Old 12-29-2014, 05:26 AM   #1
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
3.3 Final drive?
Anyone know where to find a final drive with a ratio around 3.3?
I've checked with Toyota here and they don't have an oem replacement.
The closest they had is a 3.727, which I bought. But it's still not where I want my revs to be.
Thanks
Manji is offline   Reply With Quote
Old 12-29-2014, 05:42 AM   #2
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Just short of stalling the engine in 6th or having gobs of power enough to break the transmission anyway; why?
Old 12-29-2014, 05:48 AM   #3
Manji
Manji's Avatar
Neither of those things are remotely true.
I'm not using the fa20.
Old 12-29-2014, 06:41 AM   #4
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
trying to figure out gears for a V160? ha.
98-00 SC400 or GS400, 02-05 SC430
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Old 12-29-2014, 07:06 AM   #5
SomeoneWhoIsntMe
that's for USDM vehicles at least, I have no idea if it's the same in straya. you could use toyodiy to check I suppose.
and that's a 3.266:1 FD
Old 12-29-2014, 07:10 AM   #6
Manji
Manji's Avatar
Yea thanks dude. With what you gave I was able to google some good info.
http://www.totalstreetcar.com/showth...erential-Info!
Old 12-29-2014, 12:20 PM   #7
350matt
Drives: toyota mr2/ Toyota GT86
how about an LS400 diff?
they're 3.266:1
350matt is offline   Reply With Quote
Old 12-29-2014, 05:20 PM   #8
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Good thing I was being sarcastic....but ok. So that reserves for a 2J. Have you looked at old Mk III diffs?
Old 12-29-2014, 05:28 PM   #9
Manji
Manji's Avatar
We need a sarcasm font
Old 12-30-2014, 10:42 AM   #10
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Even with the 1UZ swap, that seems like a really odd final drive choice for what I imagine you'd be doing with the car.
Any reason in particular for wanting longer gears? You can pm me if you want.
TylerLieberman is offline   Reply With Quote
Old 12-30-2014, 05:55 PM   #11
Manji
Manji's Avatar
It's not like it ruins the car. Alot of people on this forum this changing final drives increases or decreases horsepower, which is retarded.
Remember
1UZ has more than twice the torque of fa20, everywhere, including off idle.
It's usually found in cars 500kg heavier.
It won't need a typical 1st gear, one so tall that it's almost like a short second, won't bother the motor at all.
I also don't want the car to be screaming at 100km/h.
My current daily is a Audi S4. same size motor, car much heavier than gt86. At 100km/h, top gear revs 1750rpm. It holds it nicely and cruises. If I force it into 5th at the same speed, its more like 2400-2500. Its much nicer at the lower revs. So that gives me a target.
A 3.727 FD (which I have) puts my 100km/h top gear cruise at 2500rpm, which is too high.
A 3.266 FD puts my cruise at the same point more around 2150rpm.
BUT, I also don't want to move all the gearing just to drop ~300rpm at 100km/h, if it makes the car sluggish (which I still dont think it will)
I think the difference between the 3.266 and 3.727 for a V8 conversion, is like comparing a 4.1 and 4.5 with an fa20. I had my 4.5 in for a year, and yes it did rev too high at 100km/h but it was better everywhere else so I enjoyed it.
Ultimately, its another one of those things that you can sit and obsess over, but you need to try it and see how it feels .
So I'm going to try the 3.727 first, and know that there are 3.266 options out there.
Old 12-31-2014, 02:12 AM   #12
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Thanks
Close gear ratio set for the manual and a 3.727 final drive should be a great compromise. Close ratio gear set makes 1st and 2nd taller and tidy up the rest of the gears 3-6 to compliment.
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 12-31-2014, 04:49 AM   #13
Manji
Manji's Avatar
Read thread before posting,
Forum 101
Old 12-31-2014, 09:58 PM   #14
carbonBLUE
Reverse Burnouts
Forum 101
well it would be good to state that you are using a different transmission or not.
Being a **** 101
(wont forget you)
2011 Infiniti G37x
4.8 final drive drift86 Engine, Exhaust, Transmission 29 11-28-2022 12:49 PM
4.875 final drive review drift86 Engine, Exhaust, Transmission 98 02-12-2018 06:13 PM
Final Drive Discussion JimmyMac Engine, Exhaust, Transmission 118 08-07-2017 10:18 PM
Final Drive 4.67 Bongertz Engine, Exhaust, Transmission 33 09-02-2015 03:11 PM
Final Drive Calculations wootwoot Engine, Exhaust, Transmission 34 12-19-2014 04:06 AM
