. Little changes in toe in or out will massively affect tire wear.
Old 01-14-2014, 11:35 PM   #13
Kaleb765
Kaleb765's Avatar
Drives: 2015 Scion FR-S Raven Black
My rear tires are down to the tread bars beacuse I drift around just about every corner... Is is it "safe" to put them in the front and burn up the 2 that were up front? Or should I just replace the rear 2 with new tires? I guess that might be better, then I'm only buying 2 tires at a time and not 4... Idk.... Opinions??
Kaleb765 is offline   Reply With Quote
Let's discuss SCCA Stock Class ayau Tracking / Autocross / HPDE / Drifting 314 04-18-2013 02:03 PM
question about tire wear driver01 Tracking / Autocross / HPDE / Drifting 8 08-05-2012 09:50 PM
Outer tire wear at track? fasteddy Tracking / Autocross / HPDE / Drifting 20 07-24-2012 01:16 PM
Share/discuss (this mornin) 86 Newsletter... RebootWindows AUSTRALIA 6 07-19-2012 04:15 PM
Discuss.... carbonBLUE Off-Topic Lounge [WARNING: NO POLITICS] 12 02-11-2012 12:55 PM
