Old 01-30-2014, 09:26 AM   #15
Mikem53
Drives: FR-S 6MT
Be patient.. It gets better with time and use.. No need to attempt to fix something that isn't broke..
Mikem53 is offline   Reply With Quote
Old 02-06-2014, 01:47 PM   #16
marsh
Drives: ft 86 black
i had the same issue, i took it back many times to toyota. they changed oil etc.
eventually they agreed there was a problem, and took my car for 8 weeks, and there was a syncro issue and they had the parts sent from japan and then gearbox rebuilt.
in is much better than it was before, it was so annoying to drive, especially when it was cold. toyota service was shit as i said it from the day i got the car home it didnt feel right. but i persisted as people kept saying it was normal. i was sometimes unable to get it into gear e.g going from 3-2gear and 1-2gear. i was just not using that gear in the end which wasnt how it should be. the service department said just force it in.. i didnt thank gawd but it proves how smart they really are
they replaced the 2nd and 3rd gear syncro rings and replaced 1, 2,3 4 hub assembly
after waiting 8 weeks for the car back, got a letter to say it needed a service now. somehow they couldnt have done that in the 8 weeks they had the car..
marsh is offline   Reply With Quote
Old 02-06-2014, 10:17 PM   #17
KONVERTER
KONVERTER's Avatar
Stop pressing your clutch pedal all the way to the floor. Only needs to go about half way.
KONVERTER is offline   Reply With Quote
Old 02-07-2014, 12:04 AM   #18
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
grinding for 5 seconds? that sounds painful. my shifter was notchy at first but it loosened up after some use. I actually had a lighter shift knob and the notchy mechanical feeling was still there compared to stock but it seemed to glide into the gates and click into gear better than stock. I have a heavier shift knob now and although it masks the notchyness it doesnt seem to glide into the gates and click as well as the lighter shift knob did
sounds risky. adjust ur clutch travel for the same effect
andrew5826 is offline   Reply With Quote
The Following User Says Thank You to andrew5826 For This Useful Post:
Decisis (02-07-2014)
Old 02-07-2014, 01:43 AM   #19
Decisis
Mechanically Unsavvy
Decisis's Avatar
Drives: 2014 BRZ Limited SWP
I guess that's possible since our engagement point is a bit high up but I think that's kinda iffy?...
Decisis is offline   Reply With Quote
Old 02-07-2014, 02:17 AM   #20
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
There's something wrong with my trans. I've taken it to 2 different dealers, and they try to pin it on "hard shifting," but with my clutch fully depressed I have the synchros grind in second gear regularly no matter how slow I shift. I even heard the tech grind while downshifting from 6th to 5th and he just ignored it.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 02-07-2014, 04:36 AM   #21
chas3wba0
chas3wba0's Avatar
Drives: Yes
And how exactly would that solve the notchy shifting issue? o_O
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
shifting into 2nd cantaloupe BRZ First-Gen (2012+) — General Topics 63 06-23-2014 04:47 PM
notchy/gritty transmission. every gear grinding prest1ge Engine, Exhaust, Transmission 41 12-09-2012 06:45 PM
Now 4th gear is notchy Yruyur Engine, Exhaust, Transmission 38 11-15-2012 09:07 PM
MT Shifting n8dog11914 Engine, Exhaust, Transmission 4 08-28-2012 03:28 PM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 05:09 PM
