Old 04-02-2014, 02:02 PM   #29
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
i will reinstalling my kartboy shifter tonight, if you need pics let me know to compare ur install ill have mine apart. dont have a cf drive shaft though, but i have pretty much everyhing else you have.
DAN_BRZ is offline   Reply With Quote
Old 04-02-2014, 02:46 PM   #30
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Yes, please. I don't think I'm going to have time to touch my car today after all.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 04-02-2014, 07:51 PM   #31
tom@kartboy
tom@kartboy's Avatar
Drives: American Made Shift!
No idea on the Perrin bushing. Tho it does look quite similar to ours...
Swap that out for our bushings and make sure that the angle of the shifter points towards the back. I ran that same setup on my BRZ before i sold the DS and had no issues.
Feel free to email me directly if you have any other questions.
tom@kartboy is offline   Reply With Quote
Old 04-02-2014, 09:16 PM   #32
Deathreaper
Drives: 2013 Scion FRS
Quick question Anthony, Did oil leak when you removed the stock DS? Also - any vibrations / resonance with the new DS? Installing the same unit in a few weeks on my car.
Deathreaper is offline   Reply With Quote
Old 04-02-2014, 11:08 PM   #33
Anthony
Weight Nazi
Anthony's Avatar
The only reason I have the Perrin one is because I bought the shifter used and it did not come with the bushing. The seller said it was too much work to remove in relation to just taking the shifter out. So then I started looking for bushings, and for whatever reason ended up with a Perrin one.
Yes, but not much. The car was perfectly level, so I lowered the front one notch on the jack stands and that stopped the leak. And no clue about the driveshaft. This problem is keeping me from driving the car for now.
Old 04-03-2014, 07:04 PM   #34
Anthony
Weight Nazi
Anthony's Avatar
I had no time to even look at the car yesterday, and today I had to cut grass. But I did have time to set it down and see if that changed anything. NOPE.
Video is uploading. It should be done in about 30 minutes.
[ame]http://youtu.be/EPKkwIzxEK4[/ame]
Old 04-03-2014, 07:38 PM   #35
Calum
That Guy
Drives: 2013 asphalt FRS MT
I just can't get past the idea that this is caused my the rear shifter stay bushing. That bushing is what locates the shifter. Using a stock shifter or any aftermarket should matter, that bushing will still set the height of the bottom of the assembly. See if there's any play in the bushing if you loosen the bolts. Or go back to the stock bushing.
Old 04-03-2014, 09:18 PM   #36
Anthony
Weight Nazi
Anthony's Avatar
Uuuuuuugggggggghhhhhhhh...
I will give that a try tomorrow. I still have the exhaust and driveshaft off, but here is what I just finished doing:
Old 04-03-2014, 09:26 PM   #37
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
@Anthony Mickey mouse that shit brother !
I love how raw your car is, props
Sent from my IBrick
Old 04-03-2014, 09:27 PM   #38
Model Citizen
Lacking brains
Drives: frz
That counts as weight reduction right?
Model Citizen is offline   Reply With Quote
Old 04-03-2014, 09:39 PM   #39
Anthony
Weight Nazi
Anthony's Avatar
Sent from my IBrick
LOL! Thanks!
GENIUS.
Didn't even realize that.
Old 04-07-2014, 12:04 PM   #40
Driveshaft Shop
Drives: 31 Ford, Viper GTS,65 Riviera,Cayen
Let me know if i can help in anyway, between the Carbon and the aluminum shafts there have been hundreds sold with out issue.
Frank
Driveshaft Shop is offline   Reply With Quote
Old 04-07-2014, 12:14 PM   #41
Anthony
Weight Nazi
Anthony's Avatar
Frank
I ground the shifter linkage down and it works just fine now. I've only driven the car about 1/2 of a mile with the new shaft so far, and I was scrutinizing it extremely hard. No visible, audible, or feelings of vibrations or odd sounds. I believe we have a winner.
I appreciate the offer for help though! Once I get some actual mileage on the thing, if an issue arises, I will let you know. But I think we're good.
Old 04-09-2014, 07:05 PM   #42
Model Citizen
Lacking brains
Drives: frz
I was under there and looked today, that is tight, real tight,
that said i've been driving with the setup since late summer/fall.
DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft F1point4 DIY (Do-It-Yourself) Guides 67 04-17-2021 05:21 PM
Kartboy, Driveshaft shop, Cusco, Perrin, ACT & Competition Clutch @OAKOS Automotive OAKOS Automotive Transmission and Driveline 163 01-19-2015 01:44 PM
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft Evasive Motorsports Engine, Exhaust, Transmission 1 09-24-2013 02:27 PM
WTB: Driveshaft Shop (or lighter) driveshaft Anthony Want-To-Buy Requests 8 08-27-2013 12:30 PM
Driveshaft Shop CF Driveshaft installed. Hawaiian Engine, Exhaust, Transmission 5 08-13-2013 02:04 PM
