Drives: Rocket Bunny FR-S
Wheel specs for Rocket Bunny Fenders
Anyone know what wheel sizing for 18's would fit the rocket bunny fenders and clear BBK? Any help would be appreciated
Just go with Forgestars! They'll custom make the offset to exactly your specs, or if you want them to do the work and choose the right offsets, you can do that as well, that's not a problem, but with these new Super Deep Concave Forgestars, you'll want to get a set of 10"s on the back to really show off some concave wheels:
![]() ![]() ![]() Take a look at my thread if you like, it'll have all the options on there, and more pictures: ModBargains.com | Forgestar Wheels for your BRZ/FRS - Rotary Forged/Customize Yours!! PM/Email or call me up for any additional info - 714.582.3330 ext 8002 - ask for Jurrian! |
Drives: FR-S, NA8, S13
kei runs 10.5 -20 bbs'.
dont know if its a square setup or not though. |
Drives: A Hot Mess
right now my set up is as follows:
19x9.5 -7 with a 235/35/19 19x10 -19 with a 245/35/19 tire and a 25mm spacer effective -44 offset i am having issues with clearance of the actual radius of the fender in the front.. working on solving issue post sema.
one of the first people to ruin the frs.
I Love your GUCCI Wheels!
holy shit, are you serious? dude, that widebody kit is no joke.
![]() @jinxyboi | @_iLLdynasty Rice for the Rice God |
Drives: A Hot Mess
#9 | |
Drives: pinto power
based on what it looks like here..
#10 |
Drives: bicycle
Would anyone know the 'perfect' (relative) size for a 17" staggered setup on the rocket bunny kit? Thanks in advance.
#11 |
Drives: 2013 FRS Whiteout
Would these work? 18x9.5 +2 /18x11 -5
#12 |
Drives: 2013 Toyota 86
so any news? cause im having the same issue right now with forgestar f14s 19x9.5 front
#13 |
Drives: Argento FRS
Reggie has staggered Meister's on his Rocket Bunny kit.
18x9.5 -25 in the front, and 18x10.5 -40 in the rear. 245/35's all around.
ig: @potatoglasses // @toastedbiscuits |
#14 |
Drives: 2013 Rocketbunny GT86
So I just wanted to remove my old post and give everyone a more accurate size chart for the rocket bunny and wheel specs.
I am not responsible if you mess something up, I am only providing knowledge, not advice. Please PM me any corrections. Front Honestly a 9.5 width is the best upfront. You really need an effective offset of either -5 or 0 it all depends on tire size to prevent rubbing. a tire size such as 245 35 18, (with a 35 sidewall will be ok with a -5) however running a 225 40 18 (40 sidewall) will require at least a 0 offset. My current setup is 18x9.5 with a Effective offset of 0 running a 225 40 18 tire. Rear you can run anything from a 9.5-11+ in the rear. The best offset for a 9.5 is a Effective offset -40 the rear is a bit harder to do math on but look at it this way; for every inch more than 9 it ads half an inch from the center (imagining the front) so a 18x10.5 rear will require a Effective offset will require a -25mm-30mm offset to run a fat tire a 9.5 requires a -40 offset but you need a slight stretch. If you cant afford expensive wheels, Effective offsets can be obtained with spacers. For example, if you have a 18x9.5 +20 and you need a 0 offset, adding a 20mm spacer will zero out the offset giving you an effective offset of zero. if you have a 18x9.5 +10 and you need a effective offset of -30, you will need a 40mm spacer. Last edited by Maverick22; 04-15-2014 at 07:02 PM. |
| Replica rocket bunny | crildz | Cosmetic Modification (Interior/Exterior/Lighting) | 103 | 05-09-2014 04:35 PM |
| Rocket Bunny FRS in Dubai | TAP Auto Parts | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 49 | 12-04-2012 01:39 PM |
| Red Rocket Bunny FR-S - Speedhunters | RaceR | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 5 | 10-12-2012 12:48 AM |
| Rocket Bunny or Modelista? HELP!!! | ShowstoppersUSA | Cosmetic Modification (Interior/Exterior/Lighting) | 21 | 08-16-2012 01:23 PM |
| GReddy/Rocket Bunny Wheels? | Coultergeist | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 08-15-2012 02:39 AM |
