Old 02-25-2016, 12:13 PM   #1
Shift86
Drives: 2014 Whiteout Monogram Edition - MT
Titanium Exhaust Wraps?
To be honest, I've never even heard of them until now. How well do these actually work?
https://www.massdrop.com/buy/dei-tit...st-wrap-bundle
Shift86 is offline   Reply With Quote
Old 02-25-2016, 12:22 PM   #2
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Extremely well. I can get out from a decent drive (with Turbo) and place my hand on the header and it's warm at best. The header wrap is very effective.
You will need to be careful though. It can trap moisture and cause Rusting. There is also a possibility of certain parts cracking due to the added heat, though I haven't ever experienced that myself.
DustinS is offline   Reply With Quote
The Following User Says Thank You to DustinS For This Useful Post:
go_a_way1 (02-25-2016)
Old 02-25-2016, 12:22 PM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Yeah I hear good things about them, but TBH its all pretty much the same stuff. If you are wrapping a header budget for a replacement one day.
Old 02-25-2016, 12:49 PM   #4
Icecreamtruk
Drives: Track preped NA FRS
Mind you that while the header wrap makes it so it radiates less heat into the engine bay it is not magically making the heat go away, it is keeping it inside the header. It might give you very small gains as keeping the heat inside the header will increase the speed of the gasses flowing thru and possibly scavenge more out of the cylinders. But it will certainly put a hell of a lot more stress on the header and expect it to completely disintegrate over time so yeah, save up for a replacement if you decide to wrap it.
Old 02-25-2016, 12:51 PM   #5
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
It's way nicer than the traditional kind of exhaust wrap. Way less itchy to use.
I'm not worried about rust. These are stainless headers, and moisture doesn't really stick around if you just drive the car frequently. I could see it being a concern if you park your car for a season at a time and you were wrapping a cast iron header. But I don't, so I won't.
jawn is offline   Reply With Quote
Old 02-25-2016, 07:03 PM   #6
KoolBRZ
KoolBRZ's Avatar
I've tried several exhaust heat wraps
The difference is night and day between this wrap and the glass fiber wraps. There is no soaking required, It only smokes a tiny amount the first day, rather than clouds of smoke for weeks. It doesn't stink all the time, the odor goes away after the first day or two. Glass fiber wraps suck, these don't.
If I say yes, will that make you think I understand?
Old 02-25-2016, 07:13 PM   #7
You won't get the itchy scratchy stuff with the Titanium wrap. Make sure it's tight, and overlap consistently. COnsistency is key, and use safety wire to ensure the ends don't fray or start unraveling.
A great alternative is ceramic coating, if you don't want to deal with wrap, or have tight spaces that can't support the extra thickness of a wrap.
CSG now offers ceramic coating as well; cost is dependent on the piece.
churchx (02-25-2016)
Old 02-25-2016, 08:27 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
Nice to find out that one can get Ace's goodies right away now without going to other shops to add coating.
Old 02-26-2016, 01:31 AM   #9
Poodles
Drives: 2015 Series.Blue
Doesn't just have to be an alternative. Fairly common in the turbo world to ceramic coat (inside and out) and also wrap/blanket.
Keep in mind also that the deterioration of the metal isn't from moisture, it's from oxygen. Watch a blacksmith work red hot metal and the scale that forms on the surface, same process. Terribly complex process that I'm dumbing down as scale can be both a bad and good thing (good if it's non-porous and high density as it's a protective layer). Stainless creates chromium rich scale, but this all depends on the grade of stainless, etc. Gets complex fast...
Old 02-26-2016, 02:00 AM   #10
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Personally i would rather go with ceramic coating. However it is not cheap but the result is quite good. I remember i had my downpipes coated back in my mr2, supra days.
Muaddib is offline   Reply With Quote
Old 02-26-2016, 02:14 AM   #11
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Just so you know it's cheaper to buy this on ebay:
http://www.ebay.com/itm/DEI-010127-2..._I33Nw&vxp=mtr
Old 11-20-2020, 04:38 PM   #12
Nigori
Nigori's Avatar
Drives: 2020 Hakone 86
Anyone know how much wrap is needed for the Tomei EL Headers?
https://www.counterspacegarage.com/t...r-brz-frs-gt86
Nigori is offline   Reply With Quote
Old 12-07-2020, 07:29 AM   #13
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
Another option that allows the pipes to breathe is enclosing them in an insulator like DEI's Form-A-Shield
https://www.designengineering.com/fo...d-42in-x-48in/
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
FS: INVIDIA N1 EXHAUST (TITANIUM TIP) jshum Engine, Exhaust, Bolt-Ons 9 07-03-2014 11:54 PM
Titanium exhaust 4032pauln Cosmetic Modification (Interior/Exterior/Lighting) 7 04-12-2014 07:53 PM
Titanium Exhaust dj petey Engine, Exhaust, Transmission 37 04-11-2013 01:40 AM
GB for roof wraps or hood wraps... QFry Northwest 2 10-28-2012 10:39 PM
Titanium Exhaust yomchi1989 AUSTRALIA 6 09-18-2012 10:50 PM
