Old 05-25-2015, 03:47 PM   #1
Nigelr32
Drives: '14 GT86 project, '13 GT86 DD
Final Drive gears??
I am building a forged engine with around 500hp, so am going to be using a SC sequential 'box. Obviously, I will get a choice of ratios with the 'box, but am still wondering, should i change the diff gears??
As an Engineer I can see the benefit in having higher ratios, as the propshaft will get spinning faster, but am not convinced I'm right??
Any advice from those in the know will be appreciated.
Nigelr32 is offline   Reply With Quote
Old 05-25-2015, 06:21 PM   #2
stevesnj
stevesnj's Avatar
Ummm the extra torque created will trash your U-Joints, Driveshaft final drive gears and drive axles.
My 2016 Build thread
Old 05-25-2015, 07:01 PM   #3
kodyo
Drives: Scion FR-S
I wouldn't put higher ratio gears in if you are planning on putting a turbo/SC in, you will top out on that gear too quickly. Most people who go that route actually get a lower ratio.
kodyo is offline   Reply With Quote
Old 05-25-2015, 11:40 PM   #4
humfrz
I reckon that would depend on what you're going to do with the car ......
humfrz
Old 05-26-2015, 12:00 AM   #5
KoolBRZ
KoolBRZ's Avatar
That all depends on the ratios in the gearbox. Why don't you just install it first, then change the final drive to suit the gearbox? Remember, the lower the FD ratio, the more torque is put on the drive train, the higher the ratio, the more torque is put on the axles and wheels. Do you need top speed, or top acceleration? That sequential gearbox will give phenomenal acceleration with a high ratio FD because it will make the gearbox a close-ratio gearbox.
Old 05-26-2015, 12:06 AM   #6
gramicci101
Off Topic
Are you really saying that changing the ring and pinion in the differential will make the gear ratios in the transmission closer to each other? Do you think before you speak, or do you just open your mouth and roll with whatever comes out? Why don't you try to sell him on removing the left swaybar and welding the header closed too?
Old 05-26-2015, 12:18 AM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
Remember, the lower the FD ratio, the more torque is put on the drive train...
Care to elaborate on this?
Old 05-26-2015, 12:46 AM   #8
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
I am still amazed at his ability to spew out completely backward shit.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 05-26-2015, 12:59 AM   #9
gramicci101
Off Topic
I assume you'll have some sort of forced induction, since you'll be pushing around 500hp? In that case, you'll benefit more from lowering the ring and pinion ratio, so you can stay in your power band longer before having to shift. Definitely do as @stevesnj suggested and beef up the rest of the drivetrain back there so you don't lose an axle or cv joint or something like that.
Old 05-26-2015, 01:14 AM   #10
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Old 05-26-2015, 01:17 AM   #11
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
this.
I would reccomend 3.73 FD, replace the drive shaft, axles, I would look into FBM's Ford 8.8 rear end. IS300 diff would be a good thought.
Old 05-26-2015, 01:39 AM   #12
KoolBRZ
KoolBRZ's Avatar
Yes it actually does. While it doesn't change the gears themselves, it does change the spread between the gears. The gearbox isn't used by itself. It works BETWEEN the engine and the differential. The gear spread, which is the difference between close ratio and wide ratio gearboxes, is dramatically affected by the FD ratio.
In simple words, the redline speeds in 1st thru 6th with a lower FD ratio will be further apart, in other words, a wider spread. For example;
4:10 ratio lower = farther apart
1st=38 MPH @ 6966 RPMs
2nd=63 MPH @ 6969 RPMs
3rd=89 MPH @ 6933 RPMs
1st - 2nd, 25 MPH. 2nd - 3rd, 26 MPH
5:10 ratio higher = closer together
1st=30 MPH @ 6841 RPMs
2nd=50 MPH @ 6880 RPMs
3rd=72 MPH @ 6977 RPMs
1st - 2nd, 20 MPH. 2nd - 3rd, 22 MPH
If you're shifting closer together, it's the same as saying it has a closer ratio between gears.
Old 05-26-2015, 01:42 AM   #13
KoolBRZ
KoolBRZ's Avatar
I just did.
Old 05-26-2015, 01:44 AM   #14
KoolBRZ
KoolBRZ's Avatar
Think before you speak. I've actually changed my FD. Have you? Any idiot can spew insults. I back up what I say with fact. Care to dispute that?
4.8 final drive drift86 Engine, Exhaust, Transmission 29 11-28-2022 12:49 PM
4.875 final drive review drift86 Engine, Exhaust, Transmission 98 02-12-2018 06:13 PM
Final Drive 4.67 Bongertz Engine, Exhaust, Transmission 33 09-02-2015 03:11 PM
3.3 Final drive? Manji Engine, Exhaust, Transmission 18 01-01-2015 02:51 PM
Final Drive Calculations wootwoot Engine, Exhaust, Transmission 34 12-19-2014 04:06 AM
