#15 |
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
"Looks good."
Your issue just doesn't make sense to me unless the clearance was hella tight before the new DS. - AdrianG |
#16 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
It probably was. But you can't see it from the side to get a good view of it.
#17 |
Lacking brains
Drives: frz
I have both, tight, but no issues.
#18 |
Boosted
Drives: Not a supra....yet
so you have both the kart boy ss and the cf shaft with no issues ?
#19 |
We have the kart boy and carbon shaft in our race car. Zero issues. Something has to be off with the shifter install.
#20 |
Drives: FRS
Is the car still in the air? I am thinking maybe if you let it on the ground you will gain clearance....?
#21 | |
Just a dude
Drives: Scion FR-S 2013
I'm pretty sure Anthony discovered this on the ground, and up in the air was to look and figure things out..
#22 |
Drives: Subaru BRZ
Maybe I'm missing something here, why is your driveshaft turning when you let the clutch out in neutral?
Can you shim the shifter up with a few washers? |
#23 | ||
Weight Nazi
Yes. My Tiburon does this same thing. If I wiggle it, I can get it to not spin in neutral. Then I can wiggle it some more and it will begin to spin again. But it's not in gear. I can hit the brakes and it will stop but not stall. I was under the impression this is normal since my 10 year old FWD Hyundai and my still-new RWD Toyota both do it. But yes, I was also wondering why it does this and if it's normal. That's for another thread though.
#24 | |
Weight Nazi
Maybe I could take the exhaust and driveshaft off again, loosen the shifter bushing, then push up on it and re-tighten it.
#25 |
Lacking brains
Drives: frz
I gotta fix my front camber today thanks to slotted struts and rainy hpds/autox shenanigans, will try remember to get under and take a pic.
#26 |
Weight Nazi
If you can somehow get a picture of the clearance between the linkage and the driveshaft, that would be great.
#27 | |
-Jeremy |
#28 |
Weight Nazi
Huh...
I have no problem shifting, but my reverse lockout has been nonfunctional ever since I did it. I installed MTEC shifter springs, Whiteline positive shift kit, Perrin shifter pushing, and the Kartboy shifter all at once. I just chalked it up too doing too much at once. The bottom of the shifter is angled forward though, I'm pretty sure. I think if it was backwards, it would be angled backwards and the angle of the shifter would be pointing way forward. I'll look at it again when I get home.
| DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft | F1point4 | DIY (Do-It-Yourself) Guides | 67 | 04-17-2021 05:21 PM |
| Kartboy, Driveshaft shop, Cusco, Perrin, ACT & Competition Clutch @OAKOS Automotive | OAKOS Automotive | Transmission and Driveline | 163 | 01-19-2015 01:44 PM |
| New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft | Evasive Motorsports | Engine, Exhaust, Transmission | 1 | 09-24-2013 02:27 PM |
| WTB: Driveshaft Shop (or lighter) driveshaft | Anthony | Want-To-Buy Requests | 8 | 08-27-2013 12:30 PM |
| Driveshaft Shop CF Driveshaft installed. | Hawaiian | Engine, Exhaust, Transmission | 5 | 08-13-2013 02:04 PM |
