Old 05-22-2013, 01:16 PM   #15
Kochinopride
Kochinopride's Avatar
Drives: 13 FR-S, 12 CLS AMG, 05 Lotus Elise
I've been running e85 for about 8,000 miles and nothing. I get clutch chatter
2005 Lotus Elise
2012 Mercedes Benz CLS AMG 6.3
2013 Scion FR-S
2011 Land Rover LR4
2013 Lamborghini Gallardo LP570-4 Superleggera
Kochinopride is offline   Reply With Quote
Old 05-23-2013, 04:45 AM   #16
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I couldn't find my own thread. Good stuff guys. I'm just here learning.
The Following User Says Thank You to boredom.is.me For This Useful Post:
Sportsguy83 (05-23-2013)
Old 05-23-2013, 11:33 AM   #17
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
I'm pretty sure none of the cars I've driven have this. At 3k miles I can and feel the rear diff and hear the injectors....
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 05-23-2013, 11:39 AM   #18
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
I also have no chirp yet...close in on 5500 miles...
tripjammer is offline   Reply With Quote
Old 05-23-2013, 11:49 AM   #19
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
The first turbo car we did runs e85 and has no chirps either
Pure Automotive is offline   Reply With Quote
Old 05-23-2013, 09:41 PM   #20
fistpoint
Drives: Supercharged Golf Cart
I thought the latest theory on the crickets was an improperly installed valve inside the pump itself during manufacture?
fistpoint is offline   Reply With Quote
Old 05-23-2013, 10:25 PM   #21
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
I run e85 daily and unless I got used to them, the crickets haven't gotten any louder at all since I switched over from 93.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 05-23-2013, 11:59 PM   #22
midnightfrolic
Drives: Scion FRS A/T raven
I've had squeaks with every gasoline I've used. I've tried different branches of the same company in different cities. The Crickets are relentless. Maybe I need to drive it till near empty and fill up?
Fuel companies I've used:
76
Shell
Costco
Arco AM/PM
Chevron
midnightfrolic is offline   Reply With Quote
Old 03-16-2014, 07:08 PM   #23
swpbrz
Drives: swp brz limited
Originally Posted by mad_sb View Post
I believe toyota at one time thought it was related to ethanol content but from the reports we have on the forum, ethanol content makes zero difference as there are some folks on E Free fuels exclusively that have chirps all the way to people on E85 that have seen no change from E10.
Not to mention the change in lubricating properties from E0 to E10 are minimal at best.....
It for sure has to do with the ethanol. The day I bought my car it was fine. The very first fill up with 10 % ethanol was immediate chirps. It really isn't even a question. At least one cause for the chirping is this. I left the state and as soon as I fill up with a non ethanol blend it goes away. Again for sure atleast one thing for sure 100 % is the ethanol. It sucks your on here diluting a possible solution because you dont have identical symptoms
swpbrz is offline   Reply With Quote
Old 03-16-2014, 07:11 PM   #24
swpbrz
76
Shell
Costco
Arco AM/PM
Chevron
You're out of luck without leaving the state. CA allows or mandates an ethanol blend. We are screwed unless they make a piece that can handle the ethanol.
Old 03-16-2014, 07:58 PM   #25
mad_sb
Drives: 2013 Asphalt FR-S
How do you know it had ethanol free gas in it when you purchased it?
The Ethanol issue has be suspected since day 1, and some people seem to have success in running different brands of gas but I believe it was dis-proven to be the root issue in all cases (meaning it does not eliminate the crickets in all cases), looking for the detailed thread where the pump was torn down now. And if I am providing this one little bit of "bad" information it is more than made for by the many threads i have posted about tuning tech etc.
Edit:
Found the Subaru tsb that explains it is to do with the clearances on the pump internals, looks like this latest revision says that fuel formulation may contribute so if running E0 works for you that's great, but i believe the root cause is still the pump design or rather the way tolerances stack up on some pumps in comparison to others. That does not mean it works in all cases, nor that it will always work in yours.
The Following User Says Thank You to mad_sb For This Useful Post:
arghx7 (03-17-2014)
Old 03-16-2014, 08:45 PM   #26
boredom.is.me
Custom User Title
Well they must have fixed it. I replaced my pump around Christmas and haven't chirped yet.
Old 03-16-2014, 11:35 PM   #27
quasi86
quasi86's Avatar
Drives: 2013 Scion FR-S m/t Raven
With me they've been gone since the weather turned cold here in St Louis. However on the couple of days recently that it has gotten warmer I can definitely hear them again.
We have 93 around here and it is 10% ethanol. I almost exclusively use Quiktrip to refill.
Temperature has effected/eliminated the crickets for the time being, but I fear they will return.
Sent from my EVO using Tapatalk
Everyone, Including The Office Girls And Ladies, Came To See This Come Off The Truck For The Very First Time!
quasi86 is offline   Reply With Quote
Old 03-17-2014, 12:22 AM   #28
mike the snake
I posted this in the "crickets" thread a while back. On my old BMW they had probs with the DI fuel pump, and someone suggested running a capfull of synthetic 2-stroke oil per tankfull of gas, and that was supposed to help.
I haven't had the crickets, but I bet this trick would work. It certainly wouldn't hurt anything to try.
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 10:06 AM
Where to get non ethanol fuel? mhigham Engine, Exhaust, Transmission 19 11-13-2012 11:27 AM
Ethanol fuel treatments JoeBoxer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 09-19-2012 11:42 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
Website that locates ethanol-free fuel wbradley Issues | Warranty | Recalls / TSB 8 07-24-2012 12:47 AM
