Old 04-29-2016, 09:34 PM   #43
Trac Toy
Trac Toy's Avatar
I had contacted Cyrius Garage a couple months ago and will be getting a 4.88 installed sometime this year. Same rough quote $500 for the gearset and solid pinion spacer. $86/hr... plus probably some additional cost for shims and such...
Just gotta not be working 7 days a week 13 hour days to be able to get the car down to him.
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
Old 06-10-2016, 04:25 PM   #44
tdotBRZ
tdotBRZ's Avatar
Drives: 2014 BRZ Limited SWP 6MT
Originally Posted by Mr.Impreza View Post
Am I smelling a possible group buy/group install haha
Originally Posted by scottman View Post
I'll join group buy, but we probably need like at least 10 people for any discount. :p
Originally Posted by congee View Post
So umm, does any of you have a telephone line that can call long distance to the states?!?! If no groupbuy, maybe we can save on shipping?!!?
In for group buy on a 4.88 FD gear set
Originally Posted by WRBrzRX View Post
sorry to thread hijack guy but I'd do a 4.88 group buy as well
Originally Posted by orangespark View Post
In for group buy on a 4.88 FD gear set as well.
Seems like we have 5 people at the moment.
Originally Posted by TRAKRAVN View Post
I called Pat this morning to ask about setting up a group buy for you guys. He said 4-5 people would be enough. If you're interested give him a call at 905-403-9888 you can ask for Dan (Pat's brother) or Pat. Tell them you talked to Paul so they know what to put your order for a group buy.
Originally Posted by sixthree View Post
In for groupbuy!
So roughly $1200 all together at pat cyr before groupbuy rate. I'm waiting for a quote from my mechanic, might be able to get a cheaper labor rate. Apparently he has a connection for final drives but not sure if they have 4.88 available.
Originally Posted by Wayno View Post
In for 4.88 GB.
Originally Posted by cool7 View Post
Interested in 4.88 GB as well.
Originally Posted by Walla Walla View Post
interested in 4.88 GB!
Anyone here end up getting those group buy prices all in with shims and install for Weir 4.88FD yet? Would be very interested if price is right
tdotBRZ is offline   Reply With Quote
Old 06-12-2016, 08:15 AM   #45
TRAKRAVN
Drives: 2015 Scion FRS - Raven
Pat is installing my stuff June 20th. Might be too late for me.
TRAKRAVN is offline   Reply With Quote
Old 06-20-2016, 08:31 PM   #46
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
It's taken 2 months but I've finally got my FD from Weir. I ordered everything sans bearings.
Old 06-24-2016, 10:57 AM   #47
TRAKRAVN
So I've gotten the car back with the 5.29 gears. Please keep in mind at the time of install the gears, MFactory 1.5way LSD and AL driveshaft were installed along with the Whiteline bushing inserts for the diff and subframe.
All parts were installed at Cyrious Garage and Pat double checked everything to ensure it was ready for track use.
The drives differently, I don't think it's actually any faster then before but boy is it different. The car accelerates very smoothly now and you can pull though each gear very quickly. I would say now it's a 3rd to 4th car instead of a 2nd to 3rd car. First gear is reserved now for burnouts, tractor pulls, donuts and stump pulling. It's now also almost impossible to stall the car. The car does 115kph at 4000rpm now on the highway.
The driveshaft does have a bit of a whine which only seems to be apparent between 80-90kph, I don't know if it hits a sweet spot of resonance but it's not very noticeable at any other speed.
The diff has transformed the car into something I've never experienced before. Controlling a slide is a lot easier now then before. It does make some clicking and clacking noises with sounds like something is bouncing around in the trunk. Corner exit is a lot different then before. I haven't had much time to play with it to give a proper review.
I will be heading to Shannonville tomorrow to give it a proper break-in and review. If anyone has some time tomorrow come out and see it for yourself.
Old 06-24-2016, 11:07 AM   #48
tdotBRZ
tdotBRZ's Avatar
Are you at shanny in the morning tomorrow? If not you should be :p I'm there with brzworld tomorrow 9am-5pm, we'll have around 20 FRS/BRZ's, would love to see your car in action with that aggressive final drive
Old 06-25-2016, 10:07 PM   #49
TRAKRAVN
Driving the Shannonville this morning AC on (no recirc) windows down going 115kph at 4000rpm yielded 7.5L/100km. I measured this by reesting the odometer and having a full tank near my house and filling the car before entering the track and checking the output of the pump. Not relying on the cars computer.
My stock tires are basically finished and we couldn't get any comparable runs to our times from last year. So I still don't know if the car is faster then stock.
It was my first attempt at drag racing a RWD car today and My best was 16.0 @ 145kph according the the SoloDL.
On the road course the car has a lot more rear grip. The car was understeering at corner entry and over steering at corner exit. Coupled with the toasted tires and my neglect to adjust pressures maybe this can be resolved with some new rubber and attention to pressures.
Old 06-25-2016, 11:03 PM   #50
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Damn, 5.29 is absolutely bananas
Sent from my ONEPLUS A3000 using Tapatalk
drewbot is offline   Reply With Quote
Old 06-25-2016, 11:06 PM   #51
TRAKRAVN
You're not too far you can try it out if you want.
Old 06-26-2016, 01:56 AM   #52
ysu
Drives: Toyota 86 GTS Auto
I'd be interested in a 4.88 goup buy, too.
ysu is offline   Reply With Quote
Old 06-26-2016, 02:45 AM   #53
Impureclient
Drives: 2015 FR-S
Also in for a group buy if that happens.
Impureclient is offline   Reply With Quote
Old 06-26-2016, 06:18 AM   #54
TRAKRAVN
Oil and coolant temps on the highway were 185F for each after 45mins of constant cruising so I doubt other then the extra rpm there is probably very little extra wear on the motor.
(I have an oil cooler and koyo rad)
Old 07-06-2016, 01:01 PM   #55
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I ordered a 5.29 for my car from Pat Cyr at Cyrious Garageworks. He does the install as well and has a 4.88 in his car if you want to see what it feels like.
5.29? Is it auto or manual? How you liking it?
SUB-FT86 is offline   Reply With Quote
Old 07-07-2016, 01:59 PM   #56
TRAKRAVN
Car is a manual, I don't drive it much but it takes some getting used to the 4000rpm cruising on the highway. The car "feels" great, though the jury is still out for me if the car is faster or not.
Final drive tcroft91 Engine, Exhaust, Transmission 19 02-08-2016 11:09 AM
Final Drive: 4.56 vs. 4.88 mcbrawr Engine, Exhaust, Transmission 43 12-26-2015 07:23 PM
Final Drive 4.67 Bongertz Engine, Exhaust, Transmission 33 09-02-2015 03:11 PM
3.3 Final drive? Manji Engine, Exhaust, Transmission 18 01-01-2015 02:51 PM
The Marginal FR-S Final Review | Part 3 Dezoris Scion FR-S / Toyota 86 GT86 General Forum 49 08-14-2013 05:43 PM
