Drives: 2013 Toyobaru FT-86
Which turbo kits have diverter valves which vent back into the intake and wastegates which vent into the exhaust. I want a turbo, don't want any turbo noises...
#2 |
Killed Scion
Drives: 2013 FR-S Whiteout
then buy a supercharger if you don't want turbo noises... either way you'll get sound from the wastegate or you'll get compressor surge from there not having a BOV. Also you'll get spool sounds.
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
#3 | |
Spool sounds = OK "compressor surge from there not having a BOV" = WRONG ![]() Diverter valves are BOV's, they just "divert" to the non pressurized intake side. Like the kind used by OEM's (Ford, Porsche, Ferrari, Nissian, GM, shall I go on?) |
#4 | |
Killed Scion
instead of having this kind of response you should have been clearer in your original post. Should've said I want a Bypass/Diverter valve. Diverter valves or bypass valves are in fact different from a blow off valve but a blow off valve could also be a bypass valve. NOT having one will in fact create a compressor surge sound. SBD kit is an example of this. Most people who are looking for very specific guidelines for their kit (like you) will just go custom. So that's what I recommend.
| The Following 3 Users Say Thank You to MisterSheep For This Useful Post: |
#6 | |
...there is always the option of getting a custom KIT that I've never really thought about. All of these requirements can be met by the AVO kit but it's quality is garbage. There's has to be someone else off the shelf. |
#7 |
#8 |
Drives: Sterling BRZ Ltd
Neither recirc requests are difficult to do, just talk to the shops that make there kits.
| The Following User Says Thank You to mrk1 For This Useful Post: | FRS Justin (03-31-2016) |
#9 |
Drives: 13 FRS
We do recirculated dumps and diverter valve setups quite often. It's not standard on the kits but can be done easily.
| The Following User Says Thank You to JDLAutoDesign For This Useful Post: | Bykov (03-31-2016) |
#10 | |
Drives: 2013 SPD Black FR-S
#11 |
You can recirc a greddy.
#12 |
#13 |
Drives: RX-7 / BRZ
Full Blown offers a recirculating wastegate.
Also on some BOV, they actually have a part simply there for the noise, remove it and it just vents. On the HKS SSQV BOV's you take off the housing and pull out the silver sleeve. They sell a purple sleeve you replace it with ($20 or so) and it makes the BOV less obnoxious... not as quiet as recir back to the intake though-
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#14 |
Ya, there are a ton of options. But basically, I would not not decide on a kit based on whether or not it recirculates, since you can add this later or switch the blowoff to a recirculating, or even some how recirculating converters. There are many many options.
| Best Turbo kit / kits to stay away from? | bren5279 | Forced Induction | 137 | 07-26-2018 10:50 AM |
| OFT tuning with other turbo kits | NyC Zn6 | Software Tuning | 27 | 09-05-2016 11:52 AM |
| Negatives of unmetered BOV to atmosphere | kbogarto | Forced Induction | 8 | 02-22-2015 09:03 PM |
| turbo kits | ogrowup | Engine, Exhaust, Transmission | 4 | 01-03-2015 08:39 AM |
| Why is no one using sti turbo kits? | diss7 | Forced Induction | 12 | 05-16-2014 11:10 AM |
