Old 08-26-2014, 06:08 PM   #71
mig86
Drives: MY15 86 GTS
Traction OFF Switch (Automatically)
Hey All,
After getting sick of holding down the traction button for 3 sec each time I get into the car, I installed a latching switch on the dash (see images below).
When switched on, it will turn off TRC and VSC when the car is started.
Initially I hooked this straight into the existing circuit, but the ECU is a little too clever for this.
When you go over a certain speed and have the button 'jammed' on, it detects a switch failure and turns all features back on.
To overcome this issue, I have re-used a circuit I designed for a seat belt warning light in ICV's.
Now the line is held low for approx 7sec.
The illuminated 'Halo' is connected to the interior illumination rheostat circuit, so it dims with the other functions.
I plan to get a small laser etched switch plate surround with words like 'TRACK MODE'
If there is any interested in the parts or instructions to hook up - let me know.
-Mig
mig86 is offline   Reply With Quote
The Following User Says Thank You to mig86 For This Useful Post:
Manic (08-27-2014)
Old 08-26-2014, 06:17 PM   #72
vroom4
What would you charge for a plug and play kit? I dont want it off all the time, just want to be able to 'flip a switch' and have it auto-off on every car start until i flip the switch back (aka for the entire weekend of autox so I dont forget half the time).
vroom4 is offline   Reply With Quote
Old 08-26-2014, 06:21 PM   #73
DC2R
Drives: 2014 Scion FR-S
This is great! How much? Lol
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 08-26-2014, 06:40 PM   #74
DriftHappens
Drives: '14 FRS White
interested!
DriftHappens is offline   Reply With Quote
Old 08-26-2014, 07:02 PM   #75
Pabloc
Drives: BRZ Ltd WRB, MT6; '91 M5; '89 911
Interest here, too -
Pabloc is offline   Reply With Quote
Old 08-26-2014, 07:53 PM   #76
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
looks really clean, did you have a batch of cca blanks made up? It doesn't look very complicated, I don't see any timer chips or relays, how does it disengage?
fwiw, I went this way: http://www.ft86club.com/forums/showthread.php?t=10621
also this being the diy section, I think there would be a lot of interest in more detailed instructions.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 08-26-2014, 10:27 PM   #77
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Not trying to thrash on your idea here, but seriously people, it's 3 seconds. With all the time and effort involved to make this a functional kit, even if it took only 5 minutes to install and only cost $30 for the kit, depending on how much you make an hour, you could do the 3 second feature over 1000 times before you would see a return on your "investment".
Dustin is offline   Reply With Quote
Old 08-26-2014, 10:39 PM   #78
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Your funny man.... hope to see you again next year. Did you fix your A/C yet?
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 08-26-2014, 10:47 PM   #79
Dustin
Twin Screw You
Dustin's Avatar
No, I have a lot of credit card debt out I need to get caught up on before I spend any more money on my car, including fixing the AC. Luckily I have my Tacoma that is my daily so it not a necessity to fix the AC on my car.
The Following User Says Thank You to Dustin For This Useful Post:
zoth (08-26-2014)
Old 08-26-2014, 10:49 PM   #80
mig86
Drives: MY15 86 GTS
Dustin,
First up, each to their own.
For me, I really dislike the monetary valuation of everything.
I actually make quite a bit per hour at work, as an engineer for an Japanese car OEM.
But I also do all my own car mods, lawn mowing, cooking etc.
Offcourse I could pay someone to do it for less than the time 'costs' me, but that’s not the point.
I also do work for others getting the ECU's etc. working in their project cars.
Things like reverse engineering the security system etc.
I do charge, but nowhere near what I should. Why? Because I enjoy it, I like the challenge and I like working on interesting problems. It's entirely different to working as part of a corporation.
If everything in the world was developed only on the parameters you gave, it would be a very bland place.
As for the 3sec. Shure not a long time. But if you are tracking the car and forget to do it, or stall and restart etc. it could be a pain in the arse when you hook into a corner and the fun police takes over.
-Mig
The Following 3 Users Say Thank You to mig86 For This Useful Post:
Akari (08-27-2014), Namuna (08-27-2014), Travisty75 (01-01-2017)
Old 08-26-2014, 11:11 PM   #81
Dustin
Twin Screw You
Dustin's Avatar
Originally Posted by mig86 View Post
Dustin,
-Mig
It had nothing to do with a monetary value being put on anything. We're talking about saving time because that's what this is supposed to do, help save time. I'm talking about the amount of time to install it plus the amount of time someone would have to work to make the money to pay for this. After all time involved, even if someone makes say $30 an hour to pay for this kit which for arguments sake lets say cost $30. That's 1 hour of labor to pay for this kit. 60 minutes into seconds = 3600 seconds. Each time to turn off the TC system take approximately 3 second so 3600/3 and you get 1200. That's 1200 times you could push the button before you would actually "save" that time. That doesn't include the install time. Like I said before, even if it was a 5 minute install, 5 minutes x 60 seconds is 300 seconds. 300/3 = 100 more times to hold down the traction control button before you would "save" the time involved.
each to their own.
I know I'm probably over thinking it way too much but it all goes back to, it's only 3 seconds. And if you're at the track and you spin out or stall, well that run/pass/lap is ruined anyways so you should have plenty of time to hold down that button for 3 seconds again.
Old 08-26-2014, 11:19 PM   #82
mig86
Drives: MY15 86 GTS
Thats how it works. You depress the round button and it will turn off the TRC / VSC each time you start the car.
If you want it off, just release the switch (Which will stop it doing it next time you start) and if you want to change the state you just use the normal button.
Plug and play is tricky, not worth tracking down the plugs for a handfull of units.
I spliced this in (no need to cut anything). If there is interest I might put together a kit with all the fly leads soldered in ready for splicing.
Old 08-26-2014, 11:22 PM   #83
mig86
Drives: MY15 86 GTS
Whats a CCA Blank?
The circuit intentonaly doesn't use any digital chips (like 555 timers).
These are susecptable to nosie and can flase trigger in this type of circuit.
For simplicity it's just an R/C timer triggering a FET.
The other transistors are there to discharge the system quickly when the ignition is switched off. This was originaly for seatbelt warning light which are required when registering a home made car in Australia.
Old 08-26-2014, 11:31 PM   #84
mig86
Drives: MY15 86 GTS
I think when you equate time to money, that's what you're doing.
I don't have an innate capitalist view of the world. Not all time = $'s.
If that were true the Arts would be in trouble!
brake override DOES NOT diminish heel & toe 4agze Scion FR-S / Toyota 86 GT86 General Forum 31 09-17-2012 04:43 AM
Permanent Optimum opti-coat 2.0 ?? Ericfrs Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 09-04-2012 02:11 AM
LF: rear fog switch picture Silverdub Scion FR-S / Toyota 86 GT86 General Forum 6 06-28-2012 08:34 AM
Anyone going to switch badges? DougieFresh Scion FR-S / Toyota 86 GT86 General Forum 60 09-28-2011 02:56 AM
Brake override system in the FT-86? mrKiKaZ Scion FR-S / Toyota 86 GT86 General Forum 10 02-22-2010 11:33 AM
