#15 |
Drives: FR-S 6MT
Be patient.. It gets better with time and use.. No need to attempt to fix something that isn't broke..
#16 |
Drives: ft 86 black
i had the same issue, i took it back many times to toyota. they changed oil etc.
eventually they agreed there was a problem, and took my car for 8 weeks, and there was a syncro issue and they had the parts sent from japan and then gearbox rebuilt. in is much better than it was before, it was so annoying to drive, especially when it was cold. toyota service was shit as i said it from the day i got the car home it didnt feel right. but i persisted as people kept saying it was normal. i was sometimes unable to get it into gear e.g going from 3-2gear and 1-2gear. i was just not using that gear in the end which wasnt how it should be. the service department said just force it in.. i didnt thank gawd but it proves how smart they really are they replaced the 2nd and 3rd gear syncro rings and replaced 1, 2,3 4 hub assembly after waiting 8 weeks for the car back, got a letter to say it needed a service now. somehow they couldnt have done that in the 8 weeks they had the car.. |
#17 |
Stop pressing your clutch pedal all the way to the floor. Only needs to go about half way.
#18 |
Señor Member
Drives: BRZ SWP
grinding for 5 seconds? that sounds painful. my shifter was notchy at first but it loosened up after some use. I actually had a lighter shift knob and the notchy mechanical feeling was still there compared to stock but it seemed to glide into the gates and click into gear better than stock. I have a heavier shift knob now and although it masks the notchyness it doesnt seem to glide into the gates and click as well as the lighter shift knob did
sounds risky. adjust ur clutch travel for the same effect |
| The Following User Says Thank You to andrew5826 For This Useful Post: | Decisis (02-07-2014) |
#19 |
Mechanically Unsavvy
Drives: 2014 BRZ Limited SWP
I guess that's possible since our engagement point is a bit high up but I think that's kinda iffy?...
#20 | |
That guy
Drives: Ultramarine mt FR-S
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
#21 |
Drives: Yes
And how exactly would that solve the notchy shifting issue? o_O
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
| shifting into 2nd | cantaloupe | BRZ First-Gen (2012+) — General Topics | 63 | 06-23-2014 05:47 PM |
| notchy/gritty transmission. every gear grinding | prest1ge | Engine, Exhaust, Transmission | 41 | 12-09-2012 07:45 PM |
| Now 4th gear is notchy | Yruyur | Engine, Exhaust, Transmission | 38 | 11-15-2012 10:07 PM |
| MT Shifting | n8dog11914 | Engine, Exhaust, Transmission | 4 | 08-28-2012 04:28 PM |
| shifting and down shifting feel | Lowellrenzo | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 07-08-2012 06:09 PM |
