Old 10-11-2015, 11:15 PM   #15
Joeyk
Drives: It runs
Did you also get the pinion bearing, carrier bearings, correct shims, and other parts needed to install properly?
I had to swap pinion bearings 2x while adjusting to check the right depth for it.
possibly its either not shimmed right and the back lash is messed up. and if they didn't check for backlash properly it could make the loud whine.
you can't reuse any of the OEM stuff with the new ring and pinion set.
especially the crush spacer for the pinion.
Joeyk is offline   Reply With Quote
Old 10-11-2015, 11:16 PM   #16
Joeyk
Drives: It runs
Also the stock ring has 4.1 stamped on it. the ones from weir doesn't i think...
Old 10-11-2015, 11:19 PM   #17
Joeyk
Drives: It runs
also if your final drive is not the 4.10 your dash doesn't tell you what gear you are in.
Old 10-12-2015, 03:44 AM   #18
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
@Joeyk are you meaning for auto or the gear indicator for manual that you can choose to display as I hadn't heard this?
nzer is offline   Reply With Quote
The Following User Says Thank You to nzer For This Useful Post:
Joeyk (10-12-2015)
Old 10-12-2015, 07:22 AM   #19
Joeyk
Drives: It runs
Oh I didn't know you can choose to display the gear you've selected.
For the manual. Mine used to tell me which gear I was in. After the install of the final drive it didn't.
I guess what happened was when I had the battery disconnected the previous setting was deleted.
I've always wondered what g-on was... LOL guess I'll try to turn it on when I get home and see if it still works.
The Following User Says Thank You to Joeyk For This Useful Post:
jbailey8748 (10-31-2015)
Old 10-12-2015, 07:55 AM   #20
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Sorry your having problems. My Weir 4.88's installed easy and are super quiet.
Lunatic is offline   Reply With Quote
Old 10-12-2015, 08:22 AM   #21
GT86_PRAGUE
Drives: GT86
You have to turn it on, but it will be off from 3rd gear up.
You would have to adjust settings in ECU for showing correct gear.
GT86_PRAGUE is offline   Reply With Quote
Old 10-12-2015, 08:25 AM   #22
GT86_PRAGUE
Drives: GT86
Mine 4.88 Weir was also PITA to install, it was a two day job, but now it is working almost flawlessly, just some noisy humming above 190km/h. I am interested how it will be after few weeks.
Advice: buy the shim set.
Old 10-12-2015, 09:01 AM   #23
Joeyk
Drives: It runs
wish I went with the 5.30 instead.
Old 10-12-2015, 09:53 AM   #24
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
they dont test drive it before calling you to say its ready? i had a weir 4.56 and it hummed like a mofo on the highway but no detrimental noises.. did they put on new bearings?
IG-Joey_Soul
Old 10-12-2015, 11:28 AM   #25
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
I ordered 4.88 to weir Performance for my AT.
good shop good price and fast delivery.
but i will swap next week, i'm waiting for pinion bearing. i do not know is there more parts needed or no?
Toyota86.ir is offline   Reply With Quote
Old 10-12-2015, 11:47 AM   #26
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
Well weir performance just confirmed that I DID receive the correct parts. I'm hoping for a peaceful resolution to this.
I found another shop that I actually trust that I'm going to have look at it.
If they don;t refund me a good portion of the $, I'm debating on disputing the original charge with my credit card company.
xsnapshot is offline   Reply With Quote
Old 10-12-2015, 11:49 AM   #27
xsnapshot
Fast enough
They did, and they knew it was making noise. They made me aware before I drove it that "it's making a little noise still". That was quite the understatement.
BTW your car shouldn't be "humming like a mofo" on the highway. It should be quiet. Have you checked the temperature of your diff after some casual driving? Is it getting really hot?
The Following User Says Thank You to xsnapshot For This Useful Post:
Ultramaroon (10-12-2015)
Old 10-12-2015, 11:13 PM   #28
makesdrivingfunagain
Im sorry to hear about that... I have had a similar experience with a previous build in CA. The business that screwed up my car was an incompetent, lying, thief and had my car for a month for a 1-2day job. Then when I got the final bill he overcharged and the worked sucked. I had to go to another shop to fix it. I should have sued him. I should have sued. Why didn't I sue this guy
makesdrivingfunagain is offline   Reply With Quote
4.8 final drive drift86 Engine, Exhaust, Transmission 29 11-28-2022 12:49 PM
3.7 Final Drive GsxrMe Engine, Exhaust, Transmission 9 09-28-2015 07:55 AM
Final Drive 4.67 Bongertz Engine, Exhaust, Transmission 33 09-02-2015 03:11 PM
Final Drive gears?? Nigelr32 Engine, Exhaust, Transmission 41 08-14-2015 03:43 PM
3.3 Final drive? Manji Engine, Exhaust, Transmission 18 01-01-2015 02:51 PM
