Old 03-30-2016, 11:24 AM   #29
congee
congee's Avatar
Drives: SSM BRZ
Originally Posted by orangespark View Post
In for group buy on a 4.88 FD gear set as well.
Seems like we have 5 people at the moment.
Originally Posted by TRAKRAVN View Post
I called Pat this morning to ask about setting up a group buy for you guys. He said 4-5 people would be enough. If you're interested give him a call at 905-403-9888 you can ask for Dan (Pat's brother) or Pat. Tell them you talked to Paul so they know what to put your order for a group buy.
Thanks!
I sent him an email and got a quick response today. $550.00 for the gears, solid pinion spacer kit, pinion seal, fluid and shipping/duty. 6.5 hrs to install, $86/hr rate. Sent him an email about the groupbuy rate. Wonder how much it will be.
congee is offline   Reply With Quote
The Following User Says Thank You to congee For This Useful Post:
sixthree (03-30-2016)
Old 03-30-2016, 12:07 PM   #30
sixthree
Drives: 14BRZ
In for groupbuy!
So roughly $1200 all together at pat cyr before groupbuy rate. I'm waiting for a quote from my mechanic, might be able to get a cheaper labor rate. Apparently he has a connection for final drives but not sure if they have 4.88 available.
sixthree is offline   Reply With Quote
Old 03-30-2016, 03:26 PM   #31
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by jcw99 View Post
$601 + 23 shipping via USPS to Maryland = $624
Itemized: r & p with depth shim set 268.71
stub shaft seals 20.60
pinion seal 9.80
inner pinion brg 78.79
outer """"""""""" 49.79
solid spacer kit 55.00
pinion nut 5.45
2 spec. order OEM carrier bags 113.20
total 601.34
Also, I forgot to mention that the tech I'm using, Brady Johnson @ Pure Auto. Perf., said that he likes the Weir gears because they come with a paint line on them already. Hope this helps you.
Thanks I appreciate it, it's much cheaper and better quality then everything else as all the fiddly bits are including, I still need to find an installer
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
jcw99 (03-30-2016)
Old 03-30-2016, 05:15 PM   #32
jcw99
Drives: swp mt '14 brz premium
BTW, I forgot to mention that he also includes a big long list of OEM carrier shims by size and part number so that the installer can get the shims more easily from an OEM source after he has determined what size(s?) is needed. I was going to go and buy all the shims and take them to the tech but Spence said not to do that because they're about $6 each. He's a big help to the customer and the tech.
jcw99 is offline   Reply With Quote
Old 04-07-2016, 06:48 PM   #33
Hawk77FT
Drives: GTS 86
Here are couple of pics of my diff with 4.556 final drive. I went with bigger, stronger inner and outer bearings (Supra MK3). This weekend I will try to make some time to put it in!
Hawk77FT is offline   Reply With Quote
Old 04-07-2016, 07:46 PM   #34
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Originally Posted by congee View Post
Thanks!
In for 4.88 GB.
Old 04-28-2016, 05:50 PM   #35
cool7
Drives: BRZ WRB
Interested in 4.88 GB as well.
cool7 is offline   Reply With Quote
Old 04-29-2016, 01:37 PM   #36
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
interested in 4.88 GB!
Walla Walla is offline   Reply With Quote
Old 04-29-2016, 03:08 PM   #37
phrosty
If someone made a business of shipping out pre-built pumpkins, they'd make a killing.
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
WRBrzRX (04-29-2016)
Old 04-29-2016, 03:11 PM   #38
WRBrzRX
Drives: runs&drives
I've been thinking the same lately. Or one that took in pumpkins on a trade-in and used them to build stock.
WRBrzRX is offline   Reply With Quote
Old 04-29-2016, 03:18 PM   #39
Walla Walla
Hicas Thread Basher
not sure if everyone would pay the price though
Old 04-29-2016, 04:13 PM   #40
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
DELETED, I am retard
drewbot is offline   Reply With Quote
Old 04-29-2016, 04:16 PM   #41
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
@Cole you seeing this bruv
Old 04-29-2016, 07:57 PM   #42
jcw99
That's what Spencer Fabrications does.
The Following User Says Thank You to jcw99 For This Useful Post:
phrosty (06-08-2016)
Final drive tcroft91 Engine, Exhaust, Transmission 19 02-08-2016 11:09 AM
Final Drive: 4.56 vs. 4.88 mcbrawr Engine, Exhaust, Transmission 43 12-26-2015 07:23 PM
Final Drive 4.67 Bongertz Engine, Exhaust, Transmission 33 09-02-2015 03:11 PM
3.3 Final drive? Manji Engine, Exhaust, Transmission 18 01-01-2015 02:51 PM
The Marginal FR-S Final Review | Part 3 Dezoris Scion FR-S / Toyota 86 GT86 General Forum 49 08-14-2013 05:43 PM
