Drives: 2013 BRZ limited WRB
Negatives of unmetered BOV to atmosphere
What are the negatives of venting unmetered air to the atmosphere? I understand it puts fuel into the cylinders that there isnt air to burn. But other than losing some fuel does running this set up long term damage anything?? Thanks
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Makes it more difficult to tune. Introduces a variable for no reason. Long term issues would be dependent on how well the tune can compensate for it.
| The Following User Says Thank You to Whatabouteggs For This Useful Post: | kbogarto (02-22-2015) |
Drives: 2013 Black FR-S
What? I think you've got it backwards.
You can do whatever you like with un-metered air because the MAF hasn't seen this air yet and thus fueling and spark hasn't compensated. It is bad to vent METERED air because the MAF has seen that air and has told the ecu about this air. So if you dump it after the MAF has seen it then you get issues.
| The Following 2 Users Say Thank You to sw20kosh For This Useful Post: | Travisty75 (02-22-2015), Ultramaroon (02-22-2015) |
#4 | |
[Citation Needed]
If you do that and don't do anything else, you'll be running too rich. Worse mileage, worse response, black smoke out of the exhaust from unburned gas, if you have a cat it will damage it.
If you pay whatever and get a great tune along with it, best case scenario you get no performance benefit, negligible additional wear and all the wooshing noises you want. |
#6 | |
| The Following 4 Users Say Thank You to sw20kosh For This Useful Post: |
not playing cards
@Whatabouteggs, does sw20kosh's explanation click for you? He is correct but we can discuss some more if you like. This could be a fun, interesting learning experience, IMHO.
As long as the bov is before the maf... There will be no difference. The only difference would occur if your bov is right before or very close to your maf sensor and caused turbulence when open as with mine on my JDL. also if you are 100% speed density it makes absolutely no difference. This question is best left to your tuner... Especially since you haven't mentioned what setup you are actually running. We would just be guessing at random.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
[Citation Needed]
That is true. Depends on the MAF placement of the kit though. AVO's kit uses the stock MAF location I believe, so that wouldn't be possible. It uses a MAP sensor that comes with the kit to control for pressure, and the MAF for temperature and total air metered.
| Greddy SP Elite axle back-any negatives? | BMWDavid | Engine, Exhaust, Transmission | 72 | 12-31-2014 06:31 PM |
