Old 08-30-2012, 12:19 PM   #1
sajonf
Drives: 13 Scion FR-S, 12 Camaro ZL1
vibration after spring install?
I recently installed the Eibach ProKit and now have a slight vibration at the rear of the car above 55mph. It didn't exist before the springs were installed and I had an alignment done the day after putting them on. It isn't terrible but definitely noticeable.
Has anyone else experienced this after installing lowering springs?
I also have aftermarket wheels and tires so I intend to put the stock set back on and see if it still vibrates. I guess it is possible to have coincidentally lost a wheel weight at the same time. I haven't had them checked for balance yet -I figured I would try the stock wheels first and if it still has the problem I could eliminate wheel balancing as the issue.
Any input would be appreciated.
sajonf is offline   Reply With Quote
Old 08-30-2012, 01:32 PM   #2
d1ck
Drives: Black 2013 FRS
Check your wheels to see if there is a spot where the used to be a weight. They use stick on weights so there would probably be some glue left behind or maybe a clean spot in the shape of a square.
d1ck is offline   Reply With Quote
Old 08-30-2012, 01:39 PM   #3
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
~60mph is often a wheel balance issue. I am running sportlines and don't have that vibration.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-30-2012, 01:48 PM   #4
sajonf
Thats what i was thinking too, a high speed vibration is usually a wheel balance issue. I should be able to identify that (or rule it out) by switching back to the stock wheels this weekend.
Old 08-30-2012, 02:10 PM   #5
gmookher
make sure you got your lugs torqued down bro
gmookher is offline   Reply With Quote
Old 08-30-2012, 02:30 PM   #6
sajonf
yup they are 85 lb/ft
Eibach Sportline Spring review Dave-ROR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 07-24-2019 06:23 PM
Actual Spring difference BRZ vs FRS Motopythons Suspension | Chassis | Brakes -- Sponsored by 949 Racing 66 05-13-2015 10:12 PM
Spring Rate Calculator yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-28-2012 11:31 AM
Lowest quality spring? Synack Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 07-26-2012 12:00 PM
FR-S to be priced at $22k and coming in Spring of 2012? vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 92 10-25-2011 09:06 PM
