Drives: 2015 scion frs
Wheel fitment question
Wheel size is 17x8.25 with a +35 offset.
Also would a 235/40/17 be the perfect tire for this wheel? Also I'll be on coilovers and would I need spacers to be flush? I read on here fronts should be flush but rears sucked in a little bit. Also I've searched but the wheel fitment kinda brain farts me sometimes. |
Not a troll
225/45 probably. And then you'll have more tire options. Might need a small spacer in the rear.
| The Following User Says Thank You to Cole For This Useful Post: | Frsboxer (01-27-2016) |
Would 235's hurt I have a set already from my previous car and they are pretty new still so I would like to use those to save money
Not a troll
Nope, that's totally ok. 235/40 is a fine fitment in that scenario. Just for future reference, 225/45 is a (maybe) better choice because of a wider choice of tires.
It depends how much you're dropped if the front/rear will be flush or not.
| The Following User Says Thank You to tyler_win_photo For This Useful Post: | Frsboxer (01-27-2016) |
AutoX-10/10ths every run
| The Following User Says Thank You to whataboutbob For This Useful Post: | Frsboxer (01-27-2016) |
Thanks guys the wheel chart made since. I'm gonna adjust coilovers when the I put the wheels on and I'll see where it goes from there
| The Following User Says Thank You to Frsboxer For This Useful Post: | whataboutbob (01-27-2016) |
| Wheel/Tire size help!!! | jordanlee2393 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 06-07-2015 07:11 PM |
| Tire Size Recommendation! | Cvxne | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 05-04-2015 01:13 PM |
| wheel and tire size questions | BRZ21 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 11-02-2014 04:46 AM |
| Help with wheel\tire size for a DD on Pro Kit | B-R-Z | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 04-08-2014 02:06 PM |
| Tire/Wheel or auto shop recommendation in Seattle area please. | mugen79 | Northwest | 6 | 12-04-2012 01:13 PM |
