Old 08-28-2018, 01:16 PM   #113
churchx
churchx's Avatar
Drives: 2014 GT86
I'm just thinking, if these cannot be used together with eg. velox's backing plates (basic kit, w/o inlets & hoses) connecting via some hose? As in - what diameter outlet of rooducts is and to where it points?
Old 08-28-2018, 01:21 PM   #114
Icecreamtruk
Drives: Track preped NA FRS
I have some sort of abomination mix between APR and Velox kit for my brake cooling. It is totally possible to have something patched up together to get the air where you want it, from where you want it. Using duct-tape to in increase the outer diameter of a hose to make it fit tight inside a bigger one is suprinsingly sturdy (as are zip-ties).
Old 08-28-2018, 11:26 PM   #115
Gearhead1
Drives: 2013 BRZ automatic
RooDucts
Sorry I do not have a photo of them installed. You can go to rooducts.com and see a picture of one installed. Although it's not a BRZ, it's very similar.
But from these pics of mine on the bench (sorry I couldn't figure out how to get them right side up), I think you'll get the idea. The inlet is on the underside of the LCA with the output nozzle wrapping up and around the backside of the LCA and pointed at the hat area of the rotor. The output nozzle has to be tucked in tight to the LCA so it doesn't interfere with the tie rod at full lock--that's the reason for the trapezoidal shape.
Circumference of the output nozzle is about 7"--maybe equal to a 2 1/4" round hose.
Like Icecreamtruk, I don't see why you wouldn't be able to connect them to a hose but you should check with Randy at RooDucts.
Gearhead1 is offline   Reply With Quote
Old 08-28-2018, 11:28 PM   #116
randyzimmer
Drives: 2 Subaru Wagons
The duct outlet has a hard time fitting in the space between all the linkages and the tire. The reasoning is that the duct causes the air inside the wheel to "churn" and doesn't just stay stagnant, ever increasing in temperature. Gearhead's data and results show that, for whatever reason, they work.
https://i1.wp.com/rooducts.com/wp-co...00%2C225&ssl=1
https://i1.wp.com/rooducts.com/wp-co...91%2C300&ssl=1
https://i0.wp.com/rooducts.com/wp-co...00%2C295&ssl=1
https://i0.wp.com/rooducts.com/wp-co...00%2C146&ssl=1
randyzimmer is offline   Reply With Quote
TF Brake Duct Cooling Kit Touge Factory Tracking / Autocross / HPDE / Drifting 77 06-11-2015 07:01 AM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
APR Performance FRS/BRZ Brake Cooling Kit vividracing Brakes, Suspension, Chassis 0 08-08-2013 04:03 PM
TF Brake Duct Cooling Kit Touge Factory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 02-19-2013 06:04 PM
Brake cooling duct kit tranzformer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-14-2011 01:37 PM
