Old 12-18-2012, 09:42 PM   #1
_F-R-S_
Drives: 13 whiteout scion frs
Droning/vibration at and around 3k rpms..
Having some wierd droning noise like a virbation noise when about to hit 3k rpms.. It then goes away when i hit 3k rpms and let off the gas.. Any ideas?!
_F-R-S_ is offline   Reply With Quote
Old 01-10-2013, 06:21 PM   #2
ghitz247
Drives: frs
Same here any update?mine it at tho
ghitz247 is offline   Reply With Quote
Old 01-10-2013, 07:17 PM   #3
developer
Drives: BRZ Limited
The black plastic shield on the bottom of the car can vibrate, there are a few bolts that people add a couple of washers to that snugs the fit and prevents vibration. There have been several threads about it. Give it a search.
developer is offline   Reply With Quote
Old 01-11-2013, 01:27 AM   #4
ghitz247
Drives: frs
oh ok thanks
Old 01-11-2013, 01:30 AM   #5
ghitz247
Drives: frs
so i guess its nothing that bad like a bad transmission or anything like that huh?
Old 01-11-2013, 03:24 AM   #6
developer
Drives: BRZ Limited
Probably not, putting the washers in only took me a few minutes. Try it and see if it fixes the problem. The other common sources of vibrations is the back deck, there is a TSB (technical service bulletin) for that problem. There have been some cars that didn't have enough fluid in the differential that caused vibrations at different speeds. If the problem will happen in neutral have someone put there hand on the plastic shield on the bottom of the car and see if the problem goes away. Good luck!
Rattling in 2nd or 3rd at low rpms BigFatFlip Engine, Exhaust, Transmission 54 09-07-2015 08:54 PM
FRS door speaker vibration? hislargeness Electronics | Audio | NAV | Infotainment 12 08-19-2013 05:22 PM
vibration after spring install? sajonf Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-30-2012 02:30 PM
Where are your RPMS Dragon86 CANADA 13 07-26-2012 10:43 AM
RPMS!! Spencer Strayer Engine, Exhaust, Transmission 82 09-15-2011 09:51 AM
