Old 09-27-2015, 10:02 PM   #1
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
3.7 Final Drive
I did it with my turbo Busa to give me slightly less wheel spin and to give me longer slower revs. I can't locate a final drive that is small like 3.7:1
Help
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 09-27-2015, 10:12 PM   #2
fika84
fika84's Avatar
Search.. Then find the Lexus IS300 final drive. Or buy one from Weir Performance for the 86-92 supra. There is a BUNCH of information on final drives on this forum if you search it using Google. Or buy my 3.91!!
fika84 is offline   Reply With Quote
Old 09-27-2015, 10:14 PM   #3
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Going to this thread
http://www.ft86club.com/forums/showthread.php?t=49288
Pointed me to here
http://weirperformance.com/finaldrivegears.html
Looks like they may be able to get used 3.73 gears or even 3.58. Probably have to call and see if they have it in stock
Freeman is offline   Reply With Quote
Old 09-27-2015, 10:17 PM   #4
fika84
fika84's Avatar
Pointed me to here
I never noticed they were used for the smaller gears! Ain't that some shit...
Old 09-27-2015, 10:18 PM   #5
Freeman
Freeman's Avatar
Originally Posted by fika84 View Post
What makes you think they are used?? I can assure you they are NOT used. I bought a 4.88 from them.
Calm down kiddo. It says it right there on the page "used ratios available" then it lists the 3.58 and 3.73 ratios. Sooooooo
Old 09-27-2015, 10:20 PM   #6
fika84
fika84's Avatar
Yeah, I caught myself while you were writing that.. my bad. Definitely never noticed that!
Old 09-27-2015, 10:21 PM   #7
Freeman
Freeman's Avatar
No worries. Misunderstanding.
Old 09-27-2015, 10:51 PM   #8
kodyo
Drives: Scion FR-S
Find a lexus IS300 with an M85 differential (3.73) and direct swap that into your car. Problem solved. You can pick them up at various car yards for ~$250 for the whole pumpkin. Weir performance with solid spacer is a good solution too if you plan to rebuild current one.
kodyo is offline   Reply With Quote
Old 09-28-2015, 07:08 AM   #9
GsxrMe
GsxrMe's Avatar
Huge thanks. I rather just purchase a used rear, flush fluid and install. Atleast I'll have the factory granny rear for backup.
2014 Subaru BRZ
Old 09-28-2015, 07:55 AM   #10
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I swapped in an M85 diff into my FRS. Was a direct fit.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
4.8 final drive drift86 Engine, Exhaust, Transmission 29 11-28-2022 12:49 PM
FI+ shorter final drive HUNTERANGEL121 Forced Induction 38 07-24-2017 12:41 AM
Final Drive 4.67 Bongertz Engine, Exhaust, Transmission 33 09-02-2015 03:11 PM
Need help finding a final drive kit Ethan Wagner Scion FR-S / Toyota 86 GT86 General Forum 1 07-12-2015 08:08 PM
3.3 Final drive? Manji Engine, Exhaust, Transmission 18 01-01-2015 02:51 PM
