12-25-2014, 12:00 AM | #99 | |
Drives: 2015 Fr-s Firestorm
12-25-2014, 12:28 AM | #100 |
Drives: 2014 Subaru BRZ
Back on topic though, what offset and backspacing would you need to run on the bunny with a 1" drop via v3's to get then 17x12 to fit under the ass w/ 315x35's w/o issues and not a lot of camber (some is acceptable but do not want a whole shit ton) also what about the fronts with a 17x10 and 275's w/ no camber or is that even possible?
01-14-2015, 05:07 PM | #101 |
Drives: frs or brz
9.5 et -5/-20 work with the v2 fenders?
01-21-2015, 11:09 PM | #102 |
Drives: ek ctr scion fr-s
anyone tried 18x12 +20 offset in the rear? im getting this type of wheels but i dont know if gonna work i have coilovers, anyone can help me?
01-21-2015, 11:43 PM | #103 | |
Drives: Raven FRS
I'm running 18x10.5 plus 22 offset on Ksport coils pretty close to all the way down and 2 1/2 inch conversion spacers if this helps. |
01-21-2015, 11:45 PM | #104 |
Drives: Raven FRS
Your going to have to do a lot of cutting to the rear bumper piece just so you know
01-22-2015, 12:20 AM | #105 | |
01-22-2015, 12:21 AM | #106 |
01-22-2015, 01:03 AM | #107 | |
Drives: Raven FRS
I'm not sure what spacer size you'll need. But consider this your wheels are 1 1/2 inches wider than mine I'm using a 2 1/2 inch spacer to be flush with the fender The camber I have is only from the coilover drop So in your set up I would look into a 1 inch spacer but you also have to consider the offset of your wheels as well |
01-22-2015, 01:40 AM | #108 | |
Drives: Raven FRS
To fit the wheels flush with the fender you'll need to cut this part of the kit or it will rub. |
02-04-2015, 02:05 PM | #109 | |
Drives: Frs s13 s14
what tire size are you running? |
02-04-2015, 09:24 PM | #110 |
Drives: Raven FRS
245/35 all around
02-25-2015, 12:35 PM | #111 |
Are you 20/20?
Drives: Hopes and dreams
Do you guys think I can get away with not having LCA's in the rear, and just going with camber bolts? Or is that not enough adjustability?
I'll be at 18x10.5 -12 (+25mm spacers) in the rear. Probably 285 or 295 section tires. Thanks!
02-25-2015, 07:08 PM | #112 |
Drives: Raven FRS
I'm on coils in the rear with stock LCA 18x10.5 with a plus 22 and much bigger spacers than 25mm. It's fits fine after some trimming
Similar Threads | ||||
Replica rocket bunny | crildz | Cosmetic Modification (Interior/Exterior/Lighting) | 103 | 05-09-2014 04:35 PM |
Rocket Bunny FRS in Dubai | TAP Auto Parts | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 49 | 12-04-2012 01:39 PM |
Red Rocket Bunny FR-S - Speedhunters | RaceR | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 5 | 10-12-2012 12:48 AM |
Rocket Bunny or Modelista? HELP!!! | ShowstoppersUSA | Cosmetic Modification (Interior/Exterior/Lighting) | 21 | 08-16-2012 01:23 PM |
GReddy/Rocket Bunny Wheels? | Coultergeist | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 08-15-2012 02:39 AM |
