Old 07-12-2014, 02:46 PM   #1
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Trouble at Track, Need Help
I'm sitting at Oregon Raceway Park. Did 5 or 6 good laps and all of a sudden the traction light comes on, abs light comes on, check engine light comes on, and engine goes into limp mode.
Plugged in a code reader and the only code we get is P2158 Speed Sensor D
Tried to clear code and it won't clear.
Let the car and engine cool down and it won't clear
Tried the peddle dance and it won't clear
unhooked the battery for 15 minutes to reset ECU and still won't clear.
Called the dealer and they don't have a clue, all they could say is bring it in Monday.
What has been done to the car is
bypassed stock transmission cooler and added a large after market universal transmission cooler
Added a oil cooler
went from 4.10 rear end gears to 4.88s
Installed a Vigilant cold air intake
All else is stock
Anyone got any ideas?
Lunatic is offline   Reply With Quote
Old 07-12-2014, 02:54 PM   #2
Fastbrew
Drives: 2014 Pearl White BRZ
Sounds like you might have broken or have a faulty speed sensor. Not sure if D= rear right but that would make sense since you have 4 of them. Did you hit something hard at speed?
Good luck!
PS:
http://www.ft86club.com/forums/showthread.php?p=1363341
Fastbrew is offline   Reply With Quote
Old 07-12-2014, 02:56 PM   #3
Dezoris
Dezoris's Avatar
Id start with the checking the obvious, wheel speed sensor. How long have you had the gearing changed?
You on stock brakes and wheels/tires?
Old 07-12-2014, 04:34 PM   #4
Lunatic
Lunatic's Avatar
Changed the gears three days ago. Still stock brakes, wheels, and tires. Didn't hit anything.
Also you can not disable any of the traction or sport modes by holding the button down.
Old 07-12-2014, 05:04 PM   #5
Lunatic
Lunatic's Avatar
Checking the speed sensors. Is there a way to check them other than visibly looking at them?
Old 07-12-2014, 05:55 PM   #6
Lunatic
Lunatic's Avatar
I just pulled all 4 speed sensors, all look brand new.
Old 07-12-2014, 07:56 PM   #7
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Pedal dance = disables all traction control and VDC, leaves ABS on. If you're doing the pedal dance correctly you should be able to put the car in Diagnostic Mode and drive without the car interfering electronically. You wouldn't be able to turn off this mode either until the next time you start the car.
-alex
Old 07-12-2014, 08:21 PM   #8
Lunatic
Lunatic's Avatar
-alex
When I do the peddle dance the traction control goes off and so does VDC, but the three warning lights stay on.
Old 07-12-2014, 08:24 PM   #9
mav1178
mav1178's Avatar
Try pulling the fuse for ABS to see if you can get the car anywhere. Beyond that you're at the mercy of the speed sensor (not the one on the wheels, those are ABS sensors)
-alex
Old 07-12-2014, 08:31 PM   #10
Lunatic
Lunatic's Avatar
-alex
Where is the speed sensor?
Old 07-12-2014, 09:05 PM   #11
JamesBond000
First Class Speeder
Drives: Silent and Quick
NVM
Last edited by JamesBond000; 07-29-2014 at 04:29 PM. Reason: I must of been high when i posted this one LOL
JamesBond000 is offline   Reply With Quote
Old 07-12-2014, 09:17 PM   #12
mav1178
mav1178's Avatar
Nevermind... I just looked at the wiring diagram and it seems like the vehicle speed is read off the 4 sensors.
-alex
Old 07-12-2014, 09:19 PM   #13
mav1178
mav1178's Avatar
http://www.ft86club.com/forums/showthread.php?t=49978
Not the same issue, but I have a sneaky feeling your final drive is messing things up.
-alex
Old 07-12-2014, 10:01 PM   #14
Lunatic
Lunatic's Avatar
I tried pulling the ABS fuse and that made no difference.
Car having trouble starting up!!! TomT2411 Issues | Warranty | Recalls / TSB 3 05-09-2014 07:57 PM
window trouble ravenblackfrs Electronics | Audio | NAV | Infotainment 4 01-08-2014 12:42 PM
Anyone else have trouble with OEM stereo + usb drive? Ingen Scion FR-S / Toyota 86 GT86 General Forum 10 07-19-2013 01:53 PM
Trouble With Lights jpit Cosmetic Modification (Interior/Exterior/Lighting) 7 06-24-2013 09:51 PM
trouble shooting tim saylor Other Vehicles & General Automotive Discussions 0 07-01-2012 01:04 PM
