go_a_way1
Old 12-13-2012, 02:42 PM   #589
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Originally Posted by jsooke View Post
Tried a set of 235/50/18 (from the Forester). They will rub at both right and left lock on inner fenders. Ohh well, need to buy more wheels and tires.
Jay
Yeah that's some tall rubber. Just put some 1" spacers on the top hats and make it a rally car!
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 12-13-2012, 09:07 PM   #590
Sac-BRZ
Drives: BRZ Limited AT
Originally Posted by clevrname View Post
I've got a 255 now, the wheel lip slightly pokes out from the tire. I hate it.
Did you get new tires for the rear yet? I'm like you, all the pictures I see on 9.5's...255 is too much of a stretch for my taste.
Sac-BRZ is offline   Reply With Quote
Old 12-14-2012, 12:31 AM   #591
NOBROWS
NOBROWS's Avatar
Drives: 2013 FIRESTORM FRS
18x9.5 +34 ?
18x9.5 + 34 , all the way around anybody got that setup?
2013 Firestorm Red FR-S
1993 Honda civic track car
Motivate 2 Hate Motorsports
NOBROWS is offline   Reply With Quote
Old 12-14-2012, 12:51 AM   #592
gabeg86
gabeg86's Avatar
Drives: 2013 Raven FR-S
there are a few 18x9.5 +38 floating around on the forums. 4mm difference in poke isn't gonna make too much difference. less than 1/6th of an inch, but the front will poke a bit. rear should be fine
gabeg86 is offline   Reply With Quote
The Following User Says Thank You to gabeg86 For This Useful Post:
dori. (12-16-2012)
Old 12-14-2012, 09:38 AM   #593
i_4got
i_4got's Avatar
Drives: Whiteout FR-S
Found these for my stock tires: http://www.fastwheels.ca/component/p...art/Itemid,62/
I was thinking of getting the 17x7.0 since that's the perfect fit for our tires. But how can I judge what offset will fit? I know that if you don't get a high enough offset, your wheels may not clear your brakes (or something like that). Would a +35 offset be safe enough?
i_4got is offline   Reply With Quote
Old 12-14-2012, 01:03 PM   #594
jchall30
Drives: 2014 Whiteout Monogram FRS
New wheels!!
I am about to order new wheels for my FR-S. I am going with one of the Five Axis models. Either the R5-F or the R7-F. These come in 19's only. I could also get the S5-F which comes in either 18 or 19. Is there an advantage to either size? I am new to the whole aftermarket wheel scene so I am just tying to make a good choice between these. Thanks in advance.
JC
jchall30 is offline   Reply With Quote
Old 12-14-2012, 01:31 PM   #595
2point0
2point0's Avatar
17x7 or 17x8 will be no big deal for the stock tires. The stock wheels are +48mm offset, so using +35 means the wheels is pushed outwards 13mm. You should have no issues with either 7" or 8" widths. If you go 8" wide, you aren't stuck getting new skinny tires when the stockers wear out.
Old 12-14-2012, 01:52 PM   #596
i_4got
i_4got's Avatar
Oh? I thought a smaller positive offset meant the center was deeper. Did I have that backwards?
Edit: I'm guessing if I want a more concave look, I should go with +42 offset? Will that clear?
Old 12-14-2012, 01:57 PM   #597
2point0
2point0's Avatar
That's sort of correct. The center really stays where it is (the hub) and the rest of the wheel goes outward with lower offset.
Offset is just the distance between the mounting face of the wheel and the imaginary centerline of the width. So yes, a lower offset pushes the mounting face closer to the centerline. But when mounted on the car, it means the outside wheel lip will be sticking out farther than a higher offset.
Spoke design will play a part in brake clearance as well. Some wheels are made differently for different offsets (lower offset looks more concave) while others just have a thicker or thinner mounting pad and the spokes stay the same.
Old 12-14-2012, 02:08 PM   #598
karma003
auto-crosser/drifter
karma003's Avatar
Drives: 2013 scion FR-S black M/T
JC
19's r heavyer, tires might cost a good amount more for being low profile, & depending on the thickness ur mpgs gonna drop. Either way, its.gonna drop just cuz its heavyer alone.
karma003 is offline   Reply With Quote
Old 12-14-2012, 02:14 PM   #599
jchall30
Thanks for the response. I drive mostly on the interstate so milage might not drop to much. I get about 34 mpg now. Weight isn't to big a deal for me as I don't drive very aggressively at all. I know it will have some effect though but will it be that noticeable with just everyday driving?
JC
Old 12-14-2012, 02:37 PM   #600
mugen79
mugen79's Avatar
Drives: Ultramarine FRS(MT), IS350(sold)
Bigger wheels are obviously heavier. Heavier objects are harder to rotate which means reduced throttle response, and also it is a more burden to brakes. Also I think you lose some of the agility of this car.
I know it is just a marketing scheme but according to Enkei website; "Every pound of unsprung weight savings has the effect of reducing overall vehicle weight by 20lbs."
(http://www.enkei.com/rpf1.shtml)
(And by the way, I didn't buy Enkei wheels so I am not trying to sell anything)
Plus this is just my personal opinion but 19s look too big for this car.
mugen79 is offline   Reply With Quote
The Following User Says Thank You to mugen79 For This Useful Post:
karma003 (12-14-2012)
Old 12-14-2012, 02:39 PM   #601
karma003
karma003's Avatar
JC
As far as just normal driving I dont think its have too much of an effect. Might make u feelba bit more slugish since its +2" bigger a diameter. Idk
Old 12-14-2012, 02:40 PM   #602
jchall30
Would the 18's be better? The S5-F comes in a 18.
JC
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
