Old 05-02-2015, 07:16 AM   #1
Cvxne
Cvxne's Avatar
Drives: 2013 Whiteout FRS
Tire Size Recommendation!
My buddy owns an frs and bought 18x9.5+35 rims. He is lowered about 2.2-2.5 inches on bc extreme lows. Anyone have a recommended tire size?
Cvxne is offline   Reply With Quote
Old 05-02-2015, 11:30 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
To each his own. There is no one-size fits all. Some go wider & lower profile, some even for smaller 16" and stock-ish thread widths/sizes. Some care about flushiness with fenders and play with spacers & offset, some care more about scrub radius & bearing longitivity and leave as is. If it's for him, not for you (and just mentioning him as example), he should install whatever he prefers/wishes more. Be it some narrower stretched tire, be it some wider one, be it whatever is closer to stock diameter to not throw off speedo readings much.
Old 05-04-2015, 01:35 AM   #3
TB
TB's Avatar
Drives: 2014 Scion FR-S Monogram
SASKYSASKATCHEWAN SK86BRZ / TB BUILD THREAD MY BUILD
TB is offline   Reply With Quote
Old 05-04-2015, 02:07 AM   #4
Pete156
I like to eat!
That low, with that amount of poke, he'll likely need camber (lots) or stretched tires (<245) or both to avoid rubbing. Just my 2 cents
Pete156 is offline   Reply With Quote
Old 05-04-2015, 11:35 AM   #5
DavidBob
DavidBob's Avatar
Drives: 2013 WRB BRZ
Im maxed out (isc coilovers) on 18x9.5 et38 with 225/40's. No rubbing at all untill i put 20mm spacers on the back for better fitment and now i rub a little but thats only in the back
Bottom line is he wont rub on 225's with no spacers
DavidBob is offline   Reply With Quote
Old 05-04-2015, 11:37 AM   #6
Timmy_Jones
Spun
Drives: 23' Supra
245 Front and 255-265 rear, but I don't know if they will fit.
Timmy_Jones is offline   Reply With Quote
Old 05-04-2015, 12:11 PM   #7
AlexWood
Drives:
Size:  197.7 KB18x9.5 +34 w/ 235/40 nankangs. Very minimal rubbing in the front under full lock. Natural camber in the rear and about -2 in front on the camber plates.
AlexWood is offline   Reply With Quote
Old 05-04-2015, 12:13 PM   #8
AlexWood
Drives:
Originally Posted by AlexWood View Post
Attachment 10882418x9.5 +34 w/ 235/40 nankangs. Very minimal rubbing in the front under full lock. Natural camber in the rear and about -2 in front on the camber plates.
Dang, sorry for that crap picture. Tapatalk mucked it up
tire size
what tire size? Boofneenee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-21-2015 11:40 AM
Tire size help sharris721 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-19-2014 12:03 AM
Appropriate tire size for 250-350 whp Tiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-12-2013 02:40 PM
Tire Size help! J-Money Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-04-2013 12:04 PM
Tire/Wheel or auto shop recommendation in Seattle area please. mugen79 Northwest 6 12-04-2012 12:13 PM
