Old 03-01-2014, 10:06 PM   #1
stueck9356
Drives: 2015 VW GTI SE
2600rpm vibration
I finished installing all of the mods in my signature. I had to pull the transmission to fix a screw-up with the mtec springs, and I put it all back together and everything works just fine.
Except at about 2600rpm, there is a vibration coming from somewhere in the powertrain. It does not happen when in neutral and revving the engine, only under load. It is more pronounced when moving through the RPMs rather than holding it at 2600rpm. The car works 100% otherwise, I even marked the rear diff/driveshaft so I could put it back on the same way it came off. I am not sure if this is a byproduct of the whiteline/perrin bushings or I just need to double check everything. Thoughts?
stueck9356 is offline   Reply With Quote
Old 03-01-2014, 10:22 PM   #2
JOSEC
Drives: 2014 Subaru BRZ WRB
It might be because of the transmission bushing and the rear shifter bushing. There's less slack resulting in more NVH. Other than that it's completely normal.
JOSEC is offline   Reply With Quote
Old 03-06-2014, 01:48 AM   #3
mnsayer
mnsayer's Avatar
Drives: LexusGS,Lotus Exige S240,LexusLX570
Im having the exact same problem did you find out what the problem is?
mnsayer is offline   Reply With Quote
Old 03-06-2014, 12:06 PM   #4
stueck9356
I am going to remove the rear shifter bushing and transmission mount bushing this weekend. I don't really like the added NVH and am going to see if they caused it.
Anyone notice vibration from headliner? BRZnut Issues | Warranty | Recalls / TSB 22 01-16-2018 09:11 PM
Speaker Vibration JayNutter Electronics | Audio | NAV | Infotainment 12 07-31-2013 12:24 AM
Reverse lockout vibration SubaSteve Issues | Warranty | Recalls / TSB 4 03-23-2013 01:26 PM
Door Speaker Vibration MattM232 Issues | Warranty | Recalls / TSB 16 03-19-2013 07:03 PM
vibration after spring install? sajonf Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-30-2012 02:30 PM
