Old 08-09-2014, 10:38 PM   #43
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by moojpg2 View Post
Just received my dss carbon drive shaft. Hope I don't have issues with it.
Rotate to find the sweet spot, if you can't find it send it back to be balanced. Their customer service is pretty good.
Freeman is offline   Reply With Quote
Old 08-09-2014, 10:38 PM   #44
moojpg2
Drives:
Will do. It doesn't seem like they had to use much weight to balance it so I'm hopeful
moojpg2 is offline   Reply With Quote
Old 08-13-2014, 05:25 AM   #45
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Quick question,
Do you HAVE TO remove the front pipe?
Carlitoz3 is offline   Reply With Quote
Old 08-13-2014, 06:45 AM   #46
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Carlitoz3 View Post
Quick question,
To do what? You have to remove the front pipe to remove the front pipe. You don't have to remove the front pipe to install a new drive shaft. You don't have to remove the spare wheel either.
[ame="http://www.youtube.com/watch?v=Y-BnxIL4jA0#t=667"]FT-86 SpeedFactory DriveShaft Shop Carbon Driveshaft Install - DIY - FRS / BRZ - YouTube[/ame]
Old 08-13-2014, 01:47 PM   #47
Carlitoz3
Carlitoz3's Avatar
To put in the shaft xD
Thanks.
Old 08-13-2014, 02:34 PM   #48
Squishy
Drives: 2013 WRB BRZ
I installed my driveshaft without any removal of other parts save the old driveshaft and its mount.
Second place is just the first place loser.
Dale Earnhardt
Squishy is offline   Reply With Quote
Old 09-18-2014, 04:58 PM   #49
TStafford
TStafford's Avatar
Drives: 2015 FR-S Ultramarine Metallic
When rotating the drive shaft are you pulling it from the trans and rotating while also keeping track of the diff position? Couldn't you just rotate on the diff end or is the trans end more important?
TStafford is offline   Reply With Quote
Old 09-18-2014, 10:46 PM   #50
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
You rotate on diff end, the front stays into the Tranny sleeve.
Mark your original position, shift 90 degrees and so on..
The Following User Says Thank You to OICU812 For This Useful Post:
FT86Z (04-10-2019)
rattle and vibration when braking? dokterdewe Issues | Warranty | Recalls / TSB 19 09-01-2019 09:44 AM
2600rpm vibration stueck9356 Issues | Warranty | Recalls / TSB 3 03-06-2014 01:06 PM
Speaker Vibration JayNutter Electronics | Audio | NAV | Infotainment 12 07-31-2013 01:24 AM
Droning/vibration at and around 3k rpms.. _F-R-S_ Issues | Warranty | Recalls / TSB 5 01-11-2013 04:24 AM
vibration after spring install? sajonf Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-30-2012 03:30 PM
