Old 01-19-2016, 05:56 PM   #1
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
Quick minor spacer question
For my street set I'm running the standard wheels, i have a separate set for autocross/track so this is for street consideration only. What spacing can i run with the oem wheels, lugs, and studs without having problems? I'm talking just a little spacing like 3-10mm only.
Would your answer change if I had Muteki SR48 lug nuts instead of the Oem lugs?
Keenercarguy is offline   Reply With Quote
Old 01-19-2016, 06:01 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
3MM MAX is all I would run on OEM studs.... even then I wouldn't feel safe
Edit: do it right get extended studs
Old 01-19-2016, 06:28 PM   #3
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I hear people who run 15mm in fronts and 20mm in back to fill up the fender walls better. I sure hope they run adapters because I could not stand running more than a 5mm on these studs... In all honesty our oem studs suck so freaking bad... I've broken off 3 and have others that want to break again.
Instagram: trevor.parque
Old 01-19-2016, 07:07 PM   #4
renfield90
The Stig's German cousin
I ran 3mm once and it was a little sketchy.
The stock studs suck anyway, if you change wheels with any frequency you WILL cross thread them eventually.
Spacer question for OEM wheels Mrqb22 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-26-2016 05:25 PM
H&R DRS Spacer (3025560) Stud installation question Dihudaxia Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-19-2015 09:16 PM
Quick Question BRZUK Scion FR-S / Toyota 86 GT86 General Forum 11 11-07-2014 10:48 PM
Spacer question Midnight Dream 86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 01-26-2014 09:37 PM
Wheel spacer question, please help AceNiNe Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 11-23-2013 03:52 AM
