Old 03-17-2014, 04:11 AM   #29
Crazy Drew
Drives: Smells like tires when I drive
Originally Posted by mike the snake View Post
I posted this in the "crickets" thread a while back. On my old BMW they had probs with the DI fuel pump, and someone suggested running a capfull of synthetic 2-stroke oil per tankfull of gas, and that was supposed to help.
I haven't had the crickets, but I bet this trick would work. It certainly wouldn't hurt anything to try.
Does the oil not kill the catalytic converters? From what I've seen this definitely has a chance to impact the lifetime of a cat.
From what I've seen, running only 93 with 10% Ethanol, Shell and Valero are the only gas that doesn't squeek in my car. Also, from what I've seen in my car the squeeking has to do with how much load the HPFP is under. Coming straight off the highway cruising at low RPM (almost all DI) the pump is quiet but if I idle at a light straight off the highway the squeeks get louder as the HPFP transitions to almost no load an bypasses a lot of fuel. I almost don't think it's ethanol related however what lubricants are used in the fuel and how the HPFP return deals with it. IMHO its the "return" system from it that squeeks.
Crazy Drew is offline   Reply With Quote
Old 03-17-2014, 08:50 AM   #30
JerryMichaels7
Drives: Whiteout FRS
Crickets prior to e85...no crickets after e85....its not the Fuel or ethonal content...
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
The Following User Says Thank You to JerryMichaels7 For This Useful Post:
mad_sb (03-17-2014)
Old 03-17-2014, 10:15 AM   #31
mad_sb
Drives: 2013 Asphalt FR-S
Well, i agree it's not ethanol content. From reading the tsb's (subaru has 3 revisions, toyota has 2) the root cause is air entrapment in the pump.
I can see how various fuels with different additive packages etc would have different likely hood of producing the needed bubbles at different temperatures and pressures, but i still don't believe it is the ethanol content that is the issue.
Also of note, you will only hear the crickets when idling on DI injectors only. Normally the switch over from port only idle to DI only idle occurs right around the time the coolant gets up to operating temp, but there are times it does not switch over when expected. This is part of the reason they come and go.
Old 03-17-2014, 10:49 AM   #32
86viper
Drives: 2013 Toyota 86 GTS
I had zero chirps for 15000km
The very day i switched to E85 they were there, quite loud.
Now 5000km later, i use the same fuel and they have reduced to the point where it has to be silent outside to hear them.
Absolutely zero problems running E85 as well.
86viper is offline   Reply With Quote
Old 03-17-2014, 11:55 AM   #33
humfrz
Originally Posted by Clembo View Post
If I had to guess it would be the less lubricating properties of alcohol vs. petroleum-based gasoline.
BTW, I can only get 10% ethanol here and have no chirp. Or at least my 63 year old ears are so damaged I can't hear it. Then again, no one looks at me funny at traffic lights so maybe it's really not there.
So, old timer ...... I must ask ....If your car's fuel pump chirps ..... and you can't hear it ...... is it making a chirping sound ..... ??
humfrz
(sorry, it's a slow day here in Puyallup)
mad_sb (03-17-2014)
Old 03-17-2014, 02:51 PM   #34
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
For all I know, mine could be chirping like crazy, but with my tinnitus, I'll never hear it.
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
Old 03-17-2014, 03:04 PM   #35
zooki
Drives: waiting on a 2021...
Originally Posted by swpbrz View Post
It for sure has to do with the ethanol. The day I bought my car it was fine. The very first fill up with 10 % ethanol was immediate chirps. It really isn't even a question. At least one cause for the chirping is this. I left the state and as soon as I fill up with a non ethanol blend it goes away. Again for sure atleast one thing for sure 100 % is the ethanol. It sucks your on here diluting a possible solution because you dont have identical symptoms
So, if someone else's experience with ethanol free fuel, or E85, or E10 fuel differs from your experience it's suddenly invalid? If they run pure gas and their fuel pump chirps they're lying? It it were ethanol content EVERY car that runs ethanol mixed gas would chirp, and NO car that runs pure gas would, and that doesn't seem to be the case from reading of everyone's experiences on this forum.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following User Says Thank You to zooki For This Useful Post:
mad_sb (03-17-2014)
Old 03-17-2014, 08:59 PM   #36
mike the snake
From what I gathered, running a capfull of 2 stroke oil per tankfull is fine and won't impact the cats at all. It's a very tiny amount of oil.
Old 08-04-2015, 02:36 AM   #37
jtsimaras
Drives: Subaru BRZ, Mazda CX5,
For me 10%ethanol blend caused chirp....now on non blend no chirp maybe luck �� no idea
jtsimaras is offline   Reply With Quote
Old 02-25-2019, 03:13 PM   #38
Swole
Drives: 86
Originally Posted by quasi86 View Post
With me they've been gone since the weather turned cold here in St Louis. However on the couple of days recently that it has gotten warmer I can definitely hear them again.
We have 93 around here and it is 10% ethanol. I almost exclusively use Quiktrip to refill.
Temperature has effected/eliminated the crickets for the time being, but I fear they will return.
Sent from my EVO using Tapatalk
Glad to know I am not the only one suspecting warm temperature brought crickets back.
Swole is offline   Reply With Quote
Old 02-25-2019, 03:28 PM   #39
I have never once experienced crickets in the winter. It has always been over 60 degrees and with ethanol added fuel. The hotter it gets the louder they got. Then last summer they just stopped in mid chirp one day and never came back. I suppose my fuel pump is broke but the car still runs so all is good.
gravitylover (02-26-2019)
Old 02-25-2019, 03:32 PM   #40
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
When I use no ethanol 91, my crickets stop. When the temperature dips below 50 degrees F, regardless of the fuel I use, the crickets stop. In my experience, ethanol and temperature both affect the noise
Old 02-28-2019, 06:12 PM   #41
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
I get no crickets with Ethanol Free. Using E10, no crickets when running Exxon/Mobil gas. All other brands produce crickets.
sly is offline   Reply With Quote
Old 02-28-2019, 06:18 PM   #42
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
I get the chirps on 91 not e85
Dr. BRZ is offline   Reply With Quote
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 11:06 AM
Where to get non ethanol fuel? mhigham Engine, Exhaust, Transmission 19 11-13-2012 12:27 PM
Ethanol fuel treatments JoeBoxer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 09-19-2012 12:42 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
Website that locates ethanol-free fuel wbradley Issues | Warranty | Recalls / TSB 8 07-24-2012 01:47 AM
