Old 12-25-2014, 12:00 AM   #99
sdwagonjp
sdwagonjp's Avatar
Drives: 2015 Fr-s Firestorm
Originally Posted by jay1989 View Post
Avant Garde f100 and f200 series. They even come in -80 to +80 offsets and 5x100. And you can get the inner peice in pretty much whatever color you want. From time you order till they are delivered is about 6 to 8 weeks as they are made to order.
They are also a 3 piece wheel which turns a lot of people off but I personally prefer a 3 piece as they are lighter and can get them generally in whatever configuration you want.
Retail is pricey as shit but I found a super hookup on them through a buddy of mine so makes them "more" affordable but still pretty pricey.
Edit: just checked can get it all the way up to a 17x15 if you wanted lol
ccw does 17x16.5
sdwagonjp is offline   Reply With Quote
Old 12-25-2014, 12:28 AM   #100
jay1989
Drives: 2014 Subaru BRZ
Back on topic though, what offset and backspacing would you need to run on the bunny with a 1" drop via v3's to get then 17x12 to fit under the ass w/ 315x35's w/o issues and not a lot of camber (some is acceptable but do not want a whole shit ton) also what about the fronts with a 17x10 and 275's w/ no camber or is that even possible?
jay1989 is offline   Reply With Quote
Old 01-14-2015, 05:07 PM   #101
crildz
Drives: frs or brz
9.5 et -5/-20 work with the v2 fenders?
crildz is offline   Reply With Quote
Old 01-21-2015, 11:09 PM   #102
mikesagas
Drives: ek ctr scion fr-s
anyone tried 18x12 +20 offset in the rear? im getting this type of wheels but i dont know if gonna work i have coilovers, anyone can help me?
mikesagas is offline   Reply With Quote
Old 01-21-2015, 11:43 PM   #103
Kwise1
Kwise1's Avatar
Drives: Raven FRS
I'm running 18x10.5 plus 22 offset on Ksport coils pretty close to all the way down and 2 1/2 inch conversion spacers if this helps.
Kwise1 is offline   Reply With Quote
Old 01-21-2015, 11:45 PM   #104
Kwise1
Kwise1's Avatar
Drives: Raven FRS
Your going to have to do a lot of cutting to the rear bumper piece just so you know
Old 01-22-2015, 12:20 AM   #105
mikesagas
Attachment 101011
thanks!! i thinking about getting these wheels with a 1.5 spacer? can make it with that size?
Old 01-22-2015, 12:21 AM   #106
mikesagas
cutting? not only the cutting for the rocket bunny wide body? explain please... and thanks!
Old 01-22-2015, 01:03 AM   #107
Kwise1
Kwise1's Avatar
Drives: Raven FRS
I'm not sure what spacer size you'll need.
But consider this your wheels are 1 1/2 inches wider than mine
I'm using a 2 1/2 inch spacer to be flush with the fender
The camber I have is only from the coilover drop
So in your set up I would look into a 1 inch spacer but you also have to consider the offset of your wheels as well
Old 01-22-2015, 01:40 AM   #108
Kwise1
Kwise1's Avatar
Drives: Raven FRS
To fit the wheels flush with the fender you'll need to cut this part of the kit or it will rub.
Old 02-04-2015, 02:05 PM   #109
Cxlumpy
Drives: Frs s13 s14
Attachment 101011
what tire size are you running?
Cxlumpy is offline   Reply With Quote
Old 02-04-2015, 09:24 PM   #110
Kwise1
Kwise1's Avatar
Drives: Raven FRS
245/35 all around
Old 02-25-2015, 12:35 PM   #111
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Do you guys think I can get away with not having LCA's in the rear, and just going with camber bolts? Or is that not enough adjustability?
I'll be at 18x10.5 -12 (+25mm spacers) in the rear. Probably 285 or 295 section tires.
Thanks!
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 02-25-2015, 07:08 PM   #112
Kwise1
Kwise1's Avatar
Drives: Raven FRS
I'm on coils in the rear with stock LCA 18x10.5 with a plus 22 and much bigger spacers than 25mm. It's fits fine after some trimming
Replica rocket bunny crildz Cosmetic Modification (Interior/Exterior/Lighting) 103 05-09-2014 04:35 PM
Rocket Bunny FRS in Dubai TAP Auto Parts FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 49 12-04-2012 01:39 PM
Red Rocket Bunny FR-S - Speedhunters RaceR FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 10-12-2012 12:48 AM
Rocket Bunny or Modelista? HELP!!! ShowstoppersUSA Cosmetic Modification (Interior/Exterior/Lighting) 21 08-16-2012 01:23 PM
GReddy/Rocket Bunny Wheels? Coultergeist Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 08-15-2012 02:39 AM
