#15 | |
Drives: 2015 Raven FRS
#17 |
#18 |
Dismember
Drives: 2013 Red Scion FR-S
The dealer will likely just replace the speed sensor and see if it fixes the problem. Quite often the code correctly diagnoses the problem. Could be a loose connection or damaged wire, too. Or some completely bizarre thing making one wheel turn at a different rate from the others. No physical symptoms?
#19 |
#20 |
Dismember
Maybe another twin owner will let you try swapping sensors?
#21 |
Still sitting at the track with a dead car, anyone have any more ideas I can try?
#22 |
Drives: Moped
#23 |
Unplug and plug in the speed sensors at all 4 wheels. Could also be a damaged sensor from the gear swap or could be loose and got damaged
#24 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Speed sensors are super finicky. If the code is telling you that it is probably the cause.
#25 |
No, never got it solved. The track owner loaned me one of his "Chump Cars", a Honda Civic so at least I got to run and had some fun. Bill, the track owner said the honda was capable of 2.15 times and I did a 2.167 so I felt pretty good.
While at the track I did pull all 4 wheel sensors and visually check them. They all looked like new. So it's still in the trailer, bringing it to the dealer this morning. |
#26 |
Legend
Drives: Whiteout FR-S
Keep us posted, after the dealer tells you what happened.
#27 |
I had a speed sensor issue when I went through an under carriage car wash. The code went away after about 12 hours (after drying). This has happened multiple times. Did you run through any water during the track day? Heat from brakes effecting sensor?
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#28 |
Well the Scion Dealer found the problem. And it ain't pretty.
Come to find out the incompetent asshole shop that changed my rear end gears didn't tighten the axle nut properly. So it came off! Which means the back hub was just kind of flopping in the breeze, tearing everything up, and just waiting for another turn so it could come off completely. Everything is shot and needs replacing. This is what was causing a miss-alignment with the speed sensor and the warning lights. The incompetent asshole shop is picking my car up and re-doing everything new. no cost. Hope they do it right this time. I am a bit ashamed I didn't catch this my self when I pulled the back wheel. I noticed my little center hub cap was missing but after pulling the wheel looked right over the axle shaft to the speed sensor. So everyone go torque your axle nuts. |
| Car having trouble starting up!!! | TomT2411 | Issues | Warranty | Recalls / TSB | 3 | 05-09-2014 07:57 PM |
| window trouble | ravenblackfrs | Electronics | Audio | NAV | Infotainment | 4 | 01-08-2014 12:42 PM |
| Anyone else have trouble with OEM stereo + usb drive? | Ingen | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 07-19-2013 01:53 PM |
| Trouble With Lights | jpit | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 06-24-2013 09:51 PM |
| trouble shooting | tim saylor | Other Vehicles & General Automotive Discussions | 0 | 07-01-2012 01:04 PM |
