Old 01-19-2016, 01:17 AM   #1
jake2357
Drives: Scion FR-S
HELP PLEASE: Had to replace wheel bearing three times in last week.
So I got into a crash about two weeks ago. I hydro-planed on the highway and hit the wall, damage on the car has been fixed and drove all the way from Dallas to San Antonio for College and the car seemed fine the whole time but when I got there my front left tire was making a sort of pulsing squeaking noise so I took it into the break shop in town and they said it was the wheel bearing. So they changed it out and I drove it and I sounded fine until I drove for about 30 minutes and it was making an even worse noise. They ended up replacing it two more times and it has happened again and again. This last time they even ordered the orignal part from toyota and the it's still starting to go bad AGAIN!!! any ideas on what it could be!! they claim that there isnt and warping or anything that could be screwing it up and that its just the part but its been 3 times now!! PLEASE HELP!!! ANY IDEAS!!
jake2357 is offline   Reply With Quote
Old 01-19-2016, 01:27 AM   #2
Their claim is wrong. Something is bent, twisted, warped or otherwise misshapen. Exactly what is can not be diagnosed over the Internet. Take it to another shop and have them check it out.
humfrz (01-19-2016), swarb (01-21-2016)
Old 01-19-2016, 01:35 AM   #3
jake2357
Drives: Scion FR-S
Ok thanks.
Old 01-19-2016, 01:42 AM   #4
Originally Posted by jake2357 View Post
Ok thanks.
Sorry can't tell you more but there are probably a dozen things it could be.
Old 01-19-2016, 04:51 PM   #5
fr_s
fr_s's Avatar
Drives: '13 FR-S WHITEOUT
Did you get an alignment?
Sent from my SM-G900V using Tapatalk
\\ 3" Perrin RCBE [] Radium MCB [] SuperTek Intake Tube [] AFE DIF [] Kartboy Crank Pulley [] BRZ Swift Springs [] OFT //
fr_s is offline   Reply With Quote
Old 01-20-2016, 09:44 PM   #6
jake2357
Drives: Scion FR-S
yep they did a good job
Old 01-21-2016, 01:26 AM   #7
humfrz
Did the first shop replace the whole hub .... ??
humfrz
Old 01-21-2016, 01:49 AM   #8
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Fine, ill be that guy.
If the problem keeps persisting, or gets worse. They did not do a good job. They probably have no idea whats wrong. Take it to a different shop.
The Following User Says Thank You to cdrazic93 For This Useful Post:
Packofcrows (01-21-2016)
Old 01-21-2016, 04:42 AM   #9
Hey! I was already that guy. Now you are that other guy.
humfrz (01-21-2016)
Old 01-21-2016, 03:10 PM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
If they did indeed change out the wheel hub and you are having issues still, you need to replace the entire spindle assembly.
-alex
bearing, problem, trouble
Front wheel bearing endless_pain Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 12-13-2016 06:06 AM
Wheel bearing? Nylander Issues | Warranty | Recalls / TSB 20 06-08-2015 04:57 PM
Ask a guy who showers 3-4 times a week anything dragonboy221 Off-Topic Lounge [WARNING: NO POLITICS] 103 02-15-2015 07:35 PM
Wheel bearing gone at 1,500k!? Muskokan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 10-02-2014 03:58 PM
Blown wheel bearing =( silverbullet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 01-23-2013 10:34 PM
