Old 07-12-2014, 10:04 PM   #15
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Originally Posted by mav1178 View Post
http://www.ft86club.com/forums/showthread.php?t=49978
Not the same issue, but I have a sneaky feeling your final drive is messing things up.
-alex
I thought that also but have found at least 3 other people with automatics that went to 4.88s with out any problems. My Scion dealership says 4.88s won't cause a problem, but who believes them.
Lunatic is offline   Reply With Quote
Old 07-12-2014, 10:27 PM   #16
Lonewolf
Lonewolf's Avatar
Drives: Moped
@CSG Mike @CSG David
Old 07-12-2014, 10:33 PM   #17
Lunatic
Lunatic's Avatar
Been working with booth of them, but no ideas yet.
Old 07-12-2014, 10:39 PM   #18
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
The dealer will likely just replace the speed sensor and see if it fixes the problem. Quite often the code correctly diagnoses the problem. Could be a loose connection or damaged wire, too. Or some completely bizarre thing making one wheel turn at a different rate from the others. No physical symptoms?
Old 07-12-2014, 11:05 PM   #19
Lunatic
Lunatic's Avatar
No, none at all.
Old 07-12-2014, 11:21 PM   #20
EAGLE5
Dismember
EAGLE5's Avatar
Maybe another twin owner will let you try swapping sensors?
Old 07-13-2014, 12:20 PM   #21
Lunatic
Lunatic's Avatar
Still sitting at the track with a dead car, anyone have any more ideas I can try?
Old 07-13-2014, 10:22 PM   #22
Lonewolf
Lonewolf's Avatar
Drives: Moped
Whatever came of this? Did you figure it out?
Old 07-13-2014, 10:36 PM   #23
stevesnj
stevesnj's Avatar
Unplug and plug in the speed sensors at all 4 wheels. Could also be a damaged sensor from the gear swap or could be loose and got damaged
Old 07-14-2014, 02:48 AM   #24
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Speed sensors are super finicky. If the code is telling you that it is probably the cause.
Old 07-14-2014, 08:02 AM   #25
Lunatic
Lunatic's Avatar
No, never got it solved. The track owner loaned me one of his "Chump Cars", a Honda Civic so at least I got to run and had some fun. Bill, the track owner said the honda was capable of 2.15 times and I did a 2.167 so I felt pretty good.
While at the track I did pull all 4 wheel sensors and visually check them. They all looked like new. So it's still in the trailer, bringing it to the dealer this morning.
Old 07-14-2014, 11:24 AM   #26
Sovereign
Legend
Drives: Whiteout FR-S
Keep us posted, after the dealer tells you what happened.
Sovereign is offline   Reply With Quote
Old 07-14-2014, 02:40 PM   #27
Tt3Sheppard
Tt3Sheppard's Avatar
I had a speed sensor issue when I went through an under carriage car wash. The code went away after about 12 hours (after drying). This has happened multiple times. Did you run through any water during the track day? Heat from brakes effecting sensor?
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 07-14-2014, 04:09 PM   #28
Lunatic
Lunatic's Avatar
Well the Scion Dealer found the problem. And it ain't pretty.
Come to find out the incompetent asshole shop that changed my rear end gears didn't tighten the axle nut properly. So it came off! Which means the back hub was just kind of flopping in the breeze, tearing everything up, and just waiting for another turn so it could come off completely.
Everything is shot and needs replacing. This is what was causing a miss-alignment with the speed sensor and the warning lights. The incompetent asshole shop is picking my car up and re-doing everything new. no cost.
Hope they do it right this time.
I am a bit ashamed I didn't catch this my self when I pulled the back wheel. I noticed my little center hub cap was missing but after pulling the wheel looked right over the axle shaft to the speed sensor.
So everyone go torque your axle nuts.
Car having trouble starting up!!! TomT2411 Issues | Warranty | Recalls / TSB 3 05-09-2014 07:57 PM
window trouble ravenblackfrs Electronics | Audio | NAV | Infotainment 4 01-08-2014 12:42 PM
Anyone else have trouble with OEM stereo + usb drive? Ingen Scion FR-S / Toyota 86 GT86 General Forum 10 07-19-2013 01:53 PM
Trouble With Lights jpit Cosmetic Modification (Interior/Exterior/Lighting) 7 06-24-2013 09:51 PM
trouble shooting tim saylor Other Vehicles & General Automotive Discussions 0 07-01-2012 01:04 PM
