Old 03-31-2016, 06:19 PM   #1
enderr
enderr's Avatar
Drives: 2013 Toyobaru FT-86
Question Turbo Kits that don't vent to atmosphere
Which turbo kits have diverter valves which vent back into the intake and wastegates which vent into the exhaust. I want a turbo, don't want any turbo noises...
enderr is offline   Reply With Quote
Old 03-31-2016, 06:20 PM   #2
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Originally Posted by enderr View Post
Which turbo kits have diverter valves and wastegates which vent into the exhaust. I want a turbo, don't want any turbo noises...
then buy a supercharger if you don't want turbo noises... either way you'll get sound from the wastegate or you'll get compressor surge from there not having a BOV. Also you'll get spool sounds.
Instagram: trevor.parque
Old 03-31-2016, 06:24 PM   #3
enderr
enderr's Avatar
sound from the wastegate throught exhaust and muffler = OK
Spool sounds = OK
"compressor surge from there not having a BOV" = WRONG
Diverter valves are BOV's, they just "divert" to the non pressurized intake side. Like the kind used by OEM's (Ford, Porsche, Ferrari, Nissian, GM, shall I go on?)
Old 03-31-2016, 06:28 PM   #4
MisterSheep
Killed Scion
sound from the wastegate = OK
Spool sounds = OK
= WRONG
instead of having this kind of response you should have been clearer in your original post. Should've said I want a Bypass/Diverter valve.
Diverter valves or bypass valves are in fact different from a blow off valve but a blow off valve could also be a bypass valve. NOT having one will in fact create a compressor surge sound. SBD kit is an example of this.
Most people who are looking for very specific guidelines for their kit (like you) will just go custom. So that's what I recommend.
The Following 3 Users Say Thank You to MisterSheep For This Useful Post:
Chrisgalactic (04-01-2016), Leonardo (03-31-2016), NyC Zn6 (04-02-2016)
Old 03-31-2016, 06:55 PM   #5
kch
Senior Misanthrope
kch's Avatar
I know JDL can do a recirc wastegate.
The Following User Says Thank You to kch For This Useful Post:
enderr (03-31-2016)
Old 03-31-2016, 07:06 PM   #6
enderr
enderr's Avatar
= WRONG
My Bad!!! I forgot the word "Diverter"
...there is always the option of getting a custom KIT that I've never really thought about. All of these requirements can be met by the AVO kit but it's quality is garbage. There's has to be someone else off the shelf.
Old 03-31-2016, 07:06 PM   #7
enderr
enderr's Avatar
this is important information...
Old 03-31-2016, 07:31 PM   #8
mrk1
Drives: Sterling BRZ Ltd
Neither recirc requests are difficult to do, just talk to the shops that make there kits.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
FRS Justin (03-31-2016)
Old 03-31-2016, 07:37 PM   #9
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
We do recirculated dumps and diverter valve setups quite often. It's not standard on the kits but can be done easily.
JDLAutoDesign is offline   Reply With Quote
The Following User Says Thank You to JDLAutoDesign For This Useful Post:
Bykov (03-31-2016)
Old 03-31-2016, 09:41 PM   #10
apelpapa
apelpapa's Avatar
Drives: 2013 SPD Black FR-S
= WRONG
The SBD comes with a blowoff now
apelpapa is offline   Reply With Quote
Old 03-31-2016, 10:18 PM   #11
You can recirc a greddy.
Old 03-31-2016, 10:26 PM   #12
apelpapa
apelpapa's Avatar
The greddy blowoffs can recirculate, but I don't think they come with the kit, you would need to buy one and weld a flange. SBD added one to their kit.
Old 04-01-2016, 12:08 AM   #13
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Full Blown offers a recirculating wastegate.
Also on some BOV, they actually have a part simply there for the noise, remove it and it just vents.
On the HKS SSQV BOV's you take off the housing and pull out the silver sleeve. They sell a purple sleeve you replace it with ($20 or so) and it makes the BOV less obnoxious... not as quiet as recir back to the intake though-
Old 04-01-2016, 12:56 AM   #14
apelpapa
apelpapa's Avatar
Ya, there are a ton of options. But basically, I would not not decide on a kit based on whether or not it recirculates, since you can add this later or switch the blowoff to a recirculating, or even some how recirculating converters. There are many many options.
Best Turbo kit / kits to stay away from? bren5279 Forced Induction 137 07-26-2018 10:50 AM
OFT tuning with other turbo kits NyC Zn6 Software Tuning 27 09-05-2016 11:52 AM
Negatives of unmetered BOV to atmosphere kbogarto Forced Induction 8 02-22-2015 09:03 PM
turbo kits ogrowup Engine, Exhaust, Transmission 4 01-03-2015 08:39 AM
Why is no one using sti turbo kits? diss7 Forced Induction 12 05-16-2014 11:10 AM
