Old 12-22-2015, 02:14 PM   #1
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Unfriendly Garage's Turbo BRZ #UGBRZ
Hi all. Thanks for taking a look.
Sweet track day shots from my Indianapolis friends #gripjunkies
As I brought her home: Stock 2013 BRZ Limited. CBS
Fall 2016.
last year iteration:
So the heart of this build is Driven Fabrication's Borg Warner EFR turbo kit. http://www.driven-fabrication.com/co...-efr-turbo-kit My car was the guinea pig for this kit. Love it and making plenty of reliable power.
Modification list:
Engine
-Built motor by Moto-East
-CP 10:1 pistons
-Carrillo rods
-GSC valvetrain and springs
-ported heads, OE case havles, original crank, OE bearings
-Reimax oil pump fam
-RacerXfab oil pan
-MY17 intake manifold
-Grams 72mm throttle body
-Velox rail covers
-Velox AOS
-Raceseng REVO pulley set
-Fluidampr harmonic dampener
-Velox rear cam plate for AOS return
-Velox block window cover
-HKS serpntine belt.
Turbo
-Driven Fab EFR turbo kit
-Borg Warner IWG 6758
-Turbosmart twin port IWG actuator
-Turbosmart Kompact PlumbBack recirculation valve valve
-Driven Fab custom FMIC
-Driven Fab front crash bar/FMIC mount
-Driven Fab charge pipes and intake
-Driven Fab EL 316L Sch10 turbo manifold w/ 316L exhaust flanges and V-bands
-Driven Fab 304 SS 3"downpipe
-K&N filter
-Driven Fab dual catch can kit (sold)
-Driven Fab coolant reservoir (removed)
Tuning
-Dynosty Tuning
-Motec M150
-Omni 3bar MAP sensor
-AEM failsafe tied to EBCS
-Tucktech AEM Failsafe/EBCS harness.
-MotoEast FF kit and FPR
-Ecutek. E85 and 93 maps
-Delicious Tuning (previous build)
Suspension
-Ohlins R&T 6k/6k
-Whiteline subframe inserts
-Whiteline differential solid mounts
-Whiteline transmission cradle insert
-Perrin engine mounts
-Velox LCA
-Velox tie rods
-RacerXfab trail arms
-Eibach 25/19mm sway bars
-FT86SF strut bar
-FT86SF strut supports
-SPC camber bolts (removed)
-Eiback Sportlines. (sold)
-Raceseng Cascams (sold)
Brakes
-STILLEN AP-Racing front and rear BBKs 4pot/4pot
-2-piece rotors 328x28 and 328x25
-StopTech SS brake lines
-Mintex pads
-Radium master cylinder brace
-STi Brembos (sold)
-DBA 4000 rotors F/R (sold)
-Hawk HPS 5.0 pads all around (sold)
-Carbotech XP10 all around (sold)
Transmission and running gear
-ACT SB7-XTSS clutch (345tq rated)
-Velox billet clutch fork and pivot
-12lb lightweight flywheel
-MTEC shifter springs
-MTEC clutch line
-Whiteline insert
-Energy shifter bushing
-BPS short throw shifter
-Raceseng Ashiko heavy knob
-DriveshaftShop aluminum one piece drive shaft.
-M85 Lexus IS300 rear pumpkin (3.73 Torsen)
-Amsoil 75w90 Severe Gear
-DriveshaftShop 600hp axles
-Spare AZ6 6MT as a backup. Possible straight cut gear box.
-ACT SB7-HDSS clutch (270tq rated) (spun it in a week, sold it)
Exhaust
-Driven Fab 316L SS Equal length IWG undivided turbo manifold with 1.5” sch10 primaries wrapped in DEI Titanium
-Driven Fab 3” downpipe wrapped in DEI Titanium
-Driven Fab 3” overpipe wrapped in DEI Titanium
-JDL 3” front pipe (unresonated) Ceramic coated
-GReddy 3” single Revolution cat back
-Invidia N1 Ti (sold)
-Invidia resonated front pipe (sold)
-Invidia overpipe(sold)
Wheels
TRACK -WedsSport TC105N 17x9+35 Powdercoated Spanish Gold at Killer Koatings
SUMMER STREET -Work CR2P 18x9+47 R disc / 18x10+50 A disc. Broze disc, polished barrel.
WINTER -Stock OEM on 215 Blizzaks Powdercoated Candy Copper at Killer Koatings.
-extra set of TPMS sensors
-ATEQ Quickset TPMS tool
-2 sets of Muteki lugs
-Drag DR31 (broken CR Kai rep junk)
Tires
TRACK -Toyo Proxes R888R 255/40r17
SUMMER STREET -Sumitomo HTR ZIII 295/30r18 265/35r18
WINTER -Bridgestone Blizzak WS80 215/45r17
Aero/exterior
-DrivewayLabs type3 rear diffuser
-DrivewayLabs side splitters
-STi front lip
-VIS SS carbon fibre ducktail trunk
-Fisik carbon fibre rear window louvers
-TOMS red tail lights
-Valenti 4th brake light
-JDM clear side markers
-Upgraded LED boomerang drivers
-DIY blacked out OE BRZ headlights
-Reverse camera
-Velox exhaust hole carbon fibre cover driverside only
-Grimmspeed hood struts
-Diode Dynamics Always-On module
-Opticoat Pro ceramic paint coating
-TYC/Collins tail lights (sold)
-redded stock tails (given away)
-APR carbon front splitter (removed)
-AeroJacket carbon fibre ducktail trunk (sold)
Interior
-JPM Coachworks Alcantara visors
-JPM Coachworks Alcantara knee pads
-JPM Coachworks Alcantara speaker grill covers
-JPM Coachworks Alcantara one piece dash
-JPM Coachworks Alcantara gauge hood
-JPM Coachworks Alcantara shifter boot
-JPM Coachworks Alcantara e-brake boot
-Eric Lehr’s Alcantara A-pillars
-Eric Lehr’s Alcantara center console wrap
-Eric Lehr’s Alcantara arm rests
-Eric Lehr’s Alcantara door sills
-Real4 Alcantara octagon steering wheel
-complete JDM black bits
-Carsmo center arm rest
-Weathertech floor mats
-Diode Dynamics interior white LED kit
-Mountek magnetic phone mount
-STi heated seat switch plate
-STi JDM push button start
Gauges/monitoring
-AEM Failsafe UEGO wideband/vacuum boost 52mm
-3d printed 52mm vent ring.
-Tanabe oil pressure 52mm
-Tanabe oil temperature 52mm
-Tanabe Vacuum/Boost 52mm
-Block8head triple pod
-Block8head dual pod (sold)
-VDO analog boost gauge (0-15psi) in a Cravenspeed pod. (sold)
Fuel
-Moto-East Flexfuel kit
-custom clock mount ethanol display http://www.ft86club.com/forums/showthread.php?t=102830
-DeatschWerks DW300c fuel pump
-DeatschWerks DW700cc port injectors
-Radium fuel rails
-MotoEast Surgetank
-Braille battery
Oil
-Setrab 25row oil cooler
-MoCal thermostatic sandwich plate.
-KN oil filter
-Blitz sandwich plate
-Accusump with electronic valve
-Reimax oil pump
-Setrab 9 row oil cooler (removed)
-TRD sandwich plate for temp/pressure sensors. (removed)
Cooling
-Mishimoto Radiator
-Mishimoto aluminum fan shroud
-Mishimoto dual 12" slims
-Mustache delete
-MPH carbon fiber hood with reverse scoop and NACA ducts (first one ever made haha)
-DIY vented BRZ fender vents
-Mishimoto racing thermostat (only used during hot summer months)
Fluids
-Amsoil 5W30 "Signature Series" full synthetic.
-Amsoil 75w90 manual transmission oil
-Amsoil 75w90 Severe Gear differential gear oil
-Motul RBF600 brake fluid
-Subaru super blue coolant
Turbo build pics:
I ran across the typical timing cover leak. Rolled it back to the dealership before I voided the warantee, they fixed it for free!
Back to the manifold... Full Argon purge. Full penetration GTAW welding.
Last shot stock BRZ headlights before I split them and upgraded the LED drivers.
Making some progress with the crash bar.
Wrapping up some exhaust parts.
Had to.
Odds and ends
Charge pipes
TuckTech failsafe harness
TuckTech Jacob after I paid him for his harness
Powder coating Cold side components
Buttoning things up
AND DONE!
More pics and info to come....
-Sam
xkalelx is offline   Reply With Quote
The Following 2 Users Say Thank You to xkalelx For This Useful Post:
Lonewolf (12-22-2015), SkAsphalt (09-20-2016)
Old 12-22-2015, 02:14 PM   #2
xkalelx
xkalelx's Avatar
reserved
Old 12-22-2015, 02:15 PM   #3
xkalelx
xkalelx's Avatar
reserved 2
Old 12-22-2015, 02:24 PM   #4
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Any of the build? Custom turbo kit? Give us moarrrr
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
xkalelx (12-22-2015)
Old 12-22-2015, 03:41 PM   #5
xkalelx
xkalelx's Avatar
Just threw a ton of pics up. More to come when I get some time. Thanks for looking!
Old 12-22-2015, 03:41 PM   #6
JazzleSAURUS
I REALLY like that intercooler. Beaut.
Any pics of it all together, hood up?
Old 12-22-2015, 03:49 PM   #7
xkalelx
xkalelx's Avatar
Incoming! @JazzleSAURUS
Old 12-31-2015, 10:31 AM   #8
JazzleSAURUS
Nicely done. Needs a lightweight battery, black out the intercooler, and a trimmed stock engine cover to be perfect :P
The cold side turbo silicone coupler appears to be stressed, is that just the picture? Any plans for thermal management on the hot side of the turbo itself?
xkalelx (01-02-2016)
Old 12-31-2015, 11:03 AM   #9
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Nice build!
Cockatoo is offline   Reply With Quote
The Following User Says Thank You to Cockatoo For This Useful Post:
Old 01-02-2016, 01:08 AM   #10
xkalelx
xkalelx's Avatar
@JazzleSAURUS Im throwing this EFR specific Thermal Zero blanket on tomorrow along with a new ACT clutch. I had an overheat event on the highway a couple weeks when I walked a new BMW M4 on a 40-140 pull. Oil temps were 220 before the pull and 250 after, coolant was 250 as well. cruised around for another 20 minutes to cool everything down. Plans are to trim the mustache to allow better airflow.
Heres a thread I started for the blanket: http://www.ft86club.com/forums/showthread.php?p=2467660
[IMG][/IMG]
Old 03-03-2016, 06:27 PM   #11
xkalelx
xkalelx's Avatar
Tuning is complete. Hal at Dynosty is the man! This is putting down really respectable numbers. Way more than I was expecting looking at similar kits. See the 93 dyno chart and the e85 chart below. I have 3 maps setup currently.
Map 1: 315whp on 93 @8psi.
Map 2: 325whp on e85 @8psi.
Map 3: 378whp on e85 @12psi
Old 09-20-2016, 01:19 PM   #12
DerHauptDigga
DerHauptDigga's Avatar
Drives: 2016 FRS
Well well well... look what we have here. This looks familiar.
2016 Ablaze FRS
Build Thread: http://www.ft86club.com/forums/showthread.php?t=101985
Immer Not geil.
DerHauptDigga is offline   Reply With Quote
The Following User Says Thank You to DerHauptDigga For This Useful Post:
xkalelx (09-21-2016)
Old 09-20-2016, 03:05 PM   #13
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Oh hey there..
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
Old 09-21-2016, 09:31 AM   #14
xkalelx
xkalelx's Avatar
Hi Guys!
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 08:33 PM
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 03:41 PM
Bren5279's Full turbo partout (JDL uel turbo, Greddy Evo 3, AEM gauges, + More) VA bren5279 Engine, Exhaust, Bolt-Ons 69 06-29-2015 11:56 PM
Garage fr-s oaroyale Scion FR-S / Toyota 86 GT86 General Forum 0 01-07-2013 06:38 PM
