Old 01-08-2014, 11:32 AM   #1
ravenblackfrs
ravenblackfrs's Avatar
Drives: 2013 Raven Black FRS
window trouble
Freaking out a little right now....
Driver window only rolls down with driver switch... Passenger window only goes does with switch on passenger door... Driver door passenger window switch doesn't work.
Also, auto roll down and up doesn't work... Is this something from the cold doing this?
Raven FR-S, Magnaflow Axel Back Exhaust, Airaid Intake.... Pending Dynojet for performance gains... Big wish list... just need money to do it!
ravenblackfrs is offline   Reply With Quote
Old 01-08-2014, 12:06 PM   #2
iTash
Drives: BRZ Premium
you're not the only one. Yesterday, I noticed the passenger window toggle "auto" light blinking. Tried opening using the driver side toggle and it wouldn't work, however, the passenger side toggle works. Not sure the cause of this.
I would guess its the cold weather because that's the only noticeable change that happened around my area, but it doesn't make sense that it works from the passenger side but not driver side. Just gotta wait and see if the weather is really affecting it.
iTash is offline   Reply With Quote
Old 01-08-2014, 12:35 PM   #3
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Same happening here. Also, my windows will not completely shut when I get in the car. They lower a bit when I open the door to get in, as designed, but they don't back unless I manually raise the window that extra centimeter with the switch on the door. The lights on my window switches are also blinking.
I also think it is due to the cold weather, but I thought cold was below –5°F. I would guess that you don't get that cold in VA or GA. Perhaps there is some systemic problem with the window mechanism.
Old 01-08-2014, 12:36 PM   #4
Terrapin77
Terrapin77's Avatar
Drives: 2013 Argento FR-S
Read pg 52 of your owners manual.
Terrapin77 is offline   Reply With Quote
Old 01-08-2014, 12:42 PM   #5
cooldandani
Drives:
go to your passengers side and put the window down all the day and leave the button pressed down for 5 seconds and put the window back up. now you should be able to control the window with the drivers side button
cooldandani is offline   Reply With Quote
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 02:14 PM
U0115 OBD trouble code vtmike Issues | Warranty | Recalls / TSB 4 08-31-2013 01:24 PM
squeaky window due to window rubbing against rubber at the top tracerit Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 08-10-2013 05:34 AM
Trouble With Lights jpit Cosmetic Modification (Interior/Exterior/Lighting) 7 06-24-2013 09:51 PM
trouble shooting tim saylor Other Vehicles & General Automotive Discussions 0 07-01-2012 01:04 PM
