Old 02-06-2016, 04:29 PM   #1
tcroft91
tcroft91's Avatar
Drives: 2013 Scion FRS
Final drive
Has anyone have any experience with the final drive from mfactory 4.67 was it worth it
Sent from my SM-N910P using Tapatalk
tcroft91 is offline   Reply With Quote
Old 02-06-2016, 05:46 PM   #2
swarb
The Following 2 Users Say Thank You to swarb For This Useful Post:
go_a_way1 (02-06-2016), Teseo (03-18-2024)
Old 02-06-2016, 06:34 PM   #3
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I don't have it but it's worth it.
The Following 3 Users Say Thank You to chaoskaze For This Useful Post:
Carlitoz3 (02-07-2016), skinnybehr (02-07-2016), tcroft91 (02-06-2016)
Old 02-07-2016, 02:43 AM   #4
humfrz
For example:
http://www.ft86club.com/forums/showthread.php?t=70664
Is it worth it ....??
I reckon that depends on what you want your car to do different ......
humfrz
new2subaru (02-07-2016)
Old 02-07-2016, 01:21 PM   #5
mrk1
Drives: Sterling BRZ Ltd
How do you use your car and is it manual or auto?
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
tcroft91 (02-07-2016)
Old 02-07-2016, 01:23 PM   #6
tcroft91
tcroft91's Avatar
I daily drive an its manual looking for some more bottom end in it
Old 02-07-2016, 01:35 PM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
More bottom end .. if NA, in addition to FD upgrade i'd look also into Crawford BPBs. They move main torque/powerband in lower rpm-s ..
The Following User Says Thank You to churchx For This Useful Post:
Teseo (03-18-2024)
Old 02-07-2016, 01:46 PM   #8
tcroft91
tcroft91's Avatar
Ive have seen them do they work as described on the website
Old 02-07-2016, 02:00 PM   #9
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Here's my thread on FD swaps, I used the 4.56 FD swap from weir performance and I believe it's less expensive than the mfactory. The main thing is to find a reputable shop to do it for you honestly
http://www.ft86club.com/forums/showthread.php?t=92972
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
The Following 3 Users Say Thank You to Aztec For This Useful Post:
FRS Justin (02-07-2016), tcroft91 (02-07-2016), Teseo (03-18-2024)
Old 02-07-2016, 07:20 PM   #10
FRS Justin
Drives: 2013 Asphalt FRS
I've had 3 different final drive setups in my car. 2 rules that I follow are:
1 Only let a qualified shop do the install, it's not for the beginner mechanic don't skimp on this or you will have a noisy or short lived diff.
2 Use a quality fluid in your diff.
The only 2 shops I trust to setup my diff are Spencer Fabrication in NH and Weir performance in CA I have had flawless work done from both companies. Both offer the same parts and options. DO THE UPGRADES IF YOU DRIVE HARD!!!!!
A 4:56 ratio would be the way to go with a manual daily driver
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following 2 Users Say Thank You to FRS Justin For This Useful Post:
FRSBRZGT86FAN (02-07-2016), tcroft91 (02-07-2016)
Old 02-07-2016, 09:24 PM   #11
tcroft91
tcroft91's Avatar
Did it help out alot with bottom end power
Old 02-07-2016, 09:45 PM   #12
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Is it on there website? They only list supra stuff on there or celica stuff
Old 02-07-2016, 10:06 PM   #13
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
I didn't see it either I guess I'll have to call.
Carlitoz3 is offline   Reply With Quote
Old 02-07-2016, 10:18 PM   #14
FRSBRZGT86FAN
My assumption was that you needed a M98 or M85 diff to swap in the correct gears turns out you dont need to do that anymore?
4.8 final drive drift86 Engine, Exhaust, Transmission 29 11-28-2022 12:49 PM
Final Drive: 4.56 vs. 4.88 mcbrawr Engine, Exhaust, Transmission 43 12-26-2015 07:23 PM
WTB: 4.56 Final Drive jaorocks1 Want-To-Buy Requests 0 11-04-2015 07:36 PM
Final Drive 4.67 Bongertz Engine, Exhaust, Transmission 33 09-02-2015 03:11 PM
3.3 Final drive? Manji Engine, Exhaust, Transmission 18 01-01-2015 02:51 PM
