Old 05-28-2013, 11:57 PM   #1
Mrqb22
Drives: 2013 FR-S Whiteout
Spacer question for OEM wheels
I have been debating on what wheels to go with and everytime I think I find what I want to pull the trigger on something else comes out that catches my eye.
I think I may go with something in the XXR line but just cant decide which one however I know I love the + 35 off set from the photos I have seen.
I do not know much about spacers and all that stuff etc.
So I was wondering if someone could point me in the right direction on what spacers to get for the OEM wheels to make them more like a + 35 Off set. I think I read that factory is +48 I could be wrong.
But anyways in the mean time I was going to throw the spacers on in an attempt to get the look of the +35 offset on the OEM wheels until I decide which wheels I want to get. Again my knowledge is limited in this area so I am hoping you guys can help me. Also if spacers are going to effect the way the car is going to ride in a negative way I dont want to do that either.
I have the pro kit from Eibach but dont want to install it until I have my new wheels and tires and do it all at once.
I figure I could use the OEM as my Winter set up and the new ones for the nice months.
So basically bottom line question is what size spacers I need. What goes into having them installed and what tire to get to fill up that gap with the fender on the stock suspension.
Again I keep over the wheels I so crazy I cant decide if I should go with the 17 instead of 18 I saw a car with 17 xxr lowered and it looked great with the pro kit. so I dont know lol
So please bare with me guys and help me out here with the best spacer and fatter tires to fill up that gap on the stock suspension until I pull the trigger on my new set up.
Thanks
Dan
2013 Whiteout
2013 XB black pearl.
Mrqb22 is offline   Reply With Quote
Old 05-29-2013, 12:02 AM   #2
Drftfan
Drives: Argento FR-S
Get a 10 to 15mm spacer. Done.
Do the 15 in the rear. That's what she said
Drftfan is offline   Reply With Quote
The Following 3 Users Say Thank You to Drftfan For This Useful Post:
dori. (05-29-2013), ohmikegoodness (10-02-2019), suaveflooder (05-29-2013)
Old 05-29-2013, 01:16 AM   #3
Mrqb22
Got it. Are some brands better than other I am sure?
Can you let me know what best brand maybe post link to where I can get them at. I will need custom lugs I am assuming with spacers?
Also what about the tire size to fill up the fender on stock suspension
thanks for the response
Dan
2013 Whiteout
Old 05-29-2013, 09:18 AM   #4
Drftfan
Dan I will be honest. It may not be worth it at the end of the day once you start spending the money. H&r spacers are great but aren't cheap. You will need longer wheel studs if they do not come with them.
Old 06-06-2013, 12:13 PM   #5
lsr78
Drives: 2013 Scion FR-S MT Ultramarine
H&R come with the bolts.
Perrin Non Res Cat Back/CAI/Inlet/Tranny Mount/Shifter Bushing
Enkei PF01
18x7.5 et38/Conti DW 225/40/Eibach Pro-Kit
H&R spacers 15mm rear/5mm front/Whiteline PSK/ECUTek Tune
Alpine IND-S920HD/MRX-V70/CDT HD-62/JL StealthBox/Bel RX65/JPM Coachworks interior bits
lsr78 is offline   Reply With Quote
Old 06-06-2013, 12:24 PM   #6
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
This sticky has everything you need to know about what size spacers you need to get depending on how much suck/poke you want or if you want it perfectly flush given the size wheels you're planning on running:
http://www.ft86club.com/forums/showthread.php?t=7535
A little bit more clarification on how to read the chart, with the OEM wheels which are 17x7 +48 and a 1" drop, you need front spacers of 25mm in the front and 35mm in the rear to achieve perfect flushness.
Ideally, you get the perfect sized wheel with lower offsets and you won't need to run spacers. Spacers aren't necessarily unsafe, but they're essentially some extra parts in your car you don't need unless you need extra clearance for BBKs and want to go wider for track purposes (I don't track my car - I just want to look of flushness). You just need to think about spacers more and check/retorque them as necessary - so there's a bit of maintenance involved.
Personally, I went with H&R spacers (20mm in front and 30mm for the rear) on 18x7.5 +48 square wheels. I went with the "best" spacers according to others I spoke to - H&R, but other brands include Eibach, Project Ks, Ichiba... I wanted the extra assurance that the spacers wouldn't fail on me while I was driving, knowing I will be extra anal about trying to torque everything to spec to ensure the wheels/spacers don't fly off.
mit_peid is offline   Reply With Quote
The Following User Says Thank You to mit_peid For This Useful Post:
firemedic1428 (01-29-2016)
Old 06-06-2013, 12:25 PM   #7
jack43
jack43's Avatar
Drives: Sterling Silver BRZ Limited MT
I went with H&R and the longer studs. Here's 5mm front and 15mm rear, with lowering springs (sorry I don't have a better pic).
jack43 is offline   Reply With Quote
Old 06-06-2013, 12:51 PM   #8
mit_peid
Boosted Noob
mit_peid's Avatar
H&R 20mm F and 30mm R spacers
Here are some of my photos after the install of the H&R spacers. I have yet to lower the car on my Eibach Pro-Kits (~1" drop) yet cause I'm trying to do them at the same time as my Koni inserts.
Old 06-06-2013, 12:54 PM   #9
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
i ran 20 and 25mm spacers on my oem wheels. fitment was perfect even at stock height.
The Following User Says Thank You to spitfire481 For This Useful Post:
DAEMANO (03-02-2014)
Old 06-06-2013, 01:50 PM   #10
mit_peid
Boosted Noob
mit_peid's Avatar
That's interesting, I noticed that you swapped your BRZ side decals for the FRS ones. Did you just swap with a FRS of the same color?
Old 06-06-2013, 02:42 PM   #11
jack43
jack43's Avatar
Yes, plus I just swapped the spoiler away too.
Call it my FR-S makeover.
Old 03-01-2014, 09:20 PM   #12
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
thread revival blah blah
Can anyone link me to some 8mm spacers in this style please? I just wasted 15 mins of my life looking for some with no luck
Old 06-10-2014, 10:58 PM   #13
Sookainian
Sookainian's Avatar
Drives: Toyota GT86
Will this spacer fit the stock 17" rims ?
Anyidea does the stock 17" rims have the "pocket" for the nut sit in ?
Sookainian is offline   Reply With Quote
Old 06-10-2014, 11:10 PM   #14
gramicci101
Off Topic
The OEM wheels do have spaces in the back. I have Corner3Garage 20/25mm spacers, they fit the OEM wheels with no problem.
25mm conversion spacer with 5mm spacer = safe or unsafe? deedz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2013 11:59 AM
Wheels and tires Question flameSniper Southern California 9 12-20-2012 02:07 AM
Question: how to ship wheels? Cornell89 Wheels and Tires 3 08-16-2012 08:56 AM
N00b Question: what do you do with the OEM wheels, should you get aftermarkets? G4mb17 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 06-16-2012 05:01 AM
Wheels Question Tsinoy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 01-19-2012 01:45 AM
