#29 | |
Drives: Smells like tires when I drive
From what I've seen, running only 93 with 10% Ethanol, Shell and Valero are the only gas that doesn't squeek in my car. Also, from what I've seen in my car the squeeking has to do with how much load the HPFP is under. Coming straight off the highway cruising at low RPM (almost all DI) the pump is quiet but if I idle at a light straight off the highway the squeeks get louder as the HPFP transitions to almost no load an bypasses a lot of fuel. I almost don't think it's ethanol related however what lubricants are used in the fuel and how the HPFP return deals with it. IMHO its the "return" system from it that squeeks. |
#30 |
Drives: Whiteout FRS
Crickets prior to e85...no crickets after e85....its not the Fuel or ethonal content...
life's greatest stories usually start with the words, "fuck it!".
| The Following User Says Thank You to JerryMichaels7 For This Useful Post: | mad_sb (03-17-2014) |
#31 | |
Drives: 2013 Asphalt FR-S
I can see how various fuels with different additive packages etc would have different likely hood of producing the needed bubbles at different temperatures and pressures, but i still don't believe it is the ethanol content that is the issue. Also of note, you will only hear the crickets when idling on DI injectors only. Normally the switch over from port only idle to DI only idle occurs right around the time the coolant gets up to operating temp, but there are times it does not switch over when expected. This is part of the reason they come and go.
~Namaste~ |
#32 |
Drives: 2013 Toyota 86 GTS
I had zero chirps for 15000km
The very day i switched to E85 they were there, quite loud. Now 5000km later, i use the same fuel and they have reduced to the point where it has to be silent outside to hear them. Absolutely zero problems running E85 as well. |
#33 | |
humfrz (sorry, it's a slow day here in Puyallup) |
| The Following User Says Thank You to humfrz For This Useful Post: | mad_sb (03-17-2014) |
#34 |
Drives: 2013 Scion FR-S Raven 6MT
For all I know, mine could be chirping like crazy, but with my tinnitus, I'll never hear it.
Stay squatchy, my friends
#35 | |
Drives: waiting on a 2021...
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
| The Following User Says Thank You to zooki For This Useful Post: | mad_sb (03-17-2014) |
#36 | |
From what I gathered, running a capfull of 2 stroke oil per tankfull is fine and won't impact the cats at all. It's a very tiny amount of oil.
#37 |
Drives: Subaru BRZ, Mazda CX5,
For me 10%ethanol blend caused chirp....now on non blend no chirp maybe luck no idea
#38 | |
Drives: 86
#39 |
I have never once experienced crickets in the winter. It has always been over 60 degrees and with ethanol added fuel. The hotter it gets the louder they got. Then last summer they just stopped in mid chirp one day and never came back. I suppose my fuel pump is broke but the car still runs so all is good.
| The Following User Says Thank You to Tcoat For This Useful Post: | gravitylover (02-26-2019) |
#40 |
Rust bucket enthusiast
When I use no ethanol 91, my crickets stop. When the temperature dips below 50 degrees F, regardless of the fuel I use, the crickets stop. In my experience, ethanol and temperature both affect the noise
#41 |
Drives: 2016 Cosworth 2.2 BRZ
I get no crickets with Ethanol Free. Using E10, no crickets when running Exxon/Mobil gas. All other brands produce crickets.
| Car fuel pump on... | Genomaxter | Engine, Exhaust, Transmission | 5 | 11-29-2012 10:06 AM |
| Where to get non ethanol fuel? | mhigham | Engine, Exhaust, Transmission | 19 | 11-13-2012 11:27 AM |
| Ethanol fuel treatments | JoeBoxer | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 09-19-2012 11:42 AM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 04:53 PM |
| Website that locates ethanol-free fuel | wbradley | Issues | Warranty | Recalls / TSB | 8 | 07-24-2012 12:47 AM |
