Old 06-11-2014, 01:41 PM   #15
Model Citizen
Lacking brains
Drives: frz
Originally Posted by dradernh View Post
Congratulations - that kit should do an outstanding job for you. Loudon is fairly intense on brakes and will be a decent test during the hot months. The Glen would be a greater test due to the higher speeds.
Going forward, some brake temperature paint might be a good idea. Just a thought.
Absolutely going to pick up some paint at some point, even if only just for my own curiosity.
Realistically, im lazy and hate driving far for anything. Which pretty much rules out everything but thompson, nhms, or the prayer of palmer.
Originally Posted by Tye300 View Post
What's the theory behind that?
Cheap and easy airflow.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 06-11-2014, 05:22 PM   #16
randyzimmer
Drives: 2 Subaru Wagons
Hi, testing this weekend at two tracks. Here's where the fans are. They are in the center of the hub and pointing toward the caliper and mount on two of the wheel bearing bolt heads. There's a heat sensor that goes into the bleed screw that turns them on when the caliper is warmer than street use (about 2.5Amps) and turns the fans on a higher speed (~12.5A) when the caliper gets really hot. The fans continue to run until the caliper is back down to warm in the paddock.
These pics are a month old and things keep changing but you can get the idea of what's going on.
randyzimmer is offline   Reply With Quote
Old 06-11-2014, 05:34 PM   #17
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Do you have any more pics? Those are very low resolution and the angles actually make it difficult to see what's what. The top picture I can tell is the back of the OEM caliper and bleed screw. The bottom pic I have no idea what I'm looking at.
Old 06-11-2014, 05:49 PM   #18
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Did you guys see my recent thread in DIY section?
so far so good btw, I will upgrade the zip ties on the spindle with metal zip ties for an extra protection and update the thread accordingly
http://www.ft86club.com/forums/showthread.php?t=67289
glamcem is offline   Reply With Quote
Old 06-11-2014, 06:21 PM   #19
gramicci101
Off Topic
Here's the thread from the GTR forum that discusses the Spatula air duct mod:
http://www.gtrheritage.com/topic/109...-thread/page-2
http://www.gtrlife.com/forums/index.php?showtopic=34741
From this thread:
http://www.ft86club.com/forums/showthread.php?t=63781
Carreras (GT3, I think) have a nifty piece of formed plastic that wraps around the control arm to help direct air into the brake rotor, but they're $$$. The spatulas tend to cost less.
edit: It turns out that 993 brake ducts are around $12 each, and GT3 brake ducts are around $30 each. According to the GTRLife thread.
Old 06-11-2014, 06:55 PM   #20
Model Citizen
Lacking brains
Drives: frz
Man $12. I spent nearly that on each spatula.
Fuck you bed bath and beyond.
Pretty sure i had linked the gt3 ducts in the op.
Old 06-11-2014, 09:18 PM   #21
ATL BRZ
ATL BRZ's Avatar
Searched and found someone who fitted the GT3 air guides to an 86. Looks pretty good.
Build thread: http://www.ft86club.com/forums/showthread.php?t=42963
They look much more effective than the spatulas.
$34 shipped on eBay: http://pages.ebay.com/motors/link/?n...954260&alt=web
Old 06-11-2014, 09:42 PM   #22
makinen
makinen's Avatar
Drives: Toyota 86
I also have used GT3 brake ducts on my 86.
Zip-tied but lasts a year and a half without problem.
makinen is offline   Reply With Quote
Old 06-11-2014, 09:46 PM   #23
ATL BRZ
ATL BRZ's Avatar
Attachment 81741
Looks very effective from that angle! Do you have any more pics? I think I'm gonna pick up a pair of those.
Old 06-11-2014, 10:02 PM   #24
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
I use GT3 ducs too.
it's very cost effective method to lower brake temerature.
and easy to install.
Yobiwan is offline   Reply With Quote
Old 06-11-2014, 11:54 PM   #25
glamcem
glamcem's Avatar
I am not sure how effective those GT3 ducts would be, I think the best way is to combine the proper ducting (fog light delete and washer fluid is pretty much must and I tried at least 5-6 different route for brake ducts none of them worked with the KW setup except the one in my DIY ) and other stuff such as Titanium shims, thermal wrapping, Motul rBF 600 and good brake pads.. I didn't experience any fade issues at track
Old 06-11-2014, 11:55 PM   #26
glamcem
glamcem's Avatar
and of course my fav combo
Old 06-12-2014, 12:02 AM   #27
akyp
Drives: 2012 86
Need high-res photos of the GT3 ducts with wheel removed!
akyp is offline   Reply With Quote
Old 06-12-2014, 12:07 AM   #28
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
With your power, one trip to Tremblant or the Glen and you'll be over that for good. lol These short, stoppy/turny tracks are anything but the bees knees for a real car.
Fred's site shows 10/22 for Palmer's opening. That's very late in the year, so I'd guess that at some point the opening will move out to next spring. I wonder how much granite they've had to move around or truck off that mountain top.
dradernh is offline   Reply With Quote
TF Brake Duct Cooling Kit Touge Factory Tracking / Autocross / HPDE / Drifting 77 06-11-2015 07:01 AM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
APR Performance FRS/BRZ Brake Cooling Kit vividracing Brakes, Suspension, Chassis 0 08-08-2013 04:03 PM
TF Brake Duct Cooling Kit Touge Factory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 02-19-2013 06:04 PM
Brake cooling duct kit tranzformer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-14-2011 01:37 PM
