#85 | ||
Drives: 2013 Asphalt 6spd
#86 |
Drives: MY15 86 GTS
Ok. I guess in Australia we call it a PCB (printed circuit board). Haven't heard CCA before.
I did design it. Had a small run made and assembled myself. For me this type of thing is pretty straight forward. The downside of this circuit is that it isn't very accurate (time wise). But for this purpose that doesn't matter and the robustness is more critical. Sent from my GT-I9100T using Tapatalk |
#87 |
Drives: MY15 86 GTS
Happy to sell some in kit or assembled. Think I have 30ish left.
#88 | |
Drives: 2014 BRZ Ltd - DGM
Anything more than the absolute bare minimum transportation that can get you to work is a bad use of your money but nobody here bought a FRS/BRZ because it was a good investment.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car E46 323ci vert |
#89 |
StreetKart
Drives: 2014 Scion FR-S Monogram
so, where can we buy this... this lazy ass american is tired of holding down buttons
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
#90 | |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
Again, I now it's me over thinking it. It just seems ridiculous to me to do this to save a couple of seconds when you get in your car. I guess if you get a sense of accomplishment out if it then that's all that matter. Out of 86,400 seconds in a day you saved 2-3.
#91 | |
Drives: 2014 FR-S 6MT Whiteout
#92 |
NW Region Moderator
Drives: FR-S No More
@mig86, you aren't the first to do this... hehe, but I will roll this topic into the others.
I did this 2+ years ago, then @2superblus refined my circuit, and now you have yet another way. Combined with the other topic.
| The Following User Says Thank You to DarrenDriven For This Useful Post: | 2superblus (08-27-2014) |
#93 | |
Drives: 2014 BR"ZED" Sport-tech DGM MT
#94 |
Drives: 2013 GBS BRZ Limited
Buy a beetle microcontroller for $7 and skip the PCB design.
#95 | |
first off, wow that was confusing (refering to the merging of the two threads.. now my earler post has a link to the same thread that it's in)
I would think it is still accurate to +/(-) 5% depending on component tolerance, but you are right about the robustness/reliability. I have had the thought that the TDR-M module I am using will go bad at some point, but your design looks like it will run 30+ years with no problems.
#96 |
I only wish i knew what that was. VW?
#97 | |
I would love the ability to keep traction control off at all times until i enable it. |
#98 |
http://www.dfrobot.com/wiki/index.ph...2#Example_Code
It is an arduino based microcontroller . a USB cable and you can program the io pins to do anything you want. For this application it would be 1 pin and 5 lines of code. |
| brake override DOES NOT diminish heel & toe | 4agze | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 09-17-2012 05:43 AM |
| Permanent Optimum opti-coat 2.0 ?? | Ericfrs | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 4 | 09-04-2012 03:11 AM |
| LF: rear fog switch picture | Silverdub | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 06-28-2012 09:34 AM |
| Anyone going to switch badges? | DougieFresh | Scion FR-S / Toyota 86 GT86 General Forum | 60 | 09-28-2011 03:56 AM |
| Brake override system in the FT-86? | mrKiKaZ | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 02-22-2010 12:33 PM |
