Old 11-22-2013, 11:24 PM   #1
AceNiNe
AceNiNe's Avatar
Drives: Scion FRS Raven Black 6MT
Wheel spacer question, please help
I've been looking for 8mm spacers for the front, as well as 14mm spacers for the rear. I'd really hate to make a mistake so it would be much appreciated if a few things could be specified.
Looking currently at these pages for the spacers
http://www.frsport.com/index.php?tar...=&q=8mm+spacer
As far as i know there's nothing wrong with these which are 5x100 with 57.1 bore, which i think is all that's needed? Should i go somewhere else to look?
It also mentions this:
"DR Series spacers fit between the wheel and hub, and require longer wheel bolts (ordered separately). Please verify bolt specifics before ordering (taper or round bolt head and shaft length)."
I would hate to get the wrong bolt type, between tapered and round bolted... Definitely need help specifying on that one
If anyone has any other type of spacers or places to look for spacers that would be appreciated too.
Thanks again.
AceNiNe is offline   Reply With Quote
Old 11-23-2013, 03:52 AM   #2
Scibaru
Drives: Raven, blacked out everything.
Spacers
I have 25 mm spacers from ebay or Amazon on the back.They have studs built in so you don't need to change the studs. They push the oem wheels and tires to a pretty much flush fitment. I have 20 mm in front but don't recommend them because the bolts on the spacers rub slightly on the back of the wheels and it's very difficult to remove the wheels. I've read that others have used 25mm in front with no problem. They weight about lbs each, but I haven't noticed any difference in mpg.
Scibaru is offline   Reply With Quote
Wheel Spacer Size?? tonytduc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 52 11-03-2018 03:36 AM
Spacer question for OEM wheels Mrqb22 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-26-2016 05:25 PM
Wheel Spacer tonytduc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-06-2013 01:44 AM
wheel spacer to 5x114 derka-derka AUSTRALIA 12 07-02-2012 11:27 PM
