Northern California NorCal
Old 08-12-2014, 01:05 AM   #29
JDis3
JDis3's Avatar
Drives: is300 / Fr-s
i tried doing this mod but find myself too anal retentive and paranoid to be satisfied without knowing for sure I'm not messing up the sensor or the clutch. I'm in the East bay (Fairfield) is anyone nearby that could help me out?
Daily Driver:2002 Lexus is300 Graphite Gray Pearl
Garage Queen:2014 Monogram Fr-s Asphalt 6MT
my.is: iJAYDM Clublexus: JDis3 IG:@j0nathandiaz
JDis3 is offline   Reply With Quote
Old 08-12-2014, 12:15 PM   #30
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
You don't need a shorty wrench at all... The natural thing is to try to use the wrench at a 6:00 position, which doesn't allow enough room. 9:00, on the other hand...
NissanGuy is offline   Reply With Quote
Old 08-12-2014, 12:22 PM   #31
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Not too nearby, in Castro Valley, but if we can set a time for you to head down, I'll help. Really, you just have to adjust it so the clutch pedal is maybe 1cm higher than the brake pedal. It's much more comfortable than stock and still gives tons of room to fully disengage the clutch.
Old 08-12-2014, 12:25 PM   #32
JDis3
JDis3's Avatar
I've actually already adjusted it but cant seem to get the right adjustment. I feel like the sensor's collar is pushing on the clutch too much and is dictating the height instead of the clutch master rod. It would be great if anyone could reply with some pictures of the positioning of their clutch master rod and the sensor threading. Just so i can see how far the threading is at both locations to have a reference.
Old 08-12-2014, 01:29 PM   #33
EAGLE5
Dismember
EAGLE5's Avatar
I moved the clutch switch so that it is not the stopper of the pedal when released. That means the switch isn't completely depressed ever, just mostly depressed when the clutch pedal is released. If the switch is stopping the pedal, you need to move the switch back.
Old 08-12-2014, 01:46 PM   #34
JDis3
JDis3's Avatar
thats what i figured, could you take a picture of your sensor threading. Both in the engaged and depressed position. Also of your clutch master rod threading?
Old 08-12-2014, 02:05 PM   #35
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Make sure you're spinning the clevis and not the rod. Shouldn't need to worry about the sensor then.
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 08-12-2014, 02:08 PM   #36
JDis3
JDis3's Avatar
The thing is i've already adjusted the sensor and dont recall how it was positioned prior to adusting it. im not having any issues with the rod/cleavis adjustment, moreso with the sensor.
Old 08-12-2014, 02:28 PM   #37
EAGLE5
Dismember
EAGLE5's Avatar
I'll try to remember too. Harder than it sounds.
Old 05-16-2015, 05:45 AM   #38
awhatzable
Drives: GTS86
Did you Bay Area people do your clutch pedal adjustment yet? I'm thinking of offering it as a service. I've been under there five times so far to get it right. It's getting to be second nature.
wish you were from Sydney..
awhatzable is offline   Reply With Quote
Old 05-19-2015, 02:03 PM   #39
jcygts6
jcygts6's Avatar
Drives: 13 SWP BRZ
my clutch pedal makes a single click noise now when i shift gears after i depress it and let off it. I wonder what it may be, it sure is annoying. Anyone knows how i can fix this?
jcygts6 is offline   Reply With Quote
Old 05-19-2015, 02:03 PM   #40
jcygts6
jcygts6's Avatar
Drives: 13 SWP BRZ
also it happens first 10 min of driving, after everything is warmed up, the noise goes away. It only clicks when the car is on and I am driving. if it is off and i am depressing the clutch pedal, it makes no noise
Old 05-20-2015, 12:50 AM   #41
EAGLE5
Dismember
EAGLE5's Avatar
Get down there and check it out. Try Changing the adjustment.
Old 05-20-2015, 01:10 AM   #42
funwheeldrive
You should try it out yourself. It is very easy to reverse once you get down there.
I waited a year to adjust my clutch pedal. I couldn't be more happy with the results. The car is so much easier to drive in every way.
Gas Pedal Adjustment ML Cosmetic Modification (Interior/Exterior/Lighting) 32 05-01-2017 09:26 PM
Clutch Adjustment Issues!! FT-86- Scion FR-S / Toyota 86 GT86 General Forum 39 05-28-2015 09:29 PM
Quick Question when doing clutch Adjustment Number 6 BRZ First-Gen (2012+) — General Topics 3 03-13-2013 11:18 PM
Quick Question when doing Clutch Adjustment Number 6 Scion FR-S / Toyota 86 GT86 General Forum 2 03-09-2013 04:31 PM
Clutch Pedal Engagement Adjustment denverizzles Scion FR-S / Toyota 86 GT86 General Forum 1 07-25-2012 05:01 PM
