Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > DIY (Do-It-Yourself) Guides
Old 06-03-2014, 10:00 PM   #1
glamcem
glamcem's Avatar
Drives: 2017 Camaro SS 1LE HBM
Wink DIY: Custom Brake ducting mod w/ fog light delete, cheaper alternative(~$80 vs $650)
I was trying to find some reasonable brake ducting kit that utilizes the fog light bezels since I didn't want to spend $650 for the APR brake ducting kit. Then I figured there is no other alternative so I decided to make my own. My total cost was about $80 bucks and it seems to be working just fine FYI, the aftermarket brake ducting options seem to be using the same quality ducting hose so you basically pay for the backing plates and some clamps/zip ties
I am sure there are many creative guys here and someone can come up with a lot easier method . This should typically take about 3-4 hours but I have to say I am very slow so YMMV ..with that said, please read carefully
WARNING: This mod requires you to remove the bumper, brake pads, calipers and rotors so please see below links and make sure you are comfortable with performing these and as always DO IT AT YOUR OWN RISK!!!
It also involves the washer bottle removal on the driver side in order to utilize the fog light inserts and requires you to modify the OEM brake backing plates,, Did I mention the removal of the fog lights . Since I have an intercooler I wasn't able to use an air inlets but if you're NA, you may be able to route the ducting and use these air inlets and keep your fog lights and washer bottle in their places
https://www.pegasusautoracing.com/pr...p?Product=3624
Tools and Parts required :
Props to @blackfireball5 for providing information about the mesh screen and how I can fix it on the fog light bezels. If you have an FRS I would highly recommend you to follow his directions since the fog light bezels might be slightly different
http://www.ft86club.com/forums/showthread.php?t=63231
To remove your bumper you may use the following link as a reference or the video below:
http://www.ft86club.com/forums/showthread.php?t=8788
Bumper and fog lights removed
since I have the foglights (BRZ Limited) I removed after removing the bumper and safely put aside the fog light cable (you may use gorilla tape to fix it inside the bumper) then I cut the mesh gutter with a scissor and placed it into the fog light bezel and applied some liquid nails..
** make sure you cut the mesh a bit bigger than the opening so it will fit tightly
Pay attention to these tabs you will need to put the zip ties through these tabs and the holes on the side and connect the couplers from their shields so those will stay in place
you can test fit your ducting hose but don't attach your hose yet
After removing the bumper I drained the washer bottle (this step is also necessary with Kraftwerks kit install and the smaller washer bottle that comes with the KW kit still wouldn't work)
after draining the washer bottle you can remove the whole thing (washer bottle) and put back your bumper so behind the inner tire wells you can see the grills (passenger side in the picture)
and the way it looks from the front
if you see some liquid nail residue you can either clean it or simply ignore it since they will be completely dirty and look black after a while
you can now remove your front calipers, brakes and rotors
you may refer to below instructions
http://www.ft86club.com/forums/showthread.php?t=45713
after removing the calipers and rotors you may put the calipers on the control arm and remove the brake backing plates(those should be 3x 12 mm bolts)
I didn't have electric saw and the Dremel tool wasn't strong enough so I simply used the electric drill and put some holes in the backing plate(this is the left/driver side backing plate) and connected the dots to make a hole
now you can cut the 11ft ducting hose in half and attach one half of the backing plate with 5-6 zip ties if you have metal zip ties those might be even better UPDATE: I have used Metal zip ties and left the plastic ones to see if they get melted after some hard track use and they all held up just fine but it wouldn't hurt to use the metal ones (driver side shown in the picture) since I didn't test the longevity of the regular zip ties I will check them after a few event and will probably change them with metal ones
you can now put the rotors, calipers and pads in place so we will have more room to route the ducting hose
here is the correct routing of the ducting hose and more zip ties of course
then you will cut the other end of the hose about 7.5" long so the remainder of the hose will make some tension and push it forward to the bumper and the hose will stay in place (you will do the same thing for the passenger side too)
you can now cut the inner fender well and make sure you cut it close to the frame and control arm side as much as possible .. there is a metal hook (not pictured) right behind the hose you will use that to zip tie the hose before you put it through the fender well
IMPORTANT: Make sure you test fit the ducting hose to see if the tires make contact with them at full lock.. I would definitely suggest you to to put the wheels when the car is on the jack stands so it would save you some time and effort
Gorilla tape comes in handy to close the gaps
now you can follow the same steps for the passenger side, there you have it a cheap alternative to those expensive brake duct kits ..enjoy it
Past: 07 STI-03 C5 Z06-11 STI-11 EVO X GSR-13 C6 Grand Sport-'13 MX-5 Club Edition-'14 BRZ LTD- '06 S2000
Current: 2017 Camaro SS 1LE(bone stock for now)
Build Thread
Custom Brake Ducting Mod
glamcem is offline   Reply With Quote
The Following 8 Users Say Thank You to glamcem For This Useful Post:
blackfireball5 (06-04-2014), chaoskaze (08-12-2015), DAEMANO (06-03-2014), Kristian (07-12-2014), phastafrican (06-05-2014), Ryaquinn (06-24-2014), Wayno (05-25-2016), WillRacer1jz (06-07-2014)
Old 06-03-2014, 10:15 PM   #2
TM
TM's Avatar
Drives: DGM BRZ 6MT
Great detailed write up!
TM is offline   Reply With Quote
The Following 2 Users Say Thank You to TM For This Useful Post:
blackfireball5 (06-04-2014), glamcem (06-03-2014)
Old 06-04-2014, 10:33 AM   #3
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Wow, seriously nice job dude! Very detailed! And thanks for the shoutout!
blackfireball5 is offline   Reply With Quote
The Following User Says Thank You to blackfireball5 For This Useful Post:
glamcem (06-04-2014)
Old 06-05-2014, 02:52 PM   #4
Synack
Boosted
Synack's Avatar
Drives: Sideways
Good job man for exploring the option, but there seriously has to be a better way to DIY that doesn't look so..... DIY'ish.
The Following User Says Thank You to Synack For This Useful Post:
glamcem (06-05-2014)
Old 06-05-2014, 03:19 PM   #5
glamcem
glamcem's Avatar
As I said earlier in my post, I bet someone can find a better/more efficient way to do this but FYI both APR and Touge Factory kits should require you to cut some holes and routing ( removal of the brakes, rotors and pads as well) ..so those are the absolute steps, I think the only additional step with my custom method is the modification to the OEM backing plate and washer/fog lights removal since using air inlets is not an option who's running intercooler...
Build Thread
Old 06-05-2014, 09:36 PM   #6
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by glamcem View Post
As I said earlier in my post, I bet someone can find a better/more efficient way to do this but FYI both APR and Touge Factory kits should require you to cut some holes and routing ( removal of the brakes, rotors and pads as well) ..so those are the absolute steps, I think the only additional step with my custom method is the modification to the OEM spindle and washer/fog lights removal since using air inlets is not an option who's running intercooler...
I'm sure you or someone will find a more intuitive way eventually.
Old 06-06-2014, 06:47 AM   #7
phastafrican
phastafrican's Avatar
Drives: 2013 Raven Scion FR-S
Great write up
Emmanuel Baako: NASA-Southeast Race Control & NASA Florida Race Director
RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T
phastafrican is offline   Reply With Quote
The Following User Says Thank You to phastafrican For This Useful Post:
glamcem (06-06-2014)
Old 06-06-2014, 12:29 PM   #8
glamcem
glamcem's Avatar
I would love to see that too
Build Thread
Old 06-18-2014, 12:24 PM   #9
glamcem
glamcem's Avatar
little update about my custom brake cooling duct;
this past weekend I had a chance to test my custom brake ducting (updated routing) and even I ran out of the track couple times and it still held up just fine
as well as my new FT86 front splitter..so for those who are not sure about the sturdiness of the ducting and the splitter, this might be a good news
I have to mention that I added metal zip ties and intentionally left the plastic ones to see if they melt after some hard track use and they both held up just fine,YMMV
with that said I still had some fading especially when coming close to the T3 but soon after that brakes recover I think it's due to brake cooling, I will also need to address the rubbing issues I will most likely raise the car a little bit..
here is some footage from the last event
some track footage with the splitter and brake ducting
Build Thread
The Following User Says Thank You to glamcem For This Useful Post:
Old 06-19-2014, 11:30 AM   #10
ML
Mr No Bumper
ML's Avatar
Drives: 13 White MT FR-S
is that the cheapest option for the ducting??
My FR-S
Old 07-08-2014, 04:17 AM   #11
glamcem
glamcem's Avatar
I am sorry somehow I missed this post, yes it's the absolute cheapest option and after a few track days and about 1500 miles it is still staying strong
Build Thread
ML (07-08-2014)
Old 07-12-2014, 05:08 AM   #12
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Just for terminology's sake.
What you're calling the spindle is actually the "Brake/Dust Cover" or a "Backing Plate"
Not being a **** here.
Mad Paint skillz, I know.
Thanks for sharing the progress.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
The Following User Says Thank You to Floggin Tires For This Useful Post:
glamcem (07-13-2014)
Old 07-13-2014, 05:34 AM   #13
glamcem
glamcem's Avatar
Attachment 84781
Sorry for the confusion, and thanks for clarifying and yes I was referring to the brake dust cover/ backing plates.. I updated the wording accordingly
Build Thread
Floggin Tires (07-13-2014)
Old 05-13-2018, 05:49 PM   #14
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
with the fog light cable., do you cap it off or you can just simply disconnect it? i just thought i cannot leave the disconnected end open like that.
BRZ RN is offline   Reply With Quote
Search this Thread:
Advanced Search
BRZ Premium custom brake ducting ATL BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 02-17-2015 10:01 PM
3rd Brake Light Delete xxBrun0xx Cosmetic Modification (Interior/Exterior/Lighting) 10 04-19-2014 11:45 PM
Custom Third Brake Light Install (incl. Pics) Skorov AUSTRALIA 14 07-27-2013 04:04 AM
DIY Request: 3rd brake light delete Iddoit2er DIY (Do-It-Yourself) Guides 8 05-27-2013 06:53 PM
Custom Brake Ducting. Asterisked Accolade Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 07-09-2012 08:50 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
